Home » Archived » XML Schema Definition (XSD) » xsdSchema.load() throws 'NullpointerException"! Help!1
xsdSchema.load() throws 'NullpointerException"! Help!1 [message #52439] Mon, 06 September 2004 03:36 Go to next message
Originally posted by: annasser.breathe.com
Am using the XSD Schema Infoset Model (.jar) lib on a Windows XP box ( No
Eclipse installed) but attempting to load a schema throws A
nullpointerException, containg reconcileAttributes() bla bla..
I could not do anything else, even when I try using OpenXSD.jar, same.
Any help colleagues?
Anne
Re: xsdSchema.load() throws 'NullpointerException"! Help!1 [message #52476 is a reply to message #52439] Mon, 06 September 2004 08:31 Go to previous messageGo to next message
Anne,
Good help is directly proportional to the details you provide. If you
have an exception, and a question about it, you should show the stack
trace. Which jars are you using? Have you included xsd.resources.jar?
Have you looked at the FAQ about your problem? Have you tried (looking
at or running) the sample code in org.eclipse.xsd.test? Maybe you need
to register the resource factory as in the sample.
>Anne
Re: xsdSchema.load() throws 'NullpointerException"! Help!1 [message #52533 is a reply to message #52476] Mon, 06 September 2004 22:01 Go to previous messageGo to next message
Merks,
Sorry, and thanks for your thread. Here is the NullpointerException
stackTrace.
org.eclipse.xsd.impl.XSDSchemaImpl.reconcileAttributes(XSDSc hemaImpl.java:1877)
org.eclipse.xsd.impl.XSDConcreteComponentImpl.reconcile(XSDC oncreteComponentImpl.java:947)
org.eclipse.xsd.impl.XSDConcreteComponentImpl.changeAttribut e(XSDConcreteComponentImpl.java:1228)
org.eclipse.xsd.impl.XSDSchemaImpl.changeAttribute(XSDSchema Impl.java:2223)
org.eclipse.xsd.impl.XSDConcreteComponentImpl.eNotify(XSDCon creteComponentImpl.java:1201)
org.eclipse.xsd.impl.XSDConcreteComponentImpl.setElementGen( XSDConcreteComponentImpl.java:2793)
org.eclipse.xsd.impl.XSDConcreteComponentImpl.setElement(XSD ConcreteComponentImpl.java:2825)
at org.eclipse.xsd.impl.XSDSchemaImpl.setElement(XSDSchemaImpl. java:2346)
org.eclipse.xsd.impl.XSDSchemaImpl.createMetaSchema(XSDSchem aImpl.java:480)
org.eclipse.xsd.util.XSDResourceImpl.handleSchemaElement(XSD ResourceImpl.java:505)
at org.eclipse.xsd.util.XSDResourceImpl.doLoad(XSDResourceImpl. java:404)
org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:867)
org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:741)
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo ad(ResourceSetImpl.java:247)
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo adHelper(ResourceSetImpl.java:262)
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResou rce(ResourceSetImpl.java:346)
org.eclipse.xsd.impl.XSDSchemaImpl.getMagicSchemaForSchema(X SDSchemaImpl.java:532)
org.eclipse.xsd.impl.XSDSchemaImpl.getSchemaForSchema(XSDSch emaImpl.java:609)
at org.eclipse.xsd.impl.XSDSchemaImpl.createSchema(XSDSchemaImp l.java:420)
at org.eclipse.xsd.util.XSDParser.getSchema(XSDParser.java:291)
com.k_int.schema.SchemaAnalyser.populateSchemaAnalysis(Schem aAnalyser.java:125)
at damix.SchemaAnalysisTest.main(SchemaAnalysisTest.java:114)
Anne
Ed Merks wrote:
> Anne,
> >Anne
'NullpointerException"! - SOLVED!!! [message #52560 is a reply to message #52533] Tue, 07 September 2004 00:14 Go to previous messageGo to next message
Hi All,
Now am using the XSD infoset Model at a rocket speed!! It seems like this
'NullPointerException' rooted at /**
(SDSchemaImpl.java)**/
is a serious problem for developers using the XSD model as standalone.
