Home » Archived » BIRT » parameter marker not possible on a computed column?
parameter marker not possible on a computed column? [message #52140] Tue, 28 June 2005 09:23 Go to next message
Originally posted by: no.spam.com
I have a computed column that I've created in a data set. Can one not set
a parameter marker in the SQL, utilizing that computed column? I am
getting errors all over the place when trying that....
Re: parameter marker not possible on a computed column? [message #52216 is a reply to message #52140] Tue, 28 June 2005 09:48 Go to previous messageGo to next message
It appears now, due to sequence. I guess I am very confused then, as to
how a user can enter info at runtime, to filter the report -- unless what
they enter matches one of the original fields. This would seem to be a
big limitation, if its correct....
Has anyone had run-time filtering of reports, based on computed column
data?
Re: parameter marker not possible on a computed column? [message #54489 is a reply to message #52216] Wed, 06 July 2005 15:14 Go to previous message
Originally posted by: none.none.none
Anyone? Is this possible??
"Mark S." <no@spam.com> wrote in message
news:42def549debb79ec4251afdbeaacd2bd$1@www.eclipse.org...
> data?
Previous Topic:<value-of> inside a text
Next Topic:How to transform/merge Data Sets with script?
Current Time: Mon Jul 21 21:01:02 EDT 2025
Powered by FUDForum. Page generated in 0.03571 seconds
