Home » Eclipse Projects » Eclipse Platform » examples.javaeditor package source doesn't work? :(
examples.javaeditor package source doesn't work? :( [message #52260] |
Wed, 28 May 2003 14:23  |
Originally posted by: ephedrine.rogers.com
I've downloaded the entire javaeditor package from eclipse.org, have
moved its source and plugin file into a new java project properly named, and
in an effort of auto-didacity I thought could work by editing its source and
then running as 'Run-Time Workbench' - I get stumped. A hurdle! All seems
well - the icon works as specified in the plugin.xml file, yet when I try to
open a file with .jav extension in my runtimeworkbench, I get this error:
Exception creating editor: Unable to instantiate editor:
org.eclipse.ui.JavaEditor org.eclipse.core.runtime.CoreException: Plug-in
org.eclipse.ui.examples.javaeditor was unable to load class
org.eclipse.ui.examples.javaeditor.JavaEditor.
But it's in fact there!? I see lots of other people have gone through
this as well, but no answers or solutions are posted anywhere.
Urgent help appreciated!
Alex
Re: examples.javaeditor package source doesn't work? :( [message #52801 is a reply to message #52773] |
Wed, 28 May 2003 22:41   |
Hi thanks.
Absolutely - I'm not sure how much of this you would required, so I've
posted a whole session for completeness. The extension points seem to be
hooking properly as the editor view is made available in the run-time
workbench. The problem lies in when I try to 'open with' the java test
editor - that's when the error surfaces.
Thanks for your reply Syed!
!SESSION May 28, 2003
14:10:57.796 ---------------------------------------------
java.version=1.4.0_03
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_CA
Command-line arguments: -pdelaunch -dev ,bin -feature
org.eclipse.platform -data C:\Program Files\eclipse\runtime-workspace -os
win32 -ws win32 -arch x86 -nl en_CA -configuration file:C:/Program
Files/eclipse/workspace/.metadata/.plugins/org.eclipse.pde.c ore/C__Program
Files_eclipse_runtime-workspace/platform.cfg -install file:C:/Program
Files/eclipse/
!ENTRY org.eclipse.core.runtime 4 2 May 28, 2003 14:10:57.812
!MESSAGE Plug-in org.eclipse.ui.examples.javaeditor was unable to load class
!STACK 0
java.lang.ClassNotFoundException:
org.eclipse.core.internal.boot.DelegatingURLClassLoader.load Class(Delegating
URLClassLoader.java:866)
at java.lang.ClassLoader.loadClass(ClassLoader.java:262)
org.eclipse.core.internal.plugins.PluginDescriptor.createExe cutableExtension
(PluginDescriptor.java:130)
(PluginDescriptor.java:167)
org.eclipse.core.internal.plugins.ConfigurationElement.creat eExecutableExten
sion(ConfigurationElement.java:103)
at org.eclipse.ui.internal.WorkbenchPlugin$1.run(WorkbenchPlugi n.java:158)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:69)
org.eclipse.ui.internal.WorkbenchPlugin.createExtension(Work benchPlugin.java
:155)
at org.eclipse.ui.internal.EditorManager$3.run(EditorManager.ja va:676)
org.eclipse.core.internal.runtime.InternalPlatform.run(Inter nalPlatform.java
:889)
at org.eclipse.core.runtime.Platform.run(Platform.java:413)
at org.eclipse.ui.internal.EditorManager.createPart(EditorManag er.java:674)
org.eclipse.ui.internal.EditorManager.openInternalEditor(Edi torManager.java:
661)
at org.eclipse.ui.internal.EditorManager.access$7(EditorManager .java:655)
at org.eclipse.ui.internal.EditorManager$7.run(EditorManager.ja va:919)
:889)
org.eclipse.ui.internal.EditorManager.busyRestoreEditor(Edit orManager.java:8
64)
at org.eclipse.ui.internal.EditorManager$6.run(EditorManager.ja va:857)
org.eclipse.ui.internal.EditorManager.restoreEditor(EditorMa nager.java:853)
org.eclipse.ui.internal.EditorManager.restoreState(EditorMan ager.java:756)
org.eclipse.ui.internal.WorkbenchPage.restoreState(Workbench Page.java:2263)
org.eclipse.ui.internal.WorkbenchWindow.restoreState(Workben chWindow.java:13
27)
at org.eclipse.ui.internal.Workbench.restoreState(Workbench.jav a:1263)
at org.eclipse.ui.internal.Workbench.access$10(Workbench.java:1 223)
at org.eclipse.ui.internal.Workbench$12.run(Workbench.java:1141 )
:889)
org.eclipse.ui.internal.Workbench.openPreviousWorkbenchState (Workbench.java:
1093)
at org.eclipse.ui.internal.Workbench.init(Workbench.java:870)
at org.eclipse.ui.internal.Workbench.run(Workbench.java:1373)
org.eclipse.core.internal.boot.InternalBootLoader.run(Intern alBootLoader.jav
a:845)
at org.eclipse.core.boot.BootLoader.run(BootLoader.java:461)
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl
..java:25)
at org.eclipse.core.launcher.Main.basicRun(Main.java:291)
at org.eclipse.core.launcher.Main.run(Main.java:747)
at org.eclipse.core.launcher.Main.main(Main.java:583)
!ENTRY org.eclipse.ui.workbench 4 2 May 28, 2003 14:10:57.812
!MESSAGE Problems occurred when invoking code from plug-in:
"org.eclipse.ui.workbench".
!STACK 1
org.eclipse.core.runtime.CoreException[2]: java.lang.ClassNotFoundException:
:155)
:889)
661)
:889)
64)
27)
:889)
1093)
a:845)
..java:25)
!STACK 0
:155)
:889)
661)
:889)
64)
27)
:889)
1093)
a:845)
..java:25)
!SUBENTRY 1 org.eclipse.core.runtime 4 2 May 28, 2003 14:10:57.812
!STACK 0
:155)
:889)
661)
:889)
64)
27)
:889)
1093)
a:845)
..java:25)
!ENTRY org.eclipse.ui 4 4 May 28, 2003 14:10:57.828
!MESSAGE Exception creating editor: Unable to instantiate editor:
!ENTRY org.eclipse.core.runtime 4 2 May 28, 2003 14:11:09.921
!STACK 0
:155)
:889)
661)
org.eclipse.ui.internal.EditorManager.openEditorFromDescript or(EditorManager
..java:459)
at org.eclipse.ui.internal.EditorManager.openEditor(EditorManag er.java:431)
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(Workben chPage.java:2054
at org.eclipse.ui.internal.WorkbenchPage.access$6(WorkbenchPage .java:2004)
at org.eclipse.ui.internal.WorkbenchPage$9.run(WorkbenchPage.ja va:1991)
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:1986)
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:1879)
at org.eclipse.ui.actions.OpenWithMenu.openEditor(OpenWithMenu. java:237)
at org.eclipse.ui.actions.OpenWithMenu.access$0(OpenWithMenu.ja va:231)
at org.eclipse.ui.actions.OpenWithMenu$2.handleEvent(OpenWithMe nu.java:155)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :81)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:840)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:1838)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :1545)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1402)
at org.eclipse.ui.internal.Workbench.run(Workbench.java:1385)
a:845)
..java:25)
!ENTRY org.eclipse.ui.workbench 4 2 May 28, 2003 14:11:09.921
!STACK 1
:155)
:889)
661)
..java:459)
a:845)
..java:25)
!STACK 0
:155)
:889)
661)
..java:459)
a:845)
..java:25)
!SUBENTRY 1 org.eclipse.core.runtime 4 2 May 28, 2003 14:11:09.921
!STACK 0
:155)
:889)
661)
..java:459)
a:845)
..java:25)
"Syed Rizvi" <sma_r@hotmail.com> wrote in message
news:bb3r90$6un$1@rogue.oti.com...
> Can you paste the .log file from metadata so that we can pinpoint the
> error.
> cheers
> Syed
> Alexandre wrote:
> > Hi,
and
and
seems
try to
error:
Plug-in
through
> > Alex
Re: examples.javaeditor package source doesn't work? :( [message #52857 is a reply to message #52801] |
Wed, 28 May 2003 23:15   |
It seems that for some reason your JavaEditor file name is not what it is
suppose to be,check that out also.Secondly I would suggest that you create
a whole new project but don't use the project name of the downloaded
code,like make a project com.example.MyEditor and change the files in it
as to what I can see there is some name problem with your project,also
check the plugin.xml you might have used a wrong name there.
