AssertionFailed Exception with templates containing scriptles [message #52502] |
Wed, 29 October 2008 04:44  |
I'm being bothered by the JET Template editor that fails to open
templates containing (or beginning) with scriptlets. The editor fails to
open the resource with an exception (exception and sample code follow).
Is this a bug or expected behavior?
Jochen
Exception:
org.eclipse.core.runtime.AssertionFailedException: assertion failed:
at org.eclipse.core.runtime.Assert.isTrue(Assert.java:111)
at org.eclipse.core.runtime.Assert.isTrue(Assert.java:97)
at org.eclipse.jface.text.Position.<init>(Position.java:62)
org.eclipse.jet.internal.editor.JETTextEditor$PositionsColle ctor.matchOffset(JETTextEditor.java:439)
org.eclipse.jet.internal.editor.JETTextEditor$PositionsColle ctor.visit(JETTextEditor.java:416)
org.eclipse.jet.core.parser.ast.JavaScriptlet.accept0(JavaSc riptlet.java:54)
org.eclipse.jet.core.parser.ast.JETASTElement.accept(JETASTE lement.java:105)
org.eclipse.jet.core.parser.ast.JETCompilationUnit.accept0(J ETCompilationUnit.java:128)
org.eclipse.jet.internal.editor.JETTextEditor.requestCompila tionUnit(JETTextEditor.java:301)
org.eclipse.jet.internal.editor.JETTextEditor.getASTElement( JETTextEditor.java:309)
org.eclipse.jet.internal.editor.rules.ASTElementScannerRule. evaluate(ASTElementScannerRule.java:39)
org.eclipse.jet.internal.editor.rules.ASTElementScannerRule. evaluate(ASTElementScannerRule.java:33)
org.eclipse.jface.text.rules.RuleBasedScanner.nextToken(Rule BasedScanner.java:174)
org.eclipse.jface.text.rules.RuleBasedPartitionScanner.nextT oken(RuleBasedPartitionScanner.java:79)
org.eclipse.jface.text.rules.FastPartitioner.initialize(Fast Partitioner.java:166)
org.eclipse.jface.text.rules.FastPartitioner.checkInitializa tion(FastPartitioner.java:151)
org.eclipse.jface.text.rules.FastPartitioner.connect(FastPar titioner.java:143)
org.eclipse.jface.text.rules.FastPartitioner.connect(FastPar titioner.java:125)
org.eclipse.jet.internal.editor.configuration.JETDocumentPro vider.createDocument(JETDocumentProvider.java:45)
org.eclipse.ui.editors.text.FileDocumentProvider.createEleme ntInfo(FileDocumentProvider.java:734)
org.eclipse.ui.texteditor.AbstractDocumentProvider.connect(A bstractDocumentProvider.java:398)
org.eclipse.ui.texteditor.AbstractTextEditor.doSetInput(Abst ractTextEditor.java:3991)
org.eclipse.ui.texteditor.StatusTextEditor.doSetInput(Status TextEditor.java:190)
org.eclipse.ui.texteditor.AbstractDecoratedTextEditor.doSetI nput(AbstractDecoratedTextEditor.java:1325)
at org.eclipse.ui.editors.text.TextEditor.doSetInput(TextEditor .java:165)
org.eclipse.ui.texteditor.AbstractTextEditor$19.run(Abstract TextEditor.java:3026)
org.eclipse.jface.operation.ModalContext.runInCurrentThread( ModalContext.java:458)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.ja va:366)
org.eclipse.jface.window.ApplicationWindow$1.run(Application Window.java:758)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:70)
org.eclipse.jface.window.ApplicationWindow.run(ApplicationWi ndow.java:755)
at org.eclipse.ui.internal.WorkbenchWindow.run(WorkbenchWindow. java:2487)
org.eclipse.ui.texteditor.AbstractTextEditor.internalInit(Ab stractTextEditor.java:3044)
org.eclipse.ui.texteditor.AbstractTextEditor.init(AbstractTe xtEditor.java:3071)
org.eclipse.jet.internal.editor.JETTextEditor.init(JETTextEd itor.java:134)
at org.eclipse.ui.internal.EditorManager.createSite(EditorManag er.java:799)
org.eclipse.ui.internal.EditorReference.createPartHelper(Edi torReference.java:643)
org.eclipse.ui.internal.EditorReference.createPart(EditorRef erence.java:428)
org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:594)
org.eclipse.ui.internal.EditorReference.getEditor(EditorRefe rence.java:266)
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched( WorkbenchPage.java:2820)
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(Workben chPage.java:2729)
at org.eclipse.ui.internal.WorkbenchPage.access$11(WorkbenchPag e.java:2721)
at org.eclipse.ui.internal.WorkbenchPage$10.run(WorkbenchPage.j ava:2673)
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2668)
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2652)
at org.eclipse.ui.actions.OpenWithMenu.openEditor(OpenWithMenu. java:337)
at org.eclipse.ui.actions.OpenWithMenu.access$0(OpenWithMenu.ja va:325)
at org.eclipse.ui.actions.OpenWithMenu$2.handleEvent(OpenWithMe nu.java:187)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1561)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1585)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1570)
at org.eclipse.swt.widgets.Widget.notifyListeners(Widget.java:1 360)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3482)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3068)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2382)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2346)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:21 98)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:493)
org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:288)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:488)
org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:113)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:193)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:386)
The shortest template I have to reproduce this looks like this:
String classname="";
<c:iterate select="sort($class/@name |
$class/ancestor::*[@type='uml:Class']/@name,'count(ancestor: :*)') " var="p">
String
p=context.getVariable("p").toString().replaceAll("name=", "").replace('.','
').replaceAll(" ", "");
if (classname!="")
classname=classname.concat(".");
classname=classname.concat(p);
</c:iterate >
context.setVariable("className",classname);
classname=classname.replace('.', '_');
context.setVariable("fileName",classname);
FUDForum. Page generated in 0.04638 seconds
