Re: [Teneo + GMF + EMF Validation] EMF validation set to console, still a dialog appears. [message #516850 is a reply to message #516650] |
Thu, 25 February 2010 11:20   |
Martin Taal Messages: 5468 Registered: July 2009 |
Hi Christophe,
I don't know the specifics of when a dialog or when validation is shown in the console. Assuming that the exception is
expected then I would say that it is not caught at the correct place and therefore forces a dialog. But again, I have
practically no knowledge of the program flow (and the validation ui) so I can't really comment...
If the exception itself is not correct (i.e. it should not happen) then I would need to get more details to comment
(what does it fail, what is that stacktrace, what is the message).
gr. Martin
Christophe Bouhier wrote:
> Hi there,
> I have set a couple of audits on a diagram, which has a semantic model
> persisted using Teneo. I have also included the EMF Validation Ui
> plugin, which allows me to set the output to be console instead of a
> dialog box.
> Now when saving the diagram, my diagram gets validated and I still get a
> dialog instead of console output when the constraint fails.
> I also get the teneo exception:
> org.eclipse.emf.teneo.StoreValidationException
> However when I edit from the Properties View, I do get live validation
> on the console.
> So is this dialog from GMF or is it the Teneo exception, which forces
> the UI to give the dialog? (I would suspect the latter).
> Thanks Christophe
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [Teneo + GMF + EMF Validation] EMF validation set to console, still a dialog appears. [message #516917 is a reply to message #516850] |
Thu, 25 February 2010 14:12  |
Christophe Bouhier Messages: 937 Registered: July 2009 |
Hi Martin,
See my comment below, and thank you for your swift response.
Martin Taal wrote:
> Hi Christophe,
> in the console. Assuming that the exception is expected then I would say
> dialog.
Excellent point, the exception is expected as it is a constraint I have
set on a model element. The issue might be that EMF life Validation is
actually not executed when saving the diagram (As it is normally forced
by the action Edit->Validation), but Teneo executes the validation and
throws the exception.
But again, I have practically no knowledge of the program flow
Same here :).
> I would need to get more details to comment (what does it fail, what is
It is correct, I would be nice to hear from the GMF experts what
validation cycle happens when saving a diagram.
Dank je!
Christophe
FUDForum. Page generated in 0.06692 seconds
