[JET] Running a JET transform in headless mode [message #52424] |
Tue, 28 October 2008 20:01  |
I need to be able to run several JET transforms in headless mode. What is
the best way to achieve this?
I thought that adding a custom Ant builder to my projects would work, but
those cause some interesting exceptions. After a lot searching, I found
bug 184528. While this fixes the crashes, it only partially fixes the
issue -- while the builds no longer crash, I don't get any report of a
build failure (or any indication of status for that matter). Since this is
for a build system, that doesn't work so well.
I'm sorry if I'm asking a question with an obvious solution, but I'm new
to Eclipse and I'm really scratching my head over this.
Re: [JET] Running a JET transform in headless mode [message #52771 is a reply to message #52717] |
Wed, 29 October 2008 16:10  |
Tom:
If Ant isn't working, then I can't think of any route other than a custom
nature/builder.
But, if you go that route, it might be a very useful think to have in JET
itself. If you submit a bugzilla, I'd be willing to help figure out how to
create one, and, ultimately, put it into JET.
Paul
FUDForum. Page generated in 0.41648 seconds