Teh reason I am asking you have a seperate name is that then you get to
know which is your file/class and which is of Eclipse.I know it is
somewhat time consuming but it might solve the problem.
Syed
Alexandre wrote:
> Hi thanks.
> Files/eclipse/
> !STACK 0
> at
> at
> at
> at
> at
> :155)
> at
> :889)
> at
> 661)
> at
> :889)
> at
> 64)
> at
> at
> at
> at
> 27)
> at
> :889)
> at
> 1093)
> at
> a:845)
> at
> at
> ..java:25)
> !STACK 1
> at
> at
> at
> at
> at
> :155)
> at
> :889)
> at
> 661)
> at
> :889)
> at
> 64)
> at
> at
> at
> at
> 27)
> at
> :889)
> at
> 1093)
> at
> a:845)
> at
> at
> ..java:25)
> !STACK 0
> at
> at
> at
> at
> at
> :155)
> at
> :889)
> at
> 661)
> at
> :889)
> at
> 64)
> at
> at
> at
> at
> 27)
> at
> :889)
> at
> 1093)
> at
> a:845)
> at
> at
> ..java:25)
> !STACK 0
> at
> at
> at
> at
> at
> :155)
> at
> :889)
> at
> 661)
> at
> :889)
> at
> 64)
> at
> at
> at
> at
> 27)
> at
> :889)
> at
> 1093)
> at
> a:845)
> at
> at
> ..java:25)
> !STACK 0
> at
> at
> at
> at
> at
> :155)
> at
> :889)
> at
> 661)
> at
> ..java:459)
> at
> at
> at
> at
> a:845)
> at
> at
> ..java:25)
> !STACK 1
> at
> at
> at
> at
> at
> :155)
> at
> :889)
> at
> 661)
> at
> ..java:459)
> at
> at
> at
> at
> a:845)
> at
> at
> ..java:25)
> !STACK 0
> at
> at
> at
> at
> at
> :155)
> at
> :889)
> at
> 661)
> at
> ..java:459)
> at
> at
> at
> at
> a:845)
> at
> at
> ..java:25)
> !STACK 0
> at
> at
> at
> at
> at
> :155)
> at
> :889)
> at
> 661)
> at
> ..java:459)
> at
> at
> at
> at
> a:845)
> at
> at
> ..java:25)
> > error.
> > cheers
> > Syed
> > Alexandre wrote:
> > > Hi,
> and
> and
> seems
> try to
> error:
> Plug-in
> through
> > > Alex
Re: examples.javaeditor package source doesn't work? :( [message #52912 is a reply to message #52857] |
Thu, 29 May 2003 00:07   |
The JavaEditor file is well in place. I have a good difficulty
understanding why this example doesn't work. It's difficult to learn
through such trouble when the learning material is this hard to operate.
I tried renaming everything from A to Z, and still no luck. I even went
to the extent of changing all the Java across the files names to something
else for kicks and I get the same errors. Very difficult!
These are the files I've been using. Any idea?
Thanks.
Alex
news:bb3u0l$8fk$1@rogue.oti.com...
> Syed
> Alexandre wrote:
> > Hi thanks.
I've
be
> > Files/eclipse/
class
> > !STACK 0
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > :155)
> > at
> > :889)
> > at
> > at
> > 661)
> > at
> > at
> > :889)
> > at
> > 64)
> > at
> > at
> > at
> > at
> > at
> > 27)
> > at
> > :889)
> > at
> > 1093)
> > at
> > a:845)
> > at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
> > at
> > at
> > ..java:25)
> > !STACK 1
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > :155)
> > at
> > :889)
> > at
> > at
> > 661)
> > at
> > at
> > :889)
> > at
> > 64)
> > at
> > at
> > at
> > at
> > at
> > 27)
> > at
> > :889)
> > at
> > 1093)
> > at
> > a:845)
> > at
> > at
> > ..java:25)
class
> > !STACK 0
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > :155)
> > at
> > :889)
> > at
> > at
> > 661)
> > at
> > at
> > :889)
> > at
> > 64)
> > at
> > at
> > at
> > at
> > at
> > 27)
> > at
> > :889)
> > at
> > 1093)
> > at
> > a:845)
> > at
> > at
> > ..java:25)
class
> > !STACK 0
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > :155)
> > at
> > :889)
> > at
> > at
> > 661)
> > at
> > at
> > :889)
> > at
> > 64)
> > at
> > at
> > at
> > at
> > at
> > 27)
> > at
> > :889)
> > at
> > 1093)
> > at
> > a:845)
> > at
> > at
> > ..java:25)
Plug-in
class
> > !STACK 0
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > :155)
> > at
> > :889)
> > at
> > at
> > 661)
> > at
> > ..java:459)
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > a:845)
> > at
> > at
> > ..java:25)
> > !STACK 1
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > :155)
> > at
> > :889)
> > at
> > at
> > 661)
> > at
> > ..java:459)
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > a:845)
> > at
> > at
> > ..java:25)
class
> > !STACK 0
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > :155)
> > at
> > :889)
> > at
> > at
> > 661)
> > at
> > ..java:459)
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > a:845)
> > at
> > at
> > ..java:25)
class
> > !STACK 0
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > :155)
> > at
> > :889)
> > at
> > at
> > 661)
> > at
> > ..java:459)
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > a:845)
> > at
> > at
> > ..java:25)
> > > error.
> > > cheers
> > > Syed
> > > Alexandre wrote:
> > > > Hi,
have
named,
> > and
source
> > and
All
> > seems
I
> > try to
> > error:
> > Plug-in
> > through
> > > > Alex
Re: examples.javaeditor package source doesn't work? :( [message #53012 is a reply to message #52912] |
Thu, 29 May 2003 01:00   |
Can you get any other example to work on Eclipse.You can also check this
by getting the XMLEditor example.Go to file_>new->project->plugin
development->plugin project->choose a name->then click plugin with an
editor.If this example works then we know that there is no plugin import
problem.Secondly I like to know if this .log file you attached is from
runtime_workapce->metadata->.log.
It takes time and this way of learnign is very help in debugging later on.
Syed
Alexandre wrote:
> Thanks.
> Alex
> > Syed
> > Alexandre wrote:
> > > Hi thanks.
> I've
> be
> > > Files/eclipse/
> class
> > > !STACK 0
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > :155)
> > > at
> > > :889)
> > > at
> > > at
> > > 661)
> > > at
> > > at
> > > :889)
> > > at
> > > 64)
> > > at
> > > at
> > > at
> > > at
> > > at
> > > 27)
> > > at
> > > :889)
> > > at
> > > 1093)
> > > at
> > > a:845)
> > > at
> > > at
> > > ..java:25)
> > > !STACK 1
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > :155)
> > > at
> > > :889)
> > > at
> > > at
> > > 661)
> > > at
> > > at
> > > :889)
> > > at
> > > 64)
> > > at
> > > at
> > > at
> > > at
> > > at
> > > 27)
> > > at
> > > :889)
> > > at
> > > 1093)
> > > at
> > > a:845)
> > > at
> > > at
> > > ..java:25)
> class
> > > !STACK 0
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > :155)
> > > at
> > > :889)
> > > at
> > > at
> > > 661)
> > > at
> > > at
> > > :889)
> > > at
> > > 64)
> > > at
> > > at
> > > at
> > > at
> > > at
> > > 27)
> > > at
> > > :889)
> > > at
> > > 1093)
> > > at
> > > a:845)
> > > at
> > > at
> > > ..java:25)
> class
> > > !STACK 0
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > :155)
> > > at
> > > :889)
> > > at
> > > at
> > > 661)
> > > at
> > > at
> > > :889)
> > > at
> > > 64)
> > > at
> > > at
> > > at
> > > at
> > > at
> > > 27)
> > > at
> > > :889)
> > > at
> > > 1093)
> > > at
> > > a:845)
> > > at
> > > at
> > > ..java:25)
> Plug-in
> class
> > > !STACK 0
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > :155)
> > > at
> > > :889)
> > > at
> > > at
> > > 661)
> > > at
> > > ..java:459)
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > a:845)
> > > at
> > > at
> > > ..java:25)
> > > !STACK 1
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > :155)
> > > at
> > > :889)
> > > at
> > > at
> > > 661)
> > > at
> > > ..java:459)
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > a:845)
> > > at
> > > at
> > > ..java:25)
> class
> > > !STACK 0
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > :155)
> > > at
> > > :889)
> > > at
> > > at
> > > 661)
> > > at
> > > ..java:459)
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > a:845)
> > > at
> > > at
> > > ..java:25)
> class
> > > !STACK 0
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > :155)
> > > at
> > > :889)
> > > at
> > > at
> > > 661)
> > > at
> > > ..java:459)
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > a:845)
> > > at
> > > at
> > > ..java:25)
> > > > error.
