Home » Archived » BIRT » birt chart: axis limitations
birt chart: axis limitations [message #519900] |
Wed, 10 March 2010 13:01 |
Originally posted by: georg.siegert.cpb-software.com
I use birt for a Line-Chart.
The x-Axis gets Date as an input type.
The request is to show on the x-Axis the label of the first and the last
date. And in between the other dates (in any granulation) are visible.
My problem are these two dates.
When I define the type of the x-Axis as a text-Field, the first and the last
labels are values within the time-serie.
When I use the type as a date, the first and the last labels are values
outside the time-serie.
How can I force the first and last values to be shown on my x-Axis?
Thanks in advance,
Georg
Re: birt chart: axis limitations [message #520051 is a reply to message #519900] |
Wed, 10 March 2010 23:58 |
Georg,
What version of BIRT are you using?
Can you recreate a report using the sample db that shows the problem and
post?
Jason
Georg Siegert wrote:
> Hello,
> Thanks in advance,
> Georg
Re: birt chart: axis limitations [message #520141 is a reply to message #520051] |
Thu, 11 March 2010 09:39 |
I user birt 2.5.1.
My chart is embedded into a Java Rich Client.
In my attachment you can see the chart and the corresponding data in the
table.
The input type is text (using the type: AxisType.TEXT_LITERAL).
In the result the last value on the axis is before the last value in the
table,
but it has to be the same.
When I resize the window, the chart repaints as it has to be.
I use the class org.eclipse.birt.chart.model.Chart and instanciate with
ChartWithAxesImpl.create()
Georg
"Jason Weathersby" <jasonweathersby@windstream.net> schrieb im Newsbeitrag
news:hn9bj3$ask$1@build.eclipse.org...
> Georg,
> post?
> Jason
>> Hello,
>> last
>> Thanks in advance,
>> Georg
Re: birt chart: axis limitations [message #520288 is a reply to message #520141] |
Thu, 11 March 2010 20:04 |
Georg,
What happens when use a date type axis? Are you setting the scale or is
it automatic?
Jason
> I user birt 2.5.1.
> table.
> table,
> Georg
>> Georg,
>> post?
>> Jason
>>> Hello,
>>> last
>>> Thanks in advance,
>>> Georg
Re: birt chart: axis limitations [message #520399 is a reply to message #520288] |
Fri, 12 March 2010 04:20 |
Jason,
On the attachment I send you now, I use the type date.
In this case the last value on the axis is after the last value of the
table, but it has to be the same.
I didn't set the the scale.
(Just the yAxis is able to reacts on a scale value - The report designer
works the same)
On the xAxis I can set the Intervall, but in that case I just change the
quantity
and not the extreme values.
Georg
news:hnbi92$4i6$1@build.eclipse.org...
> Georg,
> it automatic?
> Jason
>> I user birt 2.5.1.
>> table.
>> table,
>> Georg
>> Newsbeitrag
>>> Georg,
>>> post?
>>> Jason
>>>> Hello,
>>>> last
>>>> last
>>>> Thanks in advance,
>>>> Georg
Re: birt chart: axis limitations [message #520504 is a reply to message #520399] |
Fri, 12 March 2010 11:26 |
Georg,
Can you put the values in a flat file so I can build an example that has
the issue? Or can you post some code with the data in it that shows the
issue?
Jason
> Jason,
> works the same)
> quantity
> Georg
>> Georg,
>> it automatic?
>> Jason
>>> I user birt 2.5.1.
>>> table.
>>> table,
>>> Georg
>>> Newsbeitrag
>>>> Georg,
>>>> post?
>>>> Jason
>>>>> Hello,
>>>>> last
>>>>> last
>>>>> Thanks in advance,
>>>>> Georg
Re: birt chart: axis limitations [message #520765 is a reply to message #520504] |
Mon, 15 March 2010 09:14 |
Jason,
I put the values into a flat file.
Thanks a lot,
Georg
news:hndph8$pdr$1@build.eclipse.org...
> Georg,
> issue?
> Thanks
> Jason
>> Jason,
>> works the same)
>> quantity
>> Georg
>> Newsbeitrag
>>> Georg,
>>> it automatic?
>>> Jason
>>>> I user birt 2.5.1.
>>>> the
>>>> table.
>>>> the
>>>> table,
>>>> Georg
>>>> Newsbeitrag
>>>>> Georg,
>>>>> and
>>>>> post?
>>>>> Jason
>>>>>> Hello,
>>>>>> last
>>>>>> visible.
>>>>>> the
>>>>>> last
>>>>>> values
>>>>>> Thanks in advance,
>>>>>> Georg
Re: birt chart: axis limitations [message #520897 is a reply to message #520765] |
Mon, 15 March 2010 16:48 |
Georg,
Can you try something like this in your code:
Axis xAxisPrimary = cwaLine.getPrimaryBaseAxes( )[0];
Scale scale = xAxisPrimary.getScale();
scale.setMin( DateTimeDataElementImpl.create( new
CDateTime(2008,9,29,13,40) ) );
scale.setMax( DateTimeDataElementImpl.create( new
CDateTime(2008,9,29,16,20) ) );
Jason
> Jason,
> Thanks a lot,
> Georg
>> Georg,
>> issue?
>> Thanks
>> Jason
>>> Jason,
>>> works the same)
>>> quantity
>>> Georg
>>> Newsbeitrag
>>>> Georg,
>>>> it automatic?
>>>> Jason
>>>>> I user birt 2.5.1.
>>>>> the
>>>>> table.
>>>>> the
>>>>> table,
>>>>> Georg
>>>>> Newsbeitrag
>>>>>> Georg,
>>>>>> and
>>>>>> post?
>>>>>> Jason
>>>>>>> Hello,
>>>>>>> last
>>>>>>> visible.
>>>>>>> the
>>>>>>> last
>>>>>>> values
>>>>>>> Thanks in advance,
>>>>>>> Georg
Re: birt chart: axis limitations [message #521033 is a reply to message #520897] |
Tue, 16 March 2010 04:52 |
Jason,
great it works
thanks a lot,
Georg
news:hnlo5f$960$1@build.eclipse.org...
> Georg,
> CDateTime(2008,9,29,13,40) ) ); scale.setMax(
> DateTimeDataElementImpl.create( new CDateTime(2008,9,29,16,20) ) );
> Jason
>> Jason,
>> Thanks a lot,
>> Georg
>> Newsbeitrag news:hndph8$pdr$1@build.eclipse.org...
>>> Georg,
>>> issue?
>>> Thanks
>>> Jason
>>>> Jason,
>>>> designer
>>>> works the same)
>>>> the
>>>> quantity
>>>> Georg
>>>> Newsbeitrag
>>>>> Georg,
>>>>> is
>>>>> it automatic?
>>>>> Jason
>>>>>> I user birt 2.5.1.
>>>>>> the
>>>>>> table.
>>>>>> the
>>>>>> table,
>>>>>> with
>>>>>> Georg
>>>>>> Newsbeitrag
>>>>>>> Georg,
>>>>>>> and
>>>>>>> post?
>>>>>>> Jason
>>>>>>>> Hello,
>>>>>>>> last
>>>>>>>> visible.
>>>>>>>> the
>>>>>>>> last
>>>>>>>> values
>>>>>>>> Thanks in advance,
>>>>>>>> Georg
Current Time: Fri Apr 26 08:44:13 GMT 2024
Powered by FUDForum. Page generated in 0.03888 seconds
