Home » Eclipse Projects » JFace » Extend ObservableMapCellLabelProvider - Documentation?
Extend ObservableMapCellLabelProvider - Documentation? [message #4638] Wed, 13 May 2009 08:19 Go to next message
I successfully bound my datamodel to my UI (table) and vice versa,
according to the following snippet:
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.jface.e xamples.databinding/src/org/eclipse/jface/examples/databindi ng/snippets/Snippet032TableViewerColumnEditing.java?view=co
My model is backed by an array that consists of Row-objects, whereas
each Row-object consists of several String- and int-attributes,
according to the table's columns. The problem is now that if such an
int-attribute is empty, the UI displays a 0 instead of nothing, since 0
is the default value.
For this purpose I'd like to extend ObservableMapCellLabelProvider and
override the method(s) that are responsible for this. For a "usual"
ColumnLabelProvider it would look similar to this:
----- snip -----
public String getText(Object element) {
Row row = (Row) element;
switch(columnIndex) {
case 0:
if(row.getColumn(0).getValue() == 0)
return "";
----- snap -----
Unfortunately I am not able to find any documentation about the class
ObservableMapCellLabelProvider to ascertain which methods need to be
overridden.
Lars
Re: Extend ObservableMapCellLabelProvider - Documentation? [message #4915 is a reply to message #4638] Thu, 14 May 2009 04:31 Go to previous messageGo to next message
I figured it out myself now!
I browsed the Sources of Eclipse and noticed that i need a mix made of
50% ObservableMapCellLabelProvider and 50% ColumnLabelProvider.
Both have the same superclass, CellLabelProvider, but
ColumnLabelProvider additionally implements some interfaces.
For this purpose I ObservableMapCellLabelProvider and implemented the
interfaces that are implemented by ColumnLabelProvider.
It looks like the following now:
public class MHRObservableMapCellLabelProvider extends
ObservableMapCellLabelProvider implements IFontProvider,
IColorProvider, ILabelProvider {
Maybe this is helpful for someone else! :-)
HTH,
Lars
Lars Bischoff schrieb:
> Hello,
> ----- snip -----
> @Override
> case 0:
> return "";
> ----- snap -----
> overridden.
> Best regards,
> Lars
Re: Extend ObservableMapCellLabelProvider - Documentation? [message #6064 is a reply to message #4638] Fri, 15 May 2009 13:25 Go to previous message
Hi Lars,
For ObservableMapCellLabelProvider, I would recommend overriding
update(ViewerCell). In fact, that's what the JavaDoc says:
"A label provider based on one or more observable maps that track attributes
that this label provider uses for display. The default behavior is to
display the first attribute's value. Clients may customize by subclassing
and overriding update(ViewerCell)."
Boris
"Lars Bischoff" <molehillrocker@googlemail.com> wrote in message
news:guedss$l9v$1@build.eclipse.org...
> Hello,
> My model is backed by an array that consists of Row-objects, whereas each
> Row-object consists of several String- and int-attributes, according to
> the table's columns. The problem is now that if such an int-attribute is
> empty, the UI displays a 0 instead of nothing, since 0 is the default
> value.
> ----- snip -----
> @Override
> case 0:
> return "";
> ----- snap -----
> overridden.
> Best regards,
> Lars
Previous Topic:Re: Jump into first cell of Table
Next Topic:Re: CCombo updates in Eclipse 3.4.
Current Time: Wed Jul 23 00:41:46 EDT 2025
Powered by FUDForum. Page generated in 0.07469 seconds