> > > > cheers
> > > > Syed
> > > > Alexandre wrote:
> > > > > Hi,
> have
> named,
> > > and
> source
> > > and
> All
> > > seems
> I
> > > try to
> > > error:
> > > Plug-in
> > > through
> > > > > Alex
> begin 666 org.eclipse.ui.examples.javaeditor.zip
> M4$L#! H``````.1PO"X````````````````C````;W)G+F5C;&EP<V4N=6DN
> M97AA;7!L97,N:F%V865D:71O<B]02P,$% ````@`67&\+F\F&1^K````K $`
> M`"T```!O<F<N96-L:7!S92YU:2YE>&%M<&QE<RYJ879A961I=&]R+RYC;&%S
> M<W!A=&BED+T*PD 0A'O!=SBV]Z*=1<X@$D&+""'6$C9+<GJY"_<C^O;&0HR-
> M`=UNA]EOAXF36ZO8E:R31@M8\#DPTF@JJ6L!QV([6T*RFDYB5*5S7>F;?F']
> MO 72WM[91>I*@+,(["D*@.BK$XU^.8VM.:&2G2-^KCQ79=#8] 'X/D]/FT-6
> MK'=9FH\`!Z^C(3'('P_16.(V:"];^@M!S@2+Y$8@)O@N^(_ZXFA8^P-02P,$
> M% ````@`67&\+A"]@4'G````'P(``"L```!O<F<N96-L:7!S92YU:2YE >&%M
> M<&QE<RYJ879A961I=&]R+RYP<F]J96-TC5'+3L,P$#Q3B7^H <L>&6P]N>@#U
> M!PH?8.Q5M%'\T-JN^OGXD02"0'#SC&=GQV-QNIEI?P4*Z.RQ>V*/W1ZL <AKM
> M<.S>7L\/A^[4W^^$)S>"BB\0%*&/69W9.V&E@=[1P$!-Z .PA QNTO@)`AOE
> M58+&Z$CP*BP3RAD#-O:"+Z?"SO:A@!5MC)4C8 3!)5(0!%\T?PPD&]' /^0)
> M-Z(5U$CB/>&D+QY4,ZCP.>>75E?FAR9&'5N&4D,=@"\]Y E)0RH%A!GS+2'X
> M]RTSL\3(*V/*C31U`[\G:/<E0-55NT^#];G;#_X`4$L#! H``````)E4MRX`
> M```````````````I````;W)G+F5C;&EP<V4N=6DN97AA;7!L97,N:F%V865D
> M:71O<B]I8V]N<R]02P,$"@``````57"\+@```````````````"\```!O <F<N
> M96-L:7!S92YU:2YE>&%M<&QE<RYJ879A961I=&]R+VEC;VYS+V]B:C$V+U!+
> M`P04````" !A;KPN0U;4S&X```",````-P```&]R9RYE8VQI<'-E+G5I+F5X
> M86UP;&5S+FIA=F%E9&ET;W(O:6-O;G,O;V)J,38O:F%V82YG:69 S]W2SL$P4
> M8!!@V,P``0T,#0T'#AQH:&A@^ \"#+B!XD\61@8&5@8=$ =DA@.+Y883GMJJ
> MQUK.-!Z]V58IGR[UQ'7-&M/&V3/W/;3<7;&N6:;P\JP>_@^'C[ Q,:X2<='J
> MGA.QS&--5.E.#@9K`%!+`P04````" !CL+LNC\YNV,P"````# ``. ```&]R
> M9RYE8VQI<'-E+G5I+F5X86UP;&5S+FIA=F%E9&ET;W(O:6-O;G,O;V)J,38O
> M5&AU;6)S+F1BNW!>\,'"C5(/&=" '0,SP[__G QL2&*,4 P&`@P,3%#^O___
> M_\.$_X^"(07^`O$_*&:!QN4H&#D@B"$?"$L8%!A<&?* =!%#)7I1@!>(,;#"
> M\SPC(<6V]]WVJAQF9 8R&Y@@0H8DV88)6!B8&$%V@XP#T43K@]KOS) (]'4B
> M0PXP%-+)L%\`6 HBAR<Q>CB!V(0,NW !4NU'!J X`P4%*$Y ^9\5B$%E/CL0
> M<S! RH/1,F'X`AYH&OC!"*%?,(*K=C#^?^/_`081#B!;@"5(D,%=D,%)D,%1
> MD.'_+08^EB &=P8G!D<&!GN&KWN+WU[.$EJZ;V-MTD17!H^W04PJDR(EV1[K
> M^#F<B)N[^>#ZX(^^9[\8^UR[M?7K@E[=Y"[M0 :ALS;'5.]=.JH8RKM9U9U9
> MG:= ^\J?X.):GLNFV];69BA[1SSJNN+ LMG?L+-\RT:/4.><DX$'3AZ6X?KY
> M;W7FI?NW*@Z=._KUK'_ UAT;=TU\O&];F](F5]4=0;N5>B9V1E^1/S39;]J_
> MR\?$RO37956UKCW:>Z5?]NL60]%)FKJ'IMX42>GQNK?@GZC8Q/)J^1[=-W[;
> M5\??.IE9EM(?N*F/2:7+NT#2[+!DZI&U)T[-NZNQ5M;MWI-716=%YWQ ZIN$3
> M="3YIXK;A#EMI1:*#1:ON'EZKLXM]]VY>^^D"-WE1JNB3V87\T_S,7;[).=L
> M-6F-?#:#VY/RF)ZK=PFKN1AB(L\?=_B1]=JB7\%<N=.DK5D\FHY,LC+>+1+@
> M+:]EV'2V=\D[ZVU+I/C;UR=^E+VVLU:SU>PT[]PF%<<D3UG)NUT:JOU3)0ZF
> M';M4+GL[:'F[C:[M]([WI:=[IZU4G*F[1JE+-$1HE_&)9R8LNRL#^2( _;IE[
> MO.R*]O^;E)0]`L#2`I1N$J!8!9J>&+H$;MHH'F;,`I:M94"L!RQ=,QG2*+%J
> M%- ```!02P,$"@``````H7"\+@```````````````"<```!O<F<N96-L:7!S
> M92YU:2YE>&%M<&QE<RYJ879A961I=&]R+V]R9R]02P,$ "@``````0W&\+@``
> M`````````````"\```!O<F<N96-L:7!S92YU:2YE>&%M<&QE <RYJ879A961I
> M=&]R+V]R9R]E8VQI<'-E+U!+`P0*```````E<;PN````````````````,@``
> M`&]R9RYE8VQI<'-E+G5I+F5X86UP;&5S+FIA=F%E9&ET;W(O;W)G+V5C;&EP
> M<V4O=6DO4$L#! H``````"5QO"X````````````````[````;W)G+F5C;&EP
> M<V4N=6DN97AA;7!L97,N:F%V865D:71O<B]O<F<O96-L:7!S92]U:2]E >&%M
> M<&QE<R]02P,$"@``````67&\+@```````````````$8```!O <F<N96-L:7!S
> M92YU:2YE>&%M<&QE<RYJ879A961I=&]R+V]R9R]E8VQI <'-E+W5I+V5X86UP
> M;&5S+VIA=F%E9&ET;W(O4$L#! H``````%EQO"X```````````````!+````
> M;W)G+F5C;&EP<V4N=6DN97AA;7!L97,N:F%V865D:71O<B]O<F<O96-L:7!S
> M92]U:2]E>&%M<&QE<R]J879A961I=&]R+VIA=F$O4$L#!!0````(`%EQO "ZF
> M#&*S3 H``#,4``!G````;W)G+F5C;&EP<V4N=6DN97AA;7!L97,N:F%V865D
> M:71O<B]O<F<O96-L:7!S92]U:2]E>&%M<&QE<R]J879A961I=&]R+VIA=F$O
> M2F%V84%U=&]);F1E;G13=')A=&5G>2YC;&%S<Z57?7!4U17_W=VW^W;#4F+P
> M`8%L4;0AR096@RX:-$H6U-"04+%000LONV\WBYO==?>M@I4J-JUMU>)W!:T$
> M45,%6["2B!],[1_ME-8.3K_&*6UG.NWTG\ZT,_V8Z;0C_=W[7EYB2&HZ3 >:]
> M=]]]YYYS?N=WSKEW3WWPQDGXL0S'!3J*Y6S<2N5SI8H5K^;BUDYSH)2W*O$=
> MYAVFE<[9Q;(:QM?QMKIJ%[L*::M@;[3+IFUE=^D0`I=,U+$C8Z:LN&WMM.-K
> MK(Q9S=M3K?(+!*_*%7)VAX"_J7F3@)8LIJT(`@C60$-(8$YWKF#U5 ?ZK/)-
> M9E_>$JCK+J;,_":SG)/O[J1F]^<J`M=V_W] 5@DL2%4K=G$@=Y>UIIBJ#O!C
> MLC@P8!;2`NN;NJ?!V#4FNVHZB4G*5DFPC3.3U5'+..6M0M;N%Q!=$=1A;ACG
> MX7R)FPMD3!2HO%G(QHDE5\BNBF >YDNI!0+G685T97/.[E]CY7,#.=LJ"ZR<
> M"9ASM#9OB6 A%M7 AP:!^94!LVP[(5R=H=H>ZT[)5P0?QQPILYC^[@[A0H':
> MR:IT7$14UNU5,T_BC*8)MGK[=E@I6]GZ!!IK<#&6CMNJ6&7'5F?93-UFV1$T
> M.[9::(LD+?EH6!1,"4R+?S)5`A=\E$H=EPC,RUIVMY4U\S($7J05N.:M4Q'4
> MAA6S<"DN$PB-$30I$A.BGL!*&8DK6"FVI+PF/<'"W"GT$V6.8<OD "NGUIIWJ
> MYUQOR2JX82/^&21 5U=7<Q=MK=V9LDIVKEB@K=@TJSK-M*Q,*>6)ZU@M,%O&
> MA2'IS60JTK#61*41)+%&HE_+&J> ZU:R6"W,V+<M4LWUN$&RWS5NIUM52@2?
