Home » Eclipse Projects » Plugin Development Environment (PDE) » Reading Bundle-SymbolicName and Bundle-Version from custom build.xml?
Re: Reading Bundle-SymbolicName and Bundle-Version from custom build.xml? [message #52781 is a reply to message #52755] |
Tue, 31 March 2009 09:42   |
It was before my time, but it was probably named 'build.xml' for the
same reason you named yours build.xml, (it is an ant script that builds
the project).
Note that the warning is only in the UI for export, headless build can't
prompt for warnings since that defeat the whole purpose of an automated
headless build.
For the version, PDE/Build will modify the custom build.xml and replace
the value on a property named "version.suffix", the value will be the
full version of the bundle with the qualifier replaced.
There is no property for the symbolic-name. Don't you know this? It
isn't something that changes.
-Andrew
Tom Morris wrote:
> Chris Aniszczyk wrote:
>> Tom Morris wrote:
>>> Back in 2006, there didn't appear to be an easy way to access the
>>> necessary parameters (Bundle-SymbolicName and Bundle-Version)
>>> according to this report
>>> http://dev.eclipse.org/newslists/news.eclipse.platform.rcp/m sg10949.html
>>> Has the situation improved today? Is there a way to get this
>>> information from the manifest or some other source which is
>>> accessible to Ant?
>> Is there a reason you have to have a build.xml in your project? can't
>> it be my-build.xml?
> Thanks for the quick reply Chris. I take it that that's a "No" in
> answer to the original question(s).
> In answer to your questions, the main reasons that it's called build.xml
> are: a) that's what Ant uses and b) that's what the development team
> chose in Fall 2000 when they switched to using Ant for their builds.
If a name like
> your-special-eclipse-pde-temporary-build.xml was used, there'd be fewer
> conflicts. Better yet, check to make sure the chosen name isn't already
> in use.
> I'm trying to promote Eclipse plugins to a project which has been around
> for a decade, so I really don't want to be insisting that they have to
> change things just to get started. I'd like to emphasize the benefits,
> not the costs.
> If I figure out a good way to parse the manifest or some other solution,
> I'll post an update.
> Tom
Re: Reading Bundle-SymbolicName and Bundle-Version from custom build.xml? [message #53043 is a reply to message #52807] |
Wed, 01 April 2009 11:22  |
See my comment here: https://bugs.eclipse.org/bugs/show_bug.cgi?id=120840#c8
Changing the default name of the script should be considered a major
breaking API change. The alternative is then to allow a bundle to
provide an alternate name. With some restrictions on features, this
should be possible, however it is not a small change and affects all the
generated scripts.
There is no time for something like this in 3.5. This would need to be
accounted for in the initial planning at the beginning of a release cycle.
-Andrew
>> builds the project).
>> can't prompt for warnings since that defeat the whole purpose of an
>> automated headless build.
>> replace the value on a property named "version.suffix", the value will
>> be the full version of the bundle with the qualifier replaced.
> Andrew, is there a way we can change the build.xml that gets generated
> to be pde-build.xml or something?
> Cheers,
> Chris Aniszczyk | EclipseSource Austin | +1 860 839 2465
> http://twitter.com/eclipsesource | http://twitter.com/caniszczyk
Re: Reading Bundle-SymbolicName and Bundle-Version from custom build.xml? [message #594277 is a reply to message #52728] |
Mon, 30 March 2009 23:24  |
>> information from the manifest or some other source which is accessible
>> to Ant?
> Is there a reason you have to have a build.xml in your project? can't it
> be my-build.xml?
As far as renaming things goes, let me turn the question around. Is
there any particular reason that a temporary file which is going to
exist for all of 5 minutes has be given a name that conflicts with every
Ant-based build in the known universe? If a name like
in use.
not the costs.
Tom
Re: Reading Bundle-SymbolicName and Bundle-Version from custom build.xml? [message #594286 is a reply to message #52755] |
the project).
headless build.
-Andrew
>>> accessible to Ant?
>> it be my-build.xml?
If a name like
> in use.
> not the costs.
> Tom
Re: Reading Bundle-SymbolicName and Bundle-Version from custom build.xml? [message #594296 is a reply to message #52781] |
Tue, 31 March 2009 10:06  |
> the project).
> headless build.
Re: Reading Bundle-SymbolicName and Bundle-Version from custom build.xml? [message #594413 is a reply to message #52807] |
generated scripts.
-Andrew
> Cheers,
Current Time: Sat Aug 30 23:13:30 EDT 2025
Powered by FUDForum. Page generated in 0.04826 seconds
