Re: Problem previewing reports in eclipse [message #515657 is a reply to message #515503] |
Fri, 19 February 2010 16:05 |
Mark,
Do you get anything in the eclipse log?
Jason
MarkU wrote:
> Hi All,
> I've been doing BIRT reports for a while now. Mostly on windows XP, but
> recently switched to ubuntu. Specifically Ubuntu 9.04.
> Ive loaded up from our version control repository all of our reports,
> and they seem to be fine, but when I try to preview them I get
> "The document that you have requested is not available. The link may be
> wrong, or you may not have the corresponding product feature installed."
> Im using eclipse 3.3.2, birt 2.2.2 and ibm java 1.5.0. and Firefox 3.0.18.
> also when I run it from the terminal using eclipse -clean if get the
> following output
> 19/02/2010 10:58:52 org.eclipse.birt.core.framework.osgi.OSGILauncher
> shutdown
> WARNING: Shutdown unnecessary. (not deployed)
> Any ideas?
> Cheers
> Mark
FUDForum. Page generated in 0.02814 seconds