> M= QT,[QI=Q&-YRG!&%JRH.>E\L4*X^(:[RJDRI99X>= Q6:R$7B?_))RG-*I
> M/]EOEAT$R0ANPJ>E@4V.:9DN-+%6*EXZ(_^E^Y_!S=+]+0(1ZG"H4RIF%H*D
> MU'$+;I4Z/LL\R&4+Q;*5)"S+!47&!+4'^JQLKD K?<ZTBTE+5<L$))(<%E0K
> M"948$LD=>9$?:6?#^$S6<LN]-].M`CF3-M+5/%5VSI692:B]F<W]3..-):Z,
> MX#89#PUY4I25R3*OJ6NJY1$44)3!+PD@!$((W2FU*%K#*;)DIE2;JW4Q),>G
> MPJI.G6[*78<!O!,[I:Y=;$A%E:01?,YIL7<[F)WT[76_?=Y)K'OHW63'.JN9
> MC%76L6>:0MXD][8OU. ^#$;0@6LD;U^*((<=<O1E.F"62@I$ZU3+SYER[#$<
> M7\4#4NN#`HN:DO]5[FM2;B\#9A>=;P+G-TT9XD?PJ)1][,/=>U?%M@9T/,'@
> M%:MDR'"6YHKQ#5PG4]@R![CZZW@JC">Q3V#Q^$:[W"J7B^7E?69Z6]YM%MLN
> M#>%I@?;_9>=>J][76Y6*F;4J.K[AL#J&IW%&L:./!S!4@V=QD-DX!0@=AUCU
> M)3F1+T3P@B3N>;S(N=38D2#,SC*62X*YZ.^K9GB&F"[^7,JD=RI'LW:FN&+9
> M=/4S53]=]9'!; OAJ,"LLE7*4]--JJ1K-A:KY91U74Z>E!9-??)9+CW&A4Q"
> M#?*O!D*>PGC7^;:"3Q8:`BVC"!_CP$<!*>3CW>"2>9C%4<01XG,VGP(?PQQ7
> MP2!/FGX^$ZVOP=B/Q7S4?Q\+6F)R,(KH/D0X'L$%PS#JELC)$33M0UA-QL8 M
> MSJ-VH(%GD"@NXBDCCL6XG&Y+ZQ<X%ESK<M3*TZU0H^64]/&?9Q?7HP <I+74U
> MQD[@<H$>?T(;QMS698;6-H(K]R&@'1G4A*$M.WGP[)_\1SP/%C(H0!-UM-!.
> M# MH92''%]."].(R1ZOG1:/G12/:,9]:=/J\"E?1?@U77HVYC)\FFP&_74LY
> MC=*=RL<SM"6?/;&&$[C.AT2@)68$HOY1K#.T="(XC$L&?6 <;GD' =\03,0)R
> MN-Z'[5JZPPAZ*[8G@D;PZ;/O-8QC6:X\O@IA>C$?J^E-)^.:9#S7,+K7T?/K
> M<25NX'TUNK%.2=_@>.3AZ^&_@Z\'O<3B4Z,-'/G5Z%,*7QAK<2-'`=I9B8T<
> M!2G)O7LR9O%=RH0Y<[HA$?!+B.\0P EL)C1]," ,_; RBV_SDDPLX76(UU+W
> MV<*KR"NND(&-'-C+:S>OIQB*YU#R%(:,4&W+$.IDC+3MT5%L302&L8&S\2%T
> M1> 5+4BVY^D-+^+&5KM&;85PT&!0J=18:VGX8@\&SPYBC8F [HH]@FZ8@ >/'N-
> M$1R/>IGY"V[\?MQ,!%N(=BOC<0MS^U8>*;9Q9CO2,+D5IG 71WN08?WD<#]G
> M'D*>C76 /:N(@RBQ'54PC"I>QAUXA?O84>S"<:YZ'7?C3=R#'U#;NUPMF<LH
> MZZ<]YDY[S)U6W/C4:(RYT_3")"]^KN]3S 5QBAY)YN;B-?IED:\TJR[#48A>
> MS79'/GFH.2>71S@C^6IOD-&*QPS-"6A 5EE TK#(T!AJ8^R+#'/(T+3M1SA_
> M\.Q[T?$(-JH,V4O?'J;.1U"+1^G38\S?QXGH"1ZL'\85V*=0=SA6/=3M'NIV
> M9%W4[2YJ/W.S7^5K+?-*(@QPS,WY'#2'.)9Z5S3XGL=RM_8ZHN.5E]!:8E% #
> M&\% (L!!()H^@=O].%I7.3JIE1RBD>?IW M\?Y%MA$6-ER:XOL)S?87G^@JW
> MU&:S3&]4KB]D^FQ0KE],>5L1YI,GPW-<?TNU(*"M0>;W4B^S93X;P=I;AA!6
> MF3W;"!K:$()&X(C*X?<G$-"B[B.T.TH?7V>X3M#B&_3B+2;$VRS&DY09)9)W
> M)C2--@])FX>DS2.AS4N]-B:TI5(OKN@(4/]")KA%6YK\:>FT<''2;15GV,+O
> M$NC@MK';=P!Z=#^T8_(E.H2(?&KI8>ARD-!4=MTK\^Y-W'>SL_M\L3VHI)]#
> MN]R/=COIMWL(,5G(<L8_@OL3NJ'[AJ ;@81>+]NJ/H*OC."AS<-8HX(HNZ\N
> MY^4*27RH/L@W(V3H#OE2>.R[QH[\+&;5!VO#(WAX<VM]< 2/'T?],&K;M5>Q
> MO^Z9U_'<"(:/$>OY^ G_.]W8W\AWX$>,P(\9FW?Y=IK;T'O<!G]*F9^Q]'[.
> MF/Z"3>*7N!WOLWW\"@]P*WD*O\9A_(8L_1;?P^^H\?=<^0=^_:/BJ*3N9SR.
