Home » Archived » M2M (model-to-model transformation) » [ATL] Problems with XMLInjector class
[ATL] Problems with XMLInjector class [message #52611] Tue, 17 July 2007 04:53
Originally posted by: erik_becker.gmx.de
Hi all,
I'm working on a solution to launch my ATL transformation
programmatically. Inspired by Milan Milanovic's ATLTransformations class
I developed a class which executes a XMLInjection, a
transformation and a XMLExtraction at the end.
Like in Milan Milanovic's solution I do a XMLInjection of a file. I
tried to change the name of the model that is created from 'IN' to
another value, but this results in a strange failure. The created XML
model is not correct.
Unfortunately in my transformation the source model is not named 'IN' so
that my transformation does not work correctly if I use the restult of
the XML injection as input.
Is there a way to 'rename' the model, to use another model name for the
injection or a another solution for my problem?
Thanks and Greets
Erik
Previous Topic:[ATL]println() in declarative expressions?
Next Topic:[ATL] Problem while launching ATL programmatically
Current Time: Sat Jul 26 08:26:58 EDT 2025
Powered by FUDForum. Page generated in 0.03315 seconds
