Re: JNDI DataSource question [message #520050 is a reply to message #519953] |
Wed, 10 March 2010 23:58 |
Craig,
Take a look at this article. Although its for JBOSS it shows how to
configure the report to use JNDI.
http://www.birt-exchange.org/devshare/deploying-birt-reports /1055-using-the-birt-viewer-with-jboss/#description
Jason
Craig M wrote:
> I understand how to setup a JNDI DataSource in my server environment and
> get it working there. How can I configure that JNDI DataSource in the
> BIRT report designer so I can test my reports against real data without
> having to specify the JDBC URL and credentials?
Re: JNDI DataSource question [message #520243 is a reply to message #520058] |
Thu, 11 March 2010 16:44 |
Correct
Craig M wrote:
> So basically, if you have defined a JDBC URL *and* a JNDI name, the
> report engine will attempt to lookup the JNDI DataSource first. So I can
> configure my development database connection for use in the Eclipse
> environment, and in my app server it will ignore that and use the JNDI
> DataSource. Thanks!
FUDForum. Page generated in 0.03239 seconds