> MSG@<G<$WU?:I4_-+BJ,8L_9EE6V7L\QZ%4>=W%(/XP@YRI*M5SBGT^Y*E9\Z
> MK;>HK S1YBQ\B^U;;GK-'I?[72Y/N21&'$['F'3>)M/9$8LZ9#JT>COD& '<
> M\.1P"'=P5E-+QX@\@#Y2HQW 5ID'+ILR%4+UH9BSS B.TU8?<LXD#VUN59\"
> MZ>,P6HW <>QNK0^-43>G1S)W;)RY.M;"VQYSZ_@._)D_*_["T5\9W;_Q:/)W
> MUN<_L![_Q";\BTWGWV3M`_D#`D\*0A9^'!8:CHD`WA8AG!1A_%#,FM#03WF,
> MG?(8.^4RMHR-\&7%6(+;1Z]B[%INA<Y6O)Z<VZJAIYDU#F-[N&F^2A9IR >7)
> M3XW?497_VG\`4$L#!!0````(`#-QO"YYA2B4IPD``&LC``!F````;W)G+F5C
> M;&EP<V4N=6DN97AA;7!L97,N:F%V865D:71O<B]O<F<O96-L:7!S92]U:2]E
> M>&%M<&QE< R]J879A961I=&]R+VIA=F$O2F%V84%U=&]);F1E;G13=')A=& ;5G
> M>2YJ879AU5I+<]M&$CZ3OV*L2D6D)()2<I/,W;5D'[0E6ZY5JG*(4ZDA, "!A
> M`Q@L9D"9<?C?M[OG@0=!B;:4I)8'"QST=/?TX^N>IJ='S_L9LB-V)8MUF2R6
> MFHW",?OA]/3T!/_]D5U?OH6792%+KA.9,YY'3.JE*%6 ^UZE*:-]BI5"B7(E
> MHH#]M$P4*TJY*'E&&X">\3"46<'S=9(O6,:U*!.>*H9,>"E@)0*:%4]2/D\%
> MJ_)(E+0/"#/%9$Q?KF26@1+OJWF:A.PF"46N!%N=!:?(YWZ9A$LO*!$*]H F
> M4:)TF<PKU/^$]('%6A37N'>I=7$^G=[?WP<B3)-"B4"6BVDJ%CR=AD4Z69V=
> M!DN=I4AL+)8;KK)4Y[B GZZU)BS)$PT'9:_>7QO169&*3.2:"&#?\WZFPX*'
> MG_A",-#>GZ1*`O&9HV05?(23BR@!M>GQ8C@<@DZRU*T='V,>BD "+SSHX`I*I
> MB9)7<%HX403J,[ I.'&Q9@I\`&=<@:LDFY<@7F@*#M#%^"E,N5+LWR -&5S3
> M_CNW'42(/%+LM8AYE>H>BB_#X<!RZN<Q&@/-8#,<# ?3(S;*93Y!PDB&X^$`
> MU'XK]%)&+(+#0:A!_.;L>IL+DDZ]I)5,(A962LLL^5V\EF&%3L/X`R^.KMT "
> MBTY8YR4+29U!$D,N!:G(%WK)9C-VRK[_GH5D4_9BQO(*4@=6\/ _)WKY6J1)
> MED"TCX"E(1N#^H.!RGBIC:JO8GC_3MS?)+D@LO$%4(@4<@"E'6P.`O'?"M)J
> MY!BP+VPZ_>[=[;O)NYN[R=EW#8:0K8;AI?%9S7#CC7E$]ON/T%69*\@O@9D/
> M@<)RJ6UVPFG(?_=P!K"L<*FZ@(C((3AX"3F)"9@O("JLC<MD!39G<RE3P?,>
> M&[0,?$>[F88#43 ,S,(OOX)+[08U8U&P$/H&\Q7-XUFI$9P)]L2@]2@!A@FX
> MXH(E[&5CMW43+!\?&^^1^T!BX'0;U=2_)+\:UPQ*L@S3926,X89^+08WX&*O
> M)=% *6@)49#-T:+&9CE:TZ80X^@;- U9C?VKW&,OX&JX1%MM,3$\"HZ0'#G;
> M3FBG_SH7N!5HE&C1D[1)+1CR7&F((>M=D@?B6%S*K+D/Q-IM^%1(A G(/=QN
> MPJ)W5Y@"8;ZP47F=AZ7@RLFOS^R0AMA]2@H;6EAWM @UI#DZ.P:T>FN-<EN(
> MW,5Z([[LPPG1X_G,$ZAL'OKU&8,ZI;Q7[))'-S(D-'_S.10%'9& B- "&4!#O-
> MO! *41!Q&\<*M$!IE'%(2@<*994#/9!9>5>X,*J5)(8G1CL*L3%8IE]% "OOI
> ME*DJ8U5!YO-&(SE45@4'1Y!;1Y9-APHB:\$1WT^8X2?!CA0HTN#^&*JU3E)V
> M+\C<C-LH(7F8]O1H>(&S?A>E!$90K*'XCNI30T*>VMS#_9/)A4M#8E >_=1DV
> M.2.*#6':?G8>@-UF-GB/MZAO" 0,-5C5L&\H>/QUCK%0ZM1%M@_A@4O9" target="_blank">>@4O9%4\K
> M0E$.:1)2.&&*8REF5UT/+3G475[OF9Q1ET',T4^[*<_^=E@Q;C#$YME#!((U
> M+1-.[($INS<DBUR6`@TG+ITM)ENE3%HZMI4#25Z';XTQIGYAVG8C8A>RV/CP
> MT.)J7X]^>V++7"Q .1O.+101VN+(Z44CTXC\)4JWB10N>0D]3EFV$^<*E@VU
> MR1EZ/#ZF9P5E'O!BA+M<.H8(SX?30W9.7REEMX4Y>1A0#\NS+"CRH&\Z/#JL
> M62#^<'!&E@EG4P4]?;3B>4B%R?C*O*;X-!]B3^E[95Z^@2ZN=I!
Re: examples.javaeditor package source doesn't work? :( [message #53102 is a reply to message #53012] |
Thu, 29 May 2003 01:03   |
I totally forgetted to ask you to search the error you are getting at
eclipse search page,someone else might had this problem,this might give
you a clue about it.
Syed
> Syed
> Alexandre wrote:
> > Hi,
went
> > Thanks.
> > Alex
create
> > > Syed
> > > Alexandre wrote:
> > > > Hi thanks.
> > I've
> > be
> > > > Files/eclipse/
> > class
> > > > !STACK 0
> > > > at
> > > > at
> > > > at
> > > > at
> > > > at
> > > > at
> > > > at
> > > > :155)
> > > > at
> > > > :889)
> > > > at
> > > > at
> > > > 661)
> > > > at
> > > > at
> > > > :889)
> > > > at
> > > > 64)
> > > > at
> > > > at
> > > > at
> > > > at
> > > > at
> > > > 27)
> > > > at
> > > > :889)
> > > > at
> > > > 1093)
> > > > at
> > > > a:845)
> > > > at
> > > > at
> > > > ..java:25)
> > > > !STACK 1
> > > > at
> > > > at
> > > > at
> > > > at
> > > > at
> > > > at
> > > > at
> > > > :155)
> > > > at
> > > > :889)
> > > > at
> > > > at
> > > > 661)
> > > > at
> > > > at
> > > > :889)
> > > > at
> > > > 64)
> > > > at
> > > > at
> > > > at
> > > > at
> > > > at
> > > > 27)
> > > > at
> > > > :889)
> > > > at
> > > > 1093)
> > > > at
> > > > a:845)
> > > > at
> > > > at
> > > > ..java:25)
> > class
> > > > !STACK 0
> > > > at
> > > > at
> > > > at
> > > > at
> > > > at
> > > > at
> > > > at
> > > > :155)
> > > > at
> > > > :889)
> > > > at
> > > > at
> > > > 661)
> > > > at
> > > > at
> > > > :889)
> > > > at
> > > > 64)
> > > > at
> > > > at
> > > > at
> > > > at
> > > > at
> > > > 27)
> > > > at
> > > > :889)
> > > > at
> > > > 1093)
> > > > at
> > > > a:845)
> > > > at
> > > > at
> > > > ..java:25)
> > class
> > > > !STACK 0
> > > > at
> > > > at
> > > > at
> > > > at
> > > > at
> > > > at
> > > > at
> > > > :155)
> > > > at
> > > > :889)
> > > > at
> > > > at
> > > > 661)
> > > > at
> > > > at
> > > > :889)
> > > > at
> > > > 64)
> > > > at
> > > > at
> > > > at
> > > > at
> > > > at
> > > > 27)
> > > > at
> > > > :889)
> > > > at
> > > > 1093)
> > > > at
> > > > a:845)
> > > > at
> > > > at
> > > > ..java:25)
> > Plug-in
> > class
> > > > !STACK 0
> > > > at
> > > > at
> > > > at
> > > > at
> > > > at
> > > > at
> > > > at
> > > > :155)
> > > > at
> > > > :889)
> > > > at
> > > > at
> > > > 661)
> > > > at
> > > > ..java:459)
> > > > at
> > > > at
> > > > at
> > > > at
> > > > at
> > > > at
> > > > at
> > > > at
> > > > at
> > > > at
> > > > at
> > > > a:845)
> > > > at
> > > > at
> > > > ..java:25)
> > > > !STACK 1
> > > > at
> > > > at
> > > > at
> > > > at
> > > > at
> > > > at
> > > > at
> > > > :155)
> > > > at
> > > > :889)
> > > > at
> > > > at
> > > > 661)
> > > > at
> > > > ..java:459)
> > > > at
> > > > at
> > > > at
> > > > at
> > > > at
> > > > at
> > > > at
> > > > at
> > > > at
> > > > at
> > > > at
> > > > a:845)
> > > > at
> > > > at
> > > > ..java:25)
> > class
> > > > !STACK 0
> > > > at
> > > > at
> > > > at
> > > > at
> > > > at
> > > > at
> > > > at
> > > > :155)
> > > > at
> > > > :889)
> > > > at
> > > > at
> > > > 661)
> > > > at
> > > > ..java:459)
> > > > at
> > > > at
> > > > at
> > > > at
> > > > at
> > > > at
> > > > at
> > > > at
> > > > at
> > > > at
> > > > at
> > > > a:845)
> > > > at
> > > > at
> > > > ..java:25)
> > class
> > > > !STACK 0
> > > > at
> > > > at
> > > > at
> > > > at
> > > > at
> > > > at
> > > > at
> > > > :155)
> > > > at
> > > > :889)
> > > > at
> > > > at
> > > > 661)
> > > > at
> > > > ..java:459)
> > > > at
> > > > at
> > > > at
> > > > at
> > > > at
> > > > at
> > > > at
> > > > at
> > > > at
> > > > at
> > > > at
> > > > a:845)
> > > > at
> > > > at
> > > > ..java:25)
> > > > > error.
