Home » Language IDEs » AspectJ » How to view multiple markers?
How to view multiple markers? [message #52536] Thu, 02 June 2005 23:42 Go to next message
When there is a gutter annotation indicating multiple markers, how does one actually get to see the markers?
thanks
-barry
Re: How to view multiple markers? [message #52696 is a reply to message #52536] Fri, 03 June 2005 04:21 Go to previous messageGo to next message
Hi Barry,
If you right click on the marker you will see one or more sub-menus
related to the type of the marker (e.g. if it is an advice marker you
will see 'Advised By'.) This menu will contain all the pieces of advice
that advise that line (or equivalent, depending on the relationship).
Sian
> thanks
> -barry
Re: How to view multiple markers? [message #52829 is a reply to message #52696] Fri, 03 June 2005 12:22 Go to previous messageGo to next message
Sian January wrote:
> Hi Barry,
Ah! At the bottom. I see now. This marker overlay is a bit messy. Often I can't tell if I have a breakpoint marker at a line because other markers are occluding it. It would be so nice if a hover tooltip would popup all the marker info.
thanks!
-barry
Re: How to view multiple markers? [message #53237 is a reply to message #52829] Mon, 06 June 2005 05:19 Go to previous messageGo to next message
Barry Kaplan wrote:
> Sian January wrote:
>> Hi Barry,
>> advice that advise that line (or equivalent, depending on the
>> relationship).
> thanks!
> -barry
In Eclipse try 'Window' > 'Preferences' > 'Java' > 'Editor', select the
Hovers tab then check 'Enable annotation roll-over...'. That may be
what you are looking for.
Sian
Re: How to view multiple markers? [message #53287 is a reply to message #53237] Mon, 06 June 2005 11:01 Go to previous message
Yes, that's exactly what I'm looking. Thanks much Sian!
-barry
Re: How to view multiple markers? [message #588533 is a reply to message #52536] Fri, 03 June 2005 04:21 Go to previous message
Hi Barry,
Sian
> thanks
> -barry
Re: How to view multiple markers? [message #588562 is a reply to message #52696] Fri, 03 June 2005 12:22 Go to previous message
Sian January wrote:
> Hi Barry,
thanks!
-barry
Re: How to view multiple markers? [message #588703 is a reply to message #52829] Mon, 06 June 2005 05:19 Go to previous message
Barry Kaplan wrote:
> Sian January wrote:
>> Hi Barry,
>> relationship).
> thanks!
> -barry
Sian
Re: How to view multiple markers? [message #588716 is a reply to message #53237] Mon, 06 June 2005 11:01 Go to previous message
-barry
Previous Topic:Can invoke introduced methods
Next Topic:Where to file this stack trace?
Current Time: Sat Jul 26 10:03:30 EDT 2025
Powered by FUDForum. Page generated in 0.06002 seconds
