Re: Using java with RCP BIRT [message #519379 is a reply to message #519120] |
Mon, 08 March 2010 16:31 |
Can you give some more detail on what you are trying? Are you wanting
to call Java from BIRT or create a BIRT report using Java?
Jason
agtn_agtn@yahoo.es wrote:
> I'm using BIRT v. 2.5 RCP and I want do a interface for choose two
> tables and manage some parameters. How can I do it?
> Thanks
Re: Using java with RCP BIRT [message #519467 is a reply to message #519446] |
Mon, 08 March 2010 17:26 |
In the beforeFactory script you can call any Java class in the classpath
as long as you import the package like:
importPackage(Packages.java.lang)
var myjsvar = new Integer(5);
You can also write the events in Java. Take a look at the bottom of
this page.
http://www.eclipse.org/birt/phoenix/deploy/reportScripting.p hp
Jason
> Well, the idea is to build a sql statement with a date and access the
> particular table (this is a historical database with some tables).
> The call would be made at an event before calling the dataset.
> I think rhino can run swing or awt interface, but for now, I'm
> investigating. But some help won't be bad.
> Greetings.
FUDForum. Page generated in 0.02753 seconds