> > > > > cheers
> > > > > Syed
> > > > > Alexandre wrote:
> > > > > > Hi,
> > have
> > named,
> > > > and
> > source
> > > > and
> > All
> > > > seems
> > I
> > > > try to
> > > > error:
> > > > Plug-in
> > > > through
> > > > > > Alex
> > M1>
Re: examples.javaeditor package source doesn't work? :( [message #53198 is a reply to message #53102] |
Thu, 29 May 2003 01:29   |
Well,
if I DL the plugin and just put it in the plugins directory, it works
fine. The idea is to put the source into the workspace so that I can edit
it and then see what it does by running as 'run-time workbench'. That's the
correct way of going about things right?
news:bb44ba$bmf$1@rogue.oti.com...
> Syed
on.
> > Syed
> > Alexandre wrote:
> > > Hi,
operate.
even
> went
something
> > > Thanks.
> > > Alex
it is
> create
in it
project,also
to
> > > > Syed
> > > > Alexandre wrote:
> > > > > Hi thanks.
so
> > > I've
seem to
> > > be
run-time
test
file:C:/Program
> > > > > Files/eclipse/
load
> > > class
> > > > > !STACK 0
> > > > > at
> > > > > at
> > > > > at
> > > > > at
> > > > > at
> > > > > at
> > > > > at
> > > > > :155)
> > > > > at
> > > > > at
> > > > > :889)
> > > > > at
> > > > > at
> > > > > 661)
> > > > > at
> > > > > at
> > > > > at
> > > > > :889)
> > > > > at
> > > > > 64)
> > > > > at
> > > > > at
> > > > > at
> > > > > at
> > > > > at
> > > > > at
> > > > > 27)
> > > > > at
> > > > > at
> > > > > at
> > > > > :889)
> > > > > at
> > > > > 1093)
> > > > > at
> > > > > a:845)
> > > > > at
> > > > > at
> > > > > ..java:25)
> > > > > !STACK 1
> > > > > at
> > > > > at
> > > > > at
> > > > > at
> > > > > at
> > > > > at
> > > > > at
> > > > > :155)
> > > > > at
> > > > > at
> > > > > :889)
> > > > > at
> > > > > at
> > > > > 661)
> > > > > at
> > > > > at
> > > > > at
> > > > > :889)
> > > > > at
> > > > > 64)
> > > > > at
> > > > > at
> > > > > at
> > > > > at
> > > > > at
> > > > > at
> > > > > 27)
> > > > > at
> > > > > at
> > > > > at
> > > > > :889)
> > > > > at
> > > > > 1093)
> > > > > at
> > > > > a:845)
> > > > > at
> > > > > at
> > > > > ..java:25)
load
> > > class
> > > > > !STACK 0
> > > > > at
> > > > > at
> > > > > at
> > > > > at
> > > > > at
> > > > > at
> > > > > at
> > > > > :155)
> > > > > at
> > > > > at
> > > > > :889)
> > > > > at
> > > > > at
> > > > > 661)
> > > > > at
> > > > > at
> > > > > at
> > > > > :889)
> > > > > at
> > > > > 64)
> > > > > at
> > > > > at
> > > > > at
> > > > > at
> > > > > at
> > > > > at
> > > > > 27)
> > > > > at
> > > > > at
> > > > > at
> > > > > :889)
> > > > > at
> > > > > 1093)
> > > > > at
> > > > > a:845)
> > > > > at
> > > > > at
> > > > > ..java:25)
load
> > > class
> > > > > !STACK 0
> > > > > at
> > > > > at
> > > > > at
> > > > > at
> > > > > at
> > > > > at
> > > > > at
> > > > > :155)
> > > > > at
> > > > > at
> > > > > :889)
> > > > > at
> > > > > at
> > > > > 661)
> > > > > at
> > > > > at
> > > > > at
> > > > > :889)
> > > > > at
> > > > > 64)
> > > > > at
> > > > > at
> > > > > at
> > > > > at
> > > > > at
> > > > > at
> > > > > 27)
> > > > > at
> > > > > at
> > > > > at
> > > > > :889)
> > > > > at
> > > > > 1093)
> > > > > at
> > > > > a:845)
> > > > > at
> > > > > at
> > > > > ..java:25)
> > > Plug-in
load
> > > class
> > > > > !STACK 0
> > > > > at
> > > > > at
> > > > > at
> > > > > at
> > > > > at
> > > > > at
> > > > > at
> > > > > :155)
> > > > > at
> > > > > at
> > > > > :889)
> > > > > at
> > > > > at
> > > > > 661)
> > > > > at
> > > > > ..java:459)
> > > > > at
> > > > > at
> > > > > at
> > > > > at
> > > > > at
> > > > > at
> > > > > at
> > > > > at
> > > > > at
> > > > > at
> > > > > at
> > > > > at
> > > > > at
> > > > > at
> > > > > at
> > > > > a:845)
> > > > > at
> > > > > at
> > > > > ..java:25)
> > > > > !STACK 1
> > > > > at
> > > > > at
> > > > > at
> > > > > at
> > > > > at
> > > > > at
> > > > > at
> > > > > :155)
> > > > > at
> > > > > at
> > > > > :889)
> > > > > at
> > > > > at
> > > > > 661)
> > > > > at
> > > > > ..java:459)
> > > > > at
> > > > > at
> > > > > at
> > > > > at
> > > > > at
> > > > > at
> > > > > at
> > > > > at
> > > > > at
> > > > > at
> > > > > at
> > > > > at
> > > > > at
> > > > > at
> > > > > at
> > > > > a:845)
> > > > > at
> > > > > at
> > > > > ..java:25)
load
> > > class
> > > > > !STACK 0
> > > > > at
> > > > > at
> > > > > at
> > > > > at
> > > > > at
> > > > > at
> > > > > at
> > > > > :155)
> > > > > at
> > > > > at
> > > > > :889)
> > > > > at
> > > > > at
> > > > > 661)
> > > > > at
> > > > > ..java:459)
> > > > > at
> > > > > at
> > > > > at
> > > > > at
> > > > > at
> > > > > at
> > > > > at
> > > > > at
> > > > > at
> > > > > at
> > > > > at
> > > > > at
> > > > > at
> > > > > at
> > > > > at
> > > > > a:845)
> > > > > at
> > > > > at
> > > > > ..java:25)
load
> > > class
> > > > > !STACK 0
> > > > > at
> > > > > at
> > > > > at
> > > > > at
> > > > > at
> > > > > at
> > > > > at
> > > > > :155)
> > > > > at
> > > > > at
> > > > > :889)
> > > > > at
> > > > > at
> > > > > 661)
> > > > > at
> > > > > ..java:459)
> > > > > at
> > > > > at
> > > > > at
> > > > > at
> > > > > at
> > > > > at
> > > > > at
> > > > > at
> > > > > at
> > > > > at
> > > > > at
> > > > > at
> > > > > at
> > > > > at
> > > > > at
> > > > > a:845)
> > > > > at
> > > > > at
> > > > > ..java:25)
pinpoint the
> > > > > > error.
