Home » Newcomers » Newcomers » Install Eclipse in Linux
Install Eclipse in Linux [message #52051] Thu, 14 April 2005 10:03 Go to next message
Originally posted by: oren.versamed.co.il
Hello
I use Suse Linux 9.2 and just download eclipse-SDK-3.0.2-linux-gtk.zip.
I am also new in Linux, so I have two questions:
1. Where to unzip the file ?
(I unzip the file to /usr/local/bin, but now eclipse is not in the path,
so I must type /usr/local/bin/eclipse/eclipse in order to open the
eclipse.
2. What is the next step after the unzip ?
Should I open the startup.jar ? (how to open the jar ?)
Should I configure something and where ?
3. Is there a linux installation guid somewhere ? (the read me talks about
windows and mac only (altough the eclipse runs))
Thanks a lot
Oren
Re: Install Eclipse in Linux [message #52151 is a reply to message #52051] Thu, 14 April 2005 11:36 Go to previous message
On 2005-04-14, OM <oren@versamed.co.il> wrote:
> 1. Where to unzip the file ? (I unzip the file to /usr/local/bin, but
> now eclipse is not in the path, so I must type
> /usr/local/bin/eclipse/eclipse in order to open the eclipse.
export PATH=$PATH:<PATH_TO_ECLIPSE> ?
Just start <ECLIPSE_INST>/eclipse...
MAN-UANIC
Eclipse.org downloads @ http://eclipse.osdn.org.ua/
Previous Topic:could not find java 2 runtime environment
Next Topic:Minimum files needed for eclipse to run
Current Time: Thu Jul 17 09:37:34 EDT 2025
Powered by FUDForum. Page generated in 0.13569 seconds
