Can't seem to break in around advice [message #52255] |
Wed, 25 May 2005 11:20  |
In the following code, I set a breakpoint at the first line in the around advice. The advice gets executed, but the breakpoint never hits:
void around() : log4jLoggingInit() {
PropertyConfigurator.configureAndWatch("log4j.properties", 1000);
If I change the advice to invoke a method, and set the breakpoint on the first line of the method, the breakpoint /does/ get hit:
initLogging();
private void initLogging() {
Has anyone else experienced similar problems?
-barry
Re: Can't seem to break in around advice [message #52284 is a reply to message #52255] |
Wed, 25 May 2005 12:06   |
Originally posted by: mchapman.uk.ibm.com
Hi Barry,
Your around advice is being inlined. You can disable this optimization
under AspectJ Compiler > Advanced > No inline
Matt.
> 1000);
> initLogging();
> 1000);
> -barry
Re: Can't seem to break in around advice [message #588396 is a reply to message #52255] |
Hi Barry,
Matt.
> 1000);
> initLogging();
> 1000);
> -barry
FUDForum. Page generated in 0.07741 seconds