> > > > > > cheers
> > > > > > Syed
> > > > > > Alexandre wrote:
> > > > > > > Hi,
eclipse.org,
> > > have
properly
> > > named,
> > > > > and
its
> > > source
> > > > > and
hurdle!
> > > All
> > > > > seems
when
> > > I
> > > > > try to
this
> > > > > error:
> > > > > Plug-in
gone
> > > > > through
> > > > > > > Alex
Re: examples.javaeditor package source doesn't work? :( [message #53737 is a reply to message #53198] |
Thu, 29 May 2003 07:57   |
So what I understand is that you really want to run the example in debug
mode.That can be done after it is running properly.You can do that by
having breakpoint in places where you want to see which method is being
called and how and which varaibles are being called.
Secondly I didn't get what does this mean "if I DL the plugin and just put
it in the plugins directory, it works fine."
Can you explain more in detail what are you doing differently to run your
tests.
Syed
Alexandre wrote:
> Well,
> > Syed
> on.
> > > Syed
> > > Alexandre wrote:
> > > > Hi,
> operate.
> even
> > went
> something
> > > > Thanks.
> > > > Alex
> it is
> > create
> in it
> project,also
> to
> > > > > Syed
> > > > > Alexandre wrote:
> > > > > > Hi thanks.
> so
> > > > I've
> seem to
> > > > be
> run-time
> test
> file:C:/Program
> > > > > > Files/eclipse/
> load
> > > > class
> > > > > > !STACK 0
> > > > > > at
> > > > > > at
> > > > > > at
> > > > > > at
> > > > > > at
> > > > > > at
> > > > > > at
> > > > > > :155)
> > > > > > at
> > > > > > at
> > > > > > :889)
> > > > > > at
> > > > > > at
> > > > > > 661)
> > > > > > at
> > > > > > at
> > > > > > at
> > > > > > :889)
> > > > > > at
> > > > > > 64)
> > > > > > at
> > > > > > at
> > > > > > at
> > > > > > at
> > > > > > at
> > > > > > at
> > > > > > 27)
> > > > > > at
> > > > > > at
> > > > > > at
> > > > > > :889)
> > > > > > at
> > > > > > 1093)
> > > > > > at
> > > > > > a:845)
> > > > > > at
> > > > > > at
> > > > > > ..java:25)
> > > > > > !STACK 1
> > > > > > at
> > > > > > at
> > > > > > at
> > > > > > at
> > > > > > at
> > > > > > at
> > > > > > at
> > > > > > :155)
> > > > > > at
> > > > > > at
> > > > > > :889)
> > > > > > at
> > > > > > at
> > > > > > 661)
> > > > > > at
> > > > > > at
> > > > > > at
> > > > > > :889)
> > > > > > at
> > > > > > 64)
> > > > > > at
> > > > > > at
> > > > > > at
> > > > > > at
> > > > > > at
> > > > > > at
> > > > > > 27)
> > > > > > at
> > > > > > at
> > > > > > at
> > > > > > :889)
> > > > > > at
> > > > > > 1093)
> > > > > > at
> > > > > > a:845)
> > > > > > at
> > > > > > at
> > > > > > ..java:25)
> load
> > > > class
> > > > > > !STACK 0
> > > > > > at
> > > > > > at
> > > > > > at
> > > > > > at
> > > > > > at
> > > > > > at
> > > > > > at
> > > > > > :155)
> > > > > > at
> > > > > > at
> > > > > > :889)
> > > > > > at
> > > > > > at
> > > > > > 661)
> > > > > > at
> > > > > > at
> > > > > > at
> > > > > > :889)
> > > > > > at
> > > > > > 64)
> > > > > > at
> > > > > > at
> > > > > > at
> > > > > > at
> > > > > > at
> > > > > > at
> > > > > > 27)
> > > > > > at
> > > > > > at
> > > > > > at
> > > > > > :889)
> > > > > > at
> > > > > > 1093)
> > > > > > at
> > > > > > a:845)
> > > > > > at
> > > > > > at
> > > > > > ..java:25)
> load
> > > > class
> > > > > > !STACK 0
> > > > > > at
> > > > > > at
> > > > > > at
> > > > > > at
> > > > > > at
> > > > > > at
> > > > > > at
> > > > > > :155)
> > > > > > at
> > > > > > at
> > > > > > :889)
> > > > > > at
> > > > > > at
> > > > > > 661)
> > > > > > at
> > > > > > at
> > > > > > at
> > > > > > :889)
> > > > > > at
> > > > > > 64)
> > > > > > at
> > > > > > at
> > > > > > at
> > > > > > at
> > > > > > at
> > > > > > at
> > > > > > 27)
> > > > > > at
> > > > > > at
> > > > > > at
> > > > > > :889)
> > > > > > at
> > > > > > 1093)
> > > > > > at
> > > > > > a:845)
> > > > > > at
> > > > > > at
> > > > > > ..java:25)
> > > > Plug-in
> load
> > > > class
> > > > > > !STACK 0
> > > > > > at
> > > > > > at
> > > > > > at
> > > > > > at
> > > > > > at
> > > > > > at
> > > > > > at
> > > > > > :155)
> > > > > > at
> > > > > > at
> > > > > > :889)
> > > > > > at
> > > > > > at
> > > > > > 661)
> > > > > > at
> > > > > > ..java:459)
> > > > > > at
> > > > > > at
> > > > > > at
> > > > > > at
> > > > > > at
> > > > > > at
> > > > > > at
> > > > > > at
> > > > > > at
> > > > > > at
> > > > > > at
> > > > > > at
> > > > > > at
> > > > > > at
> > > > > > at
> > > > > > a:845)
> > > > > > at
> > > > > > at
> > > > > > ..java:25)
> > > > > > !STACK 1
> > > > > > at
> > > > > > at
> > > > > > at
> > > > > > at
> > > > > > at
> > > > > > at
> > > > > > at
> > > > > > :155)
> > > > > > at
> > > > > > at
> > > > > > :889)
> > > > > > at
> > > > > > at
> > > > > > 661)
> > > > > > at
> > > > > > ..java:459)
> > > > > > at
> > > > > > at
> > > > > > at
> > > > > > at
> > > > > > at
> > > > > > at
> > > > > > at
> > > > > > at
> > > > > > at
> > > > > > at
> > > > > > at
> > > > > > at
> > > > > > at
> > > > > > at
> > > > > > at
> > > > > > a:845)
> > > > > > at
> > > > > > at
> > > > > > ..java:25)
> load
> > > > class
> > > > > > !STACK 0
> > > > > > at
> > > > > > at
> > > > > > at
> > > > > > at
> > > > > > at
> > > > > > at
> > > > > > at
> > > > > > :155)
> > > > > > at
> > > > > > at
> > > > > > :889)
> > > > > > at
> > > > > > at
> > > > > > 661)
> > > > > > at
> > > > > > ..java:459)
> > > > > > at
> > > > > > at
> > > > > > at
> > > > > > at
> > > > > > at
> > > > > > at
> > > > > > at
> > > > > > at
> > > > > > at
> > > > > > at
> > > > > > at
> > > > > > at
> > > > > > at
> > > > > > at
> > > > > > at
> > > > > > a:845)
> > > > > > at
> > > > > > at
> > > > > > ..java:25)
> load
> > > > class
> > > > > > !STACK 0
> > > > > > at
> > > > > > at
> > > > > > at
> > > > > > at
> > > > > > at
> > > > > > at
> > > > > > at
> > > > > > :155)
> > > > > > at
> > > > > > at
> > > > > > :889)
> > > > > > at
> > > > > > at
> > > > > > 661)
> > > > > > at
> > > > > > ..java:459)
> > > > > > at
> > > > > > at
> > > > > > at
> > > > > > at
> > > > > > at
> > > > > > at
> > > > > > at
> > > > > > at
> > > > > > at
> > > > > > at
> > > > > > at
> > > > > > at
> > > > > > at
> > > > > > at
> > > > > > at
> > > > > > a:845)
> > > > > > at
Re: examples.javaeditor package source doesn't work? :( [message #54291 is a reply to message #53737] |
Thu, 29 May 2003 12:19   |
Basically,
in the 5th message previous to this one I've placed a file attachment
that contains the files I am using as a workspace package. The directory
contents in those files contain the example's source moved into a java
project along with its plugin.xml file.
I would like to be able to have the source for the javaeditor plug-in
inside my workspace that I can tinker with it and then be able to use a
'run-time workbench' to examine the changes I've made and their results.
