Eclipse and JUnit [message #52537] |
Wed, 16 April 2003 10:07  |
Originally posted by: arashid.alpha-gamma.com
I am new to Eclipse and also want to learn JUnit. Any idea where can I find
tutorial which discuss both?
TIA
AR
Re: Eclipse and JUnit [message #52618 is a reply to message #52537] |
Thu, 17 April 2003 07:37  |
Originally posted by: panders.eircom.net
yahoo group http://groups.yahoo.com/group/contributingtoeclipse/ has a
pdf that focuses on using JUnit in eclipse - I found that to be a good
starting point, though its still work in progress and does contains
some errors!
> TIA
> AR
Re: Eclipse and JUnit [message #592997 is a reply to message #52537] |
Wed, 16 April 2003 12:59  |
Hey, I am in the same camp. I like the idea of learning both JUnit and
jfcUnit for any java app, much less Eclipse plugins. I like the idea also of
developing the unit test BEFORE writing any code. I'd love to learn more
about how to do this. I can't get my noggin' around how to do that right
now. Seems to me you'd have to have code first to figure out what to test,
so how you write a junit test case before any code, that one sort of has me
baffled. I'd love to see any good info as well. Are there any books on
JUnit?
"Asif Rashid - pass flinder1f7 user exquisitus" <arashid@alpha-gamma.com>
wrote in message news:b7jnep$97l$1@rogue.oti.com...
find
> TIA
> AR
Re: Eclipse and JUnit [message #593014 is a reply to message #52537] |
Wed, 16 April 2003 13:00  |
Incidentally, there is an article in Java Developer Journal this issue (go
to www.sys-con.com/jdj I think) about using Abbot, the Java Swing GUI Junit
extension to provide Swing UI automation testing. I am not sure which one is
better. jfcUnit hooks into the event que of Swing, where as Abbot uses the
Robot class. My understanding is that jfcUnit has the best deal, but I have
yet to figure out how to use it.
find
> TIA
> AR
Re: Eclipse and JUnit [message #593024 is a reply to message #52537] |
some errors!
> TIA
> AR
FUDForum. Page generated in 0.05305 seconds
