Best way to bring existing files & structure into Project & CVS? [message #52069] |
Sat, 15 September 2007 19:36  |
Originally posted by: Ned.WordAndDeed.com
I've got an existing project (osCommerce). I'd like to import the
files & structure into Eclipse as a Project and into CVS. And I'd
like the Project and the CVS repository to be properly connected.
As far as I can tell, the Eclipse installation went well. So far I'm
impressed, but also kind of overwhelmed by the rich environment.
Getting the set of file and structure into CVSNT works fine.
I think I've created a Project and that it was connected to CVS, but
I'm new to Eclipse, there's a lot happening, and I'm not sure I'd
recognize correct (or incorrect) configuration if I saw it. So I'm
starting again from the beginning.
So the question is, given a directory heirarchy outside of Eclipse and
full of files, what's the best way to bring this into Eclipse as a
project and into CVS?
TIA,
Ned
Eclipse 3.3.0
PDT 1.0.0v20070910
Windows 2000
Re: Best way to bring existing files & structure into Project & CVS? [message #52707 is a reply to message #52117] |
Tue, 18 September 2007 11:47  |
On Sun, 16 Sep 2007 09:38:23 +0200, "Martin Eisengardt"
<Martin@eisengardt.de> wrote:
>It's simple. :-)
>1. Within php explorer (pdt perspective) select "new project" -> "php
>project". You can switch to any existing directory. That's it. Eclipse
>stores some usefull information ("This is a PDT project") within file
>".project". After importing your project You should commit this file. There
>are some others and some small directories pdt uses (f.e. .setings). I
>recommend not to commit ".cache" since every client can rebuild this
>directory.
>2. If this project already exists in cvs you can switch to cvs repository
>exploring (perspective) and right click your project folder. Hit "Check out
>as...". If eclipse finds this small file ".project" it will recreate the
>complete project. If it does not find it Eclipse will ask You about project
>natures.
>However Eclipse caches file system information. If you manipulate files
>outside eclipse You can hit "refresh" from context menu.
You confirmed what I have been doing. Good to have a second opinion.
> Note: You should
>not use more than one cvs/svn client. You should not use eclipse and
>tortoise to work on the same directories.
This is an important tip. Many newbies need to know this.
Ned
FUDForum. Page generated in 1.06666 seconds
