Home » Eclipse Projects » Plugin Development Environment (PDE) » Grid Layout
Grid Layout [message #52032] Wed, 25 March 2009 12:00 Go to next message
I'm implementing an Wizard Page extending the class WizardPage. In the
createControl method I have the following code:
public void createControl(Composite parent) {
Composite composite1 = createComposite(parent,2);
new Label(composite1,SWT.NULL).setText("class name:");
className = createTextField(composite1);
className.addModifyListener(new TextModifyListener());
textChanged();
Composite composite2 = createComposite(parent,1);
composite2.setVisible(true);
new EiffelContainerSelectionGroup(composite2,null);
setControl(parent);
the problem is: the second composite is not showing up inside the Wizard
Page - only the first one.
the createComposite method looks as follows:
private Composite createComposite(Composite parent, int columns){
Composite composite = new Composite(parent,SWT.NULL);
GridLayout layout = new GridLayout();
layout.numColumns = columns;
composite.setLayout(layout);
GridData data = new GridData();
data.horizontalAlignment=SWT.FILL;
data.grabExcessHorizontalSpace=true;
//data.verticalAlignment=SWT.FILL;
composite.setLayoutData(data);
return composite;
Does anyone know, where the problem is? I've tried to put the two
composites inside a top-level composite and with that both composites
appeared but the result didn't look like I expected it to do. Although I
specified only one column for the top Level composite, all widgets were on
the left side of the page...
Kind regards, Kathi
Re: Grid Layout [message #52060 is a reply to message #52032] Wed, 25 March 2009 12:11 Go to previous messageGo to next message
it's me again,
I tried to modify the GridData a bit and now it works with the extra
top-Level Composite.
But it shouldn't it work without this extra composite, too?
regards, Kathi
Re: Grid Layout [message #52085 is a reply to message #52060] Thu, 26 March 2009 01:34 Go to previous messageGo to next message
Katharina Brandl wrote:
> it's me again,
> regards, Kathi
You problem has more chances of getting resolved at SWT newsgroup eclipse.platform.swt
Am not SWT guru, but it looks like you were facing this issue either due to incorrect spanning (hspan) or incorrect nesting of composites. Like I said - i don't know for sure.
Ankur..
Re: Grid Layout [message #52110 is a reply to message #52085] Thu, 26 March 2009 03:15 Go to previous messageGo to next message
ok, I'll try it there - thanks for the idea,
kathi
Re: Grid Layout [message #52136 is a reply to message #52032] Thu, 26 March 2009 04:04 Go to previous messageGo to next message
shouldn't you call setControl() with *your* top level composite and not with
the parent that is passed to you?
- Prakash
http://blog.eclipse-tips.com
Re: Grid Layout [message #53170 is a reply to message #52136] Thu, 02 April 2009 04:31 Go to previous message
> - Prakash
Yes, that was the initial problem: I have to create only one control and
pass it to the parent. Evertything else should be inside this new top
level control.
thanks for your help
Kathi
Re: Grid Layout [message #593975 is a reply to message #52032] Wed, 25 March 2009 12:11 Go to previous message
it's me again,
regards, Kathi
Re: Grid Layout [message #593984 is a reply to message #52060] Thu, 26 March 2009 01:34 Go to previous message
> it's me again,
> regards, Kathi
Ankur..
Re: Grid Layout [message #593993 is a reply to message #52085] Thu, 26 March 2009 03:15 Go to previous message
kathi
Re: Grid Layout [message #593997 is a reply to message #52032] Thu, 26 March 2009 04:04 Go to previous message
- Prakash
Re: Grid Layout [message #594471 is a reply to message #52136] Thu, 02 April 2009 04:31 Go to previous message
> - Prakash
level control.
Kathi
Previous Topic:Plugin build and listing dependencies
Next Topic:Writing to stdout
Current Time: Fri Jul 25 23:20:28 EDT 2025
Powered by FUDForum. Page generated in 0.05162 seconds
