Home » Archived » BIRT » dateTime parameters don't work ??
dateTime parameters don't work ?? [message #52598] Wed, 29 June 2005 10:52 Go to next message
I've made a report design that take 2 dateTime parameters to generate data
in a certain time range (given at runtime). Hence, my main dataset has
also 2 dateTime parameters that would be injected in the request SELECT
.... WHERE dateCreation BETWEEN ? and ?
That doesn't work and generate a class cast exception.
I've seen in this newsgroup people having the same issue, so i tried to
set parameters type to the default (for both dataset and report
parameters) and set parameters at run time with plain string :
params.put("dateBegin", "2005-06-17 10:43:05");
params.put("dateEnd", "2005-06-27 10:43:05");
The report is generated with no errors but the data is not reduced to the
give time range...
How can i use dateTime parameters?? I desesperate need a workaround or
something,
Thanks for your help
Re: dateTime parameters don't work ?? [message #52735 is a reply to message #52598] Wed, 29 June 2005 17:15 Go to previous messageGo to next message
You should file a bugzilla report for this issue. Please attach the report
design and any custom code.
I am aware of a number of bugs related to date/time format issue currently
worked on by the BIRT team. You can also try a search in bugzilla for any
similar issues. Some may have already been resolved in latest 1.0.1
development builds.
Gary
"Alex" <a.tual@fylab.fr> wrote in message
news:85275a40d12cd799e9d04314368fabb0$1@www.eclipse.org...
> give time range...
> something,
Re: dateTime parameters don't work ?? [message #54091 is a reply to message #52598] Wed, 06 July 2005 03:38 Go to previous message
Originally posted by: none.none.none
Alex, were you able to resolve this issue? I am currently having the same
problem with report parameters (dataset parameters seem to be okay).
> reduced to the give time range...
> something,
Previous Topic:Easier way to set report data?
Next Topic:PDF summary - guard page
Current Time: Sat Jul 26 17:59:37 EDT 2025
Powered by FUDForum. Page generated in 0.03915 seconds
