Home » Modeling » TMF (Xtext) » getting link name after link resolution failure
getting link name after link resolution failure [message #52248] Thu, 18 June 2009 16:48 Go to next message
[I guess this falls in to the general "error recovery" theme... :)]
Suppose we've got this grammar and input:
Foo: 'foo' name=ID
Bar: 'bar' name=ID 'using' foo=[Foo] ;
bar MyBar using NoSuchFoo
Looks like MyBar.getFoo() would return a Foo, but there's no such Foo
named "NoSuchFoo." Presumably it returns null. Is there a way to fetch
the string "NoSuchFoo" from object MyBaz in this case?
Shane
Re: getting link name after link resolution failure [message #52356 is a reply to message #52248] Fri, 19 June 2009 01:23 Go to previous message
Hi Shane,
You can get the string from the parse tree. I think what you want is
essentially a combination of what the methods NodeUtil#findNodesForFeature
and DefaultLinkingService#getCrossRefNodeAsString do. The former (static
method) gives you back a list of all parse tree nodes corresponding to the
given feature. (This list will contain a single value in the case of a
single valued feature.) The latter method (not static, so you may have to
copy it for now) extracts the string you want from a parse tree node. Note
that the latter method also depends on the Guice injected value converter
service.
In oAW there used to be a "parsedString" method for this purpose. I think
it would be a good idea to provide this as a utility in TMF Xtext. Could
you add an enhancement request to Bugzilla?
--knut
> Foo: 'foo' name=ID
> Shane
Previous Topic:I have a problem with grammar
Next Topic:New Xtext webpage
Current Time: Tue Jul 22 02:43:17 EDT 2025
Powered by FUDForum. Page generated in 0.04477 seconds