It however doesn't work. If you put those files in your workspace and
install the package with correct name and the refresh, the package will
appear in your workspace inside of eclipse. If you select 'run as run-time
workbench' you'll see that in your rtwb, there'll be the editor available
for .jav files as promised by the plugin source yet when you try to use it,
it generates the errors I've noted earlier.
All I want to do is run the example's source!! Not the plugin! :(
Cheers.
A.
news:bb4sis$r01$1@rogue.oti.com...
> tests.
> Syed
> Alexandre wrote:
> > Well,
works
edit
the
give
> > > Syed
this
an
import
from
later
> > on.
> > > > Syed
> > > > Alexandre wrote:
> > > > > Hi,
difficulty
learn
> > operate.
> > even
> > > went
> > something
> > > > > Thanks.
> > > > > Alex
what
> > it is
you
> > > create
downloaded
files
> > in it
> > project,also
get
> > to
is
> > > > > > Syed
> > > > > > Alexandre wrote:
> > > > > > > Hi thanks.
required,
> > so
> > > > > I've
> > seem to
> > > > > be
> > run-time
java
> > test
file:C:/Program
> > file:C:/Program
> > > > > > > Files/eclipse/
to
> > load
> > > > > class
> > > > > > > !STACK 0
> > > > > > > at
> > > > > > > at
> > > > > > > at
> > > > > > > at
> > > > > > > at
> > > > > > > at
> > > > > > > at
> > > > > > > :155)
> > > > > > > at
> > > > > > > at
> > > > > > > :889)
> > > > > > > at
> > > > > > > at
> > > > > > > 661)
> > > > > > > at
> > > > > > > at
> > > > > > > at
> > > > > > > :889)
> > > > > > > at
> > > > > > > 64)
> > > > > > > at
> > > > > > > at
> > > > > > > at
> > > > > > > at
> > > > > > > at
> > > > > > > at
> > > > > > > 27)
> > > > > > > at
> > > > > > > at
> > > > > > > at
> > > > > > > at
> > > > > > > :889)
> > > > > > > at
> > > > > > > 1093)
> > > > > > > at
> > > > > > > a:845)
Method)
> > > > > > > at
> > > > > > > at
> > > > > > > ..java:25)
> > > > > > > !STACK 1
> > > > > > > at
> > > > > > > at
> > > > > > > at
> > > > > > > at
> > > > > > > at
> > > > > > > at
> > > > > > > at
> > > > > > > :155)
> > > > > > > at
> > > > > > > at
> > > > > > > :889)
> > > > > > > at
> > > > > > > at
> > > > > > > 661)
> > > > > > > at
> > > > > > > at
> > > > > > > at
> > > > > > > :889)
> > > > > > > at
> > > > > > > 64)
> > > > > > > at
> > > > > > > at
> > > > > > > at
> > > > > > > at
> > > > > > > at
> > > > > > > at
> > > > > > > 27)
> > > > > > > at
> > > > > > > at
> > > > > > > at
> > > > > > > at
> > > > > > > :889)
> > > > > > > at
> > > > > > > 1093)
> > > > > > > at
> > > > > > > a:845)
Method)
> > > > > > > at
> > > > > > > at
> > > > > > > ..java:25)
to
> > load
> > > > > class
> > > > > > > !STACK 0
> > > > > > > at
> > > > > > > at
> > > > > > > at
> > > > > > > at
> > > > > > > at
> > > > > > > at
> > > > > > > at
> > > > > > > :155)
> > > > > > > at
> > > > > > > at
> > > > > > > :889)
> > > > > > > at
> > > > > > > at
> > > > > > > 661)
> > > > > > > at
> > > > > > > at
> > > > > > > at
> > > > > > > :889)
> > > > > > > at
> > > > > > > 64)
> > > > > > > at
> > > > > > > at
> > > > > > > at
> > > > > > > at
> > > > > > > at
> > > > > > > at
> > > > > > > 27)
> > > > > > > at
> > > > > > > at
> > > > > > > at
> > > > > > > at
> > > > > > > :889)
> > > > > > > at
> > > > > > > 1093)
> > > > > > > at
> > > > > > > a:845)
Method)
> > > > > > > at
> > > > > > > at
> > > > > > > ..java:25)
14:10:57.812
to
> > load
> > > > > class
> > > > > > > !STACK 0
> > > > > > > at
> > > > > > > at
> > > > > > > at
> > > > > > > at
> > > > > > > at
> > > > > > > at
> > > > > > > at
> > > > > > > :155)
> > > > > > > at
> > > > > > > at
> > > > > > > :889)
> > > > > > > at
> > > > > > > at
> > > > > > > 661)
> > > > > > > at
> > > > > > > at
> > > > > > > at
> > > > > > > :889)
> > > > > > > at
> > > > > > > 64)
> > > > > > > at
> > > > > > > at
> > > > > > > at
> > > > > > > at
> > > > > > > at
> > > > > > > at
> > > > > > > 27)
> > > > > > > at
> > > > > > > at
> > > > > > > at
> > > > > > > at
> > > > > > > :889)
> > > > > > > at
> > > > > > > 1093)
> > > > > > > at
> > > > > > > a:845)
Method)
> > > > > > > at
> > > > > > > at
> > > > > > > ..java:25)
editor:
> > > > > Plug-in
to
> > load
> > > > > class
> > > > > > > !STACK 0
> > > > > > > at
> > > > > > > at
> > > > > > > at
> > > > > > > at
> > > > > > > at
> > > > > > > at
> > > > > > > at
> > > > > > > :155)
> > > > > > > at
> > > > > > > at
> > > > > > > :889)
> > > > > > > at
> > > > > > > at
> > > > > > > 661)
> > > > > > > at
> > > > > > > ..java:459)
> > > > > > > at
> > > > > > > at
> > > > > > > at
> > > > > > > at
> > > > > > > at
> > > > > > > at
> > > > > > > at
> > > > > > > at
> > > > > > > at
> > > > > > > at
> > > > > > > at
> > > > > > > at
> > > > > > > at
> > > > > > > at
> > > > > > > at
> > > > > > > a:845)
Method)
> > > > > > > at
> > > > > > > at
> > > > > > > ..java:25)
> > > > > > > !STACK 1
> > > > > > > at
> > > > > > > at
> > > > > > > at
> > > > > > > at
> > > > > > > at
> > > > > > > at
> > > > > > > at
> > > > > > > :155)
> > > > > > > at
> > > > > > > at
> > > > > > > :889)
> > > > > > > at
> > > > > > > at
> > > > > > > 661)
> > > > > > > at
> > > > > > > ..java:459)
> > > > > > > at
> > > > > > > at
> > > > > > > at
> > > > > > > at
> > > > > > > at
> > > > > > > at
> > > > > > > at
> > > > > > > at
> > > > > > > at
> > > > > > > at
> > > > > > > at
> > > > > > > at
> > > > > > > at
> > > > > > > at
> > > > > > > at
> > > > > > > a:845)
Method)
> > > > > > > at
> > > > > > > at
> > > > > > > ..java:25)
to
> > load
> > > > > class
> > > > > > > !STACK 0
> > > > > > > at
> > > > > > > at
> > > > > > > at
> > > > > > > at
> > > > > > > at
> > > > > > > at
> > > > > > > at
> > > > > > > :155)
> > > > > > > at
> > > > > > > at
> > > > > > > :889)
> > > > > > > at
> > > > > > > at
> > > > > > > 661)
> > > > > > > at
> > > > > > > ..java:459)
> > > > > > > at
> > > > > > > at
> > > > > > > at
> > > > > > > at
> > > > > > > at
> > > > > > > at
> > > > > > > at
> > > > > > > at
> > > > > > > at
> > > > > > > at
> > > > > > > at
> > > > > > > at
> > > > > > > at
All I want to do is run the example's source!! Not the plugin! :( [message #55106 is a reply to message #54291] |
Thu, 29 May 2003 20:12  |
I am sure that you need to run the java editor as an application,because
what you mentioned in the end of the post clearly shows that and you can't
run the example source in runtime workbench as it is a test environment
for plugins,so you are better off changing the plugin into a
application.To best of my knowledge any code source without the plugin.xml
is an application.
I think you should ask another question in the newsgroup but with a
different topic.My experience in teh newsgroup is that your topic heading
is what get your question answered.
I wish I could help you more.
Syed
Current Time: Fri Jul 25 04:47:53 EDT 2025
Powered by FUDForum. Page generated in 0.08345 seconds
