Home » Eclipse Projects » Mylyn » Empty Java editors: anyone has this problem?
Empty Java editors: anyone has this problem? [message #52441] Wed, 09 July 2008 06:25 Go to next message
Originally posted by: mauro.molinari.cardinis.com
Hello all!
When I start Eclipse and activate a task on which I was working the day
before, the editors of the files in the context are correctly reopened,
but it often happens that if I switch on one of the open editors which
is not in the foreground, I get an "empty" editor (a grey panel) instead
of the Java editor. The only workaround I found is to close and reopen
the editor (but in this way I remove the file from the context and I
have to reopen it using Ctrl+Shift+T), because switching to another
editor and going back to the empty one does not help, while neither
issuing a refresh on the file helps.
I have been facing this problem for long now, I hoped it were fixed in
Mylyn 3.0 but it is not. Am I the only one to have this problem? It's
quite an intrusive issue, but I cannot find a deterministic way to
reproduce.
Thanks in advance!
Mauro.
Re: Empty Java editors: anyone has this problem? [message #52499 is a reply to message #52441] Wed, 09 July 2008 10:53 Go to previous messageGo to next message
I just noticed it also happens with the JSP editor...
Mauro.
Re: Empty Java editors: anyone has this problem? [message #52552 is a reply to message #52499] Wed, 09 July 2008 15:33 Go to previous messageGo to next message
Happens to me too since some days. Let us digg out what is causing this.
Greets
Benny
> Mauro.
Re: Empty Java editors: anyone has this problem? [message #52606 is a reply to message #52441] Thu, 10 July 2008 14:26 Go to previous messageGo to next message
I also ran into this bug intermittently. I think I have even seen it when no
task was active on startup and the editors had been restored by the
workbench (Mylyn uses the same mechanism).
Mauro, please file a new bug and provide any steps you may have to reproduce
the problem.
Steffen
> Hello all!
> reproduce.
> Thanks in advance!
> Mauro.
Re: Empty Java editors: anyone has this problem? [message #52797 is a reply to message #52606] Mon, 14 July 2008 04:52 Go to previous message
> the problem.
Thank you Steffen, I opened the following bug:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=240636
Mauro.
Re: Empty Java editors: anyone has this problem? [message #591079 is a reply to message #52441] Wed, 09 July 2008 10:53 Go to previous message
Mauro.
Re: Empty Java editors: anyone has this problem? [message #591102 is a reply to message #52499] Wed, 09 July 2008 15:33 Go to previous message
Greets
Benny
> Mauro.
Re: Empty Java editors: anyone has this problem? [message #591127 is a reply to message #52441] Thu, 10 July 2008 14:26 Go to previous message
the problem.
Steffen
> Hello all!
> reproduce.
> Thanks in advance!
> Mauro.
Re: Empty Java editors: anyone has this problem? [message #591228 is a reply to message #52606] Mon, 14 July 2008 04:52 Go to previous message
> the problem.
Mauro.
Previous Topic:Hyperlinks between Tasks and Java code
Next Topic:Working Set and Mylyn
Current Time: Thu Jul 17 00:57:32 EDT 2025
Powered by FUDForum. Page generated in 0.27431 seconds
