Home » Language IDEs » ServerTools (WTP) » XML editor encoding support
XML editor encoding support [message #52663] Mon, 08 November 2004 22:05 Go to next message
XML editor doesn't support all java encodings. I need MS949 encoding, but
it's not supported.
Re: XML editor encoding support [message #52961 is a reply to message #52663] Tue, 09 November 2004 15:45 Go to previous messageGo to next message
On Tue, 9 Nov 2004 12:05:03 +0900, Pak, Young-rok <refactorer@naver.com> wrote:
> it's not supported.
It should, when you say its not supported, are you getting an error message?
Or, just not decoding correctly? Are you using any exotic VM?
(And, I assume you have an xml declaration that specifies the encoding="ms949"?)
There might be a bug somewhere, but in principle, we should support anything
the Java VM supports. If you find that's not the case, a bugzilla report with
details and sample input, and maybe even a screen shot of error output (or
correct display!) would help us not to lose track of the problem.
Re: XML editor encoding support [message #52985 is a reply to message #52961] Tue, 09 November 2004 20:54 Go to previous message
oh, I'm sorry. it was my misunderstanding. MS949 xml documents is displayed
well. just preference has problem. encoding selection for creating files
does not contain MS949. it's not critical issue.
"David Williams" <david_williams@us.ibm.com> wrote in message
news:opsg7tajjeac05ss@news.eclipse.org...
but
> > it's not supported.
message?
encoding="ms949"?)
anything
with
Previous Topic:Dependency on EMF
Next Topic:Opening files with a non standard XML extension fails
Current Time: Tue Jul 15 16:46:56 EDT 2025
Powered by FUDForum. Page generated in 0.03916 seconds