Once of the root causes of this is the incompitibility of the xmlParser
shipped with sun 1.4.* jdk or j2re. For those of you out there who might
be experiencing this problem, here is the solution:
1) You need to override the parser shipped with Sun's Java2 jdk or j2re:
a) Download your favorite uptodate DOM Level 2+ xmlPaser such as
xercesJ-2.* etc.
Anne wrote:
> Merks,
> stackTrace.
> java.lang.NullPointerException
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Anne
> Ed Merks wrote:
> > Anne,
> > >Anne
'NullpointerException"! - SOLVED!!! [message #52589 is a reply to message #52533] Tue, 07 September 2004 00:14 Go to previous messageGo to next message
Hi All,
xercesJ-2.* etc.
Anne wrote:
> Merks,
> stackTrace.
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Anne
> Ed Merks wrote:
> > Anne,
> > >Anne
'NullpointerException"! - SOLVED!!! [message #52617 is a reply to message #52533] Tue, 07 September 2004 00:22 Go to previous messageGo to next message
Hi All,
xercesJ- 2.* etc.
b) Assuming <Java-Home> is where you installed java2 jdk or j2re.
i) For jdk - Create a directory called 'endorsed' under
<Java-Home>\lib for j2re create the 'endorsed' directory should be created
under <Java-Home>\jre\lib.
ii) Put all the xmlParser implementation jar files under the
'endorsed' directory.
ii) Also add the jar files to your class path.
NB: Make sure that you do not include any other xmlPasers in your
classpath.
c) Register a new resource Factory as in
org.eclipse.xsd.test.XSDMainTest.java.
DONE!!
cheers
Anne
Anne wrote:
> Merks,
> stackTrace.
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Anne
> Ed Merks wrote:
> > Anne,
> > >Anne
Sorry, Two threads were a mistake!! Consider the bottom one! [message #52645 is a reply to message #52533] Tue, 07 September 2004 00:24 Go to previous message
Anne wrote:
> Merks,
> stackTrace.
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Anne
> Ed Merks wrote:
> > Anne,
> > >Anne
Re: xsdSchema.load() throws 'NullpointerException"! Help!1 [message #591404 is a reply to message #52439] Mon, 06 September 2004 08:31 Go to previous message
Anne,
>Anne
Re: xsdSchema.load() throws 'NullpointerException"! Help!1 [message #591427 is a reply to message #52476] Mon, 06 September 2004 22:01 Go to previous message
Merks,
stackTrace.
Anne
Ed Merks wrote:
> Anne,
> >Anne
'NullpointerException"! - SOLVED!!! [message #591435 is a reply to message #52533] Tue, 07 September 2004 00:14 Go to previous message
Hi All,
xercesJ-2.* etc.
Anne wrote:
> Merks,
> stackTrace.
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Anne
> Ed Merks wrote:
> > Anne,
> > >Anne
'NullpointerException"! - SOLVED!!! [message #591449 is a reply to message #52533] Tue, 07 September 2004 00:14 Go to previous message
Hi All,
xercesJ-2.* etc.
Anne wrote:
> Merks,
> stackTrace.
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Anne
> Ed Merks wrote:
> > Anne,
> > >Anne
'NullpointerException"! - SOLVED!!! [message #591459 is a reply to message #52533] Tue, 07 September 2004 00:22 Go to previous message
Hi All,
xercesJ- 2.* etc.
classpath.
DONE!!
cheers
Anne
Anne wrote:
> Merks,
> stackTrace.
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Anne
> Ed Merks wrote:
> > Anne,
> > >Anne
Sorry, Two threads were a mistake!! Consider the bottom one! [message #591471 is a reply to message #52533] Tue, 07 September 2004 00:24 Go to previous message
Anne wrote:
> Merks,
> stackTrace.
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Anne
> Ed Merks wrote:
> > Anne,
> > >Anne
Previous Topic:How to get access on the content of a XSDSimpletypeDefinition
Next Topic:How to get access on the content of a XSDSimpletypeDefinition
Current Time: Mon Jul 21 20:02:38 EDT 2025
Powered by FUDForum. Page generated in 0.29125 seconds
