Home » Modeling » M2T (model-to-text transformation) » AssertionFailed Exception with templates containing scriptles
AssertionFailed Exception with templates containing scriptles [message #52502] Wed, 29 October 2008 04:44 Go to next message
I'm being bothered by the JET Template editor that fails to open
templates containing (or beginning) with scriptlets. The editor fails to
open the resource with an exception (exception and sample code follow).
Is this a bug or expected behavior?
Jochen
Exception:
org.eclipse.core.runtime.AssertionFailedException: assertion failed:
at org.eclipse.core.runtime.Assert.isTrue(Assert.java:111)
at org.eclipse.core.runtime.Assert.isTrue(Assert.java:97)
at org.eclipse.jface.text.Position.<init>(Position.java:62)
org.eclipse.jet.internal.editor.JETTextEditor$PositionsColle ctor.matchOffset(JETTextEditor.java:439)
org.eclipse.jet.internal.editor.JETTextEditor$PositionsColle ctor.visit(JETTextEditor.java:416)
org.eclipse.jet.core.parser.ast.JavaScriptlet.accept0(JavaSc riptlet.java:54)
org.eclipse.jet.core.parser.ast.JETASTElement.accept(JETASTE lement.java:105)
org.eclipse.jet.core.parser.ast.JETCompilationUnit.accept0(J ETCompilationUnit.java:128)
org.eclipse.jet.internal.editor.JETTextEditor.requestCompila tionUnit(JETTextEditor.java:301)
org.eclipse.jet.internal.editor.JETTextEditor.getASTElement( JETTextEditor.java:309)
org.eclipse.jet.internal.editor.rules.ASTElementScannerRule. evaluate(ASTElementScannerRule.java:39)
org.eclipse.jet.internal.editor.rules.ASTElementScannerRule. evaluate(ASTElementScannerRule.java:33)
org.eclipse.jface.text.rules.RuleBasedScanner.nextToken(Rule BasedScanner.java:174)
org.eclipse.jface.text.rules.RuleBasedPartitionScanner.nextT oken(RuleBasedPartitionScanner.java:79)
org.eclipse.jface.text.rules.FastPartitioner.initialize(Fast Partitioner.java:166)
org.eclipse.jface.text.rules.FastPartitioner.checkInitializa tion(FastPartitioner.java:151)
org.eclipse.jface.text.rules.FastPartitioner.connect(FastPar titioner.java:143)
org.eclipse.jface.text.rules.FastPartitioner.connect(FastPar titioner.java:125)
org.eclipse.jet.internal.editor.configuration.JETDocumentPro vider.createDocument(JETDocumentProvider.java:45)
org.eclipse.ui.editors.text.FileDocumentProvider.createEleme ntInfo(FileDocumentProvider.java:734)
org.eclipse.ui.texteditor.AbstractDocumentProvider.connect(A bstractDocumentProvider.java:398)
org.eclipse.ui.texteditor.AbstractTextEditor.doSetInput(Abst ractTextEditor.java:3991)
org.eclipse.ui.texteditor.StatusTextEditor.doSetInput(Status TextEditor.java:190)
org.eclipse.ui.texteditor.AbstractDecoratedTextEditor.doSetI nput(AbstractDecoratedTextEditor.java:1325)
at org.eclipse.ui.editors.text.TextEditor.doSetInput(TextEditor .java:165)
org.eclipse.ui.texteditor.AbstractTextEditor$19.run(Abstract TextEditor.java:3026)
org.eclipse.jface.operation.ModalContext.runInCurrentThread( ModalContext.java:458)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.ja va:366)
org.eclipse.jface.window.ApplicationWindow$1.run(Application Window.java:758)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:70)
org.eclipse.jface.window.ApplicationWindow.run(ApplicationWi ndow.java:755)
at org.eclipse.ui.internal.WorkbenchWindow.run(WorkbenchWindow. java:2487)
org.eclipse.ui.texteditor.AbstractTextEditor.internalInit(Ab stractTextEditor.java:3044)
org.eclipse.ui.texteditor.AbstractTextEditor.init(AbstractTe xtEditor.java:3071)
org.eclipse.jet.internal.editor.JETTextEditor.init(JETTextEd itor.java:134)
at org.eclipse.ui.internal.EditorManager.createSite(EditorManag er.java:799)
org.eclipse.ui.internal.EditorReference.createPartHelper(Edi torReference.java:643)
org.eclipse.ui.internal.EditorReference.createPart(EditorRef erence.java:428)
org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:594)
org.eclipse.ui.internal.EditorReference.getEditor(EditorRefe rence.java:266)
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched( WorkbenchPage.java:2820)
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(Workben chPage.java:2729)
at org.eclipse.ui.internal.WorkbenchPage.access$11(WorkbenchPag e.java:2721)
at org.eclipse.ui.internal.WorkbenchPage$10.run(WorkbenchPage.j ava:2673)
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2668)
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2652)
at org.eclipse.ui.actions.OpenWithMenu.openEditor(OpenWithMenu. java:337)
at org.eclipse.ui.actions.OpenWithMenu.access$0(OpenWithMenu.ja va:325)
at org.eclipse.ui.actions.OpenWithMenu$2.handleEvent(OpenWithMe nu.java:187)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1561)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1585)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1570)
at org.eclipse.swt.widgets.Widget.notifyListeners(Widget.java:1 360)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3482)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3068)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2382)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2346)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:21 98)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:493)
org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:288)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:488)
org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:113)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:193)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:386)
The shortest template I have to reproduce this looks like this:
String classname="";
<c:iterate select="sort($class/@name |
$class/ancestor::*[@type='uml:Class']/@name,'count(ancestor: :*)') " var="p">
String
p=context.getVariable("p").toString().replaceAll("name=", "").replace('.','
').replaceAll(" ", "");
if (classname!="")
classname=classname.concat(".");
classname=classname.concat(p);
</c:iterate >
context.setVariable("className",classname);
classname=classname.replace('.', '_');
context.setVariable("fileName",classname);
Re: AssertionFailed Exception with templates containing scriptles [message #52586 is a reply to message #52502] Wed, 29 October 2008 08:17 Go to previous messageGo to next message
Jochen:
In general assertion failures are bugs. Feel free to submit a bugzilla:
https://bugs.eclipse.org/bugs/enter_bug.cgi
Enter it under Modeling / M2T / JET Editor
And, as always, patches are welcome.
Paul
Re: AssertionFailed Exception with templates containing scriptles [message #52638 is a reply to message #52586] Wed, 29 October 2008 09:34 Go to previous message
I opened a bug (https://bugs.eclipse.org/bugs/show_bug.cgi?id=252583),
and I'd love to provide a patch. Depends on how I find the time to do it.
Jochen
Paul Elder wrote:
> Jochen:
> Paul
Previous Topic:How to check if XPath query returns empty result?
Next Topic:[JET] Running a JET transform in headless mode
Current Time: Mon Jul 21 20:08:49 EDT 2025
Powered by FUDForum. Page generated in 0.55248 seconds
