HTTP Recording/ Doku [message #52480] |
Wed, 01 February 2006 12:14  |
Originally posted by: mark.worthmann.emprise.de
I hope these questions are not to stupid, but I think there are many
beginners, which are searching for it:
HTTP-Recording:
1. If I set iteration to 10, does it mean, that the test will run 10 times
while running the test. And if sychronous is clicked, it will run 10
times, all started at the same time?
2. If I set Users to 10, does it mean that the test will run with 10
different users (one time per each user/so it runs 10 times)?
3. I searched for the Dokumentation about the http recording. Can anyone
write where I can find it?
Thank you for your help,
Mark
Re: HTTP Recording/ Doku [message #56434 is a reply to message #52480] |
Mon, 06 March 2006 16:13  |
This is a multipart message in MIME format.
--=_alternative 00748F4F85257129_=
Content-Type: text/plain; charset="US-ASCII"
Sorry it took so long to respond to your question. If you are still
interested, you can access the help about TPTP from by clicking Help->Help
Contents->TPTP Tester Guide. Then expand 'Performance Testing with TPTP
and look at the section titled 'Editing a Test'. If you still; can not
find the answers you need post a response and I will try to help you.
Content-Type: text/html; charset="US-ASCII"
<br><font size=2 face="sans-serif">Sorry it took so long to respond to
your question. If you are still interested, you can access the help
about TPTP from by clicking Help->Help Contents->TPTP Tester Guide.
Then expand 'Performance Testing with TPTP and look at the section titled
'Editing a Test'. If you still; can not find the answers you need
post a response and I will try to help you. </font>
--=_alternative 00748F4F85257129_=--
FUDForum. Page generated in 0.06086 seconds
