Home » Eclipse Projects » Mylyn » Mantis 1.1 integration
Mantis 1.1 integration [message #52128] Mon, 07 July 2008 13:27 Go to next message
Originally posted by: fkereki.gmail.com
I just installed Mylyn (including the Mantis connector) for Eclipse
Europa, and I got the following problem: when I try to connect to a Mantis
server, the "Server" field offers both Mantis 1.0a5 and 1.1.0, but in
"Additional Settings", only 1.0a5 if offered.
I cannot connect to Mantis.
What am I doing wrong?
Re: Mantis 1.1 integration [message #52375 is a reply to message #52128] Tue, 08 July 2008 11:15 Go to previous message
> Mantis server, the "Server" field offers both Mantis 1.0a5 and 1.1.0,
> but in "Additional Settings", only 1.0a5 if offered.
Best to ask on the Mylyn-Mantis forums at source forge. With that said,
I'm one of the maintainers of the connector.
It shouldn't matter which version of the connector you choose in the
Advanced settings, however it does matter in the Template. If you are
trying to connect to a Mantis Bug Tracker that is using 1.1.x or
greater, you need to tuse the template 1.1.0 template as it will setup
the url correctly.
You will also need your user name and password, annoymous access isn't
allowed.
Re: Mantis 1.1 integration [message #591024 is a reply to message #52128] Tue, 08 July 2008 11:15 Go to previous message
the url correctly.
allowed.
Previous Topic:Saving/filtering breakpoints with task's context
Next Topic:A XML error when creating a query for sourceforge repository
Current Time: Mon Sep 01 01:12:08 EDT 2025
Powered by FUDForum. Page generated in 0.04944 seconds
