Home » Modeling » OCL » Creating context-free queries
Creating context-free queries [message #52029] Mon, 03 March 2008 14:53 Go to next message
Hi...
I'm trying to create a simple context-free query
("SomeClass.allInstances()") with OCLHelper#createQuery(String), but I
always get an Exception because I never set the context-classifier with
Environment#setSelfVariable(Variable).
If I set the self-variable to any valid classifier, everything works fine.
If I set it to an empty variable (no setType(EClassifier)), I run into a
StackOverflow.
So what is the right way to create a context-free query?
Stefan
Re: Creating context-free queries [message #52055 is a reply to message #52029] Mon, 03 March 2008 18:23 Go to previous messageGo to next message
Hi, Stefan,
OCL doesn't have a concept of context-free queries. All OCL expressions
have a context classifier.
The stack-overflow on an untyped variable looks like a bug.
HTH,
Christian
Stefan Schulze wrote:
> Hi...
> StackOverflow.
> Stefan
Re: Creating context-free queries [message #52081 is a reply to message #52055] Mon, 03 March 2008 19:29 Go to previous messageGo to next message
Hi Christian,
the method Query#evaluate() seems to be designed for context-free usage. If
I want to use that method, what should I set as self-variable? Is it correct
to set it to a random EClass from my metamodel?
Stefan
"Christian W. Damus" <cdamus@ca.ibm.com> schrieb im Newsbeitrag
news:fqi1a4$6du$1@build.eclipse.org...
> Hi, Stefan,
> HTH,
> Christian
>> Hi...
>> fine.
>> StackOverflow.
>> Stefan
Re: Creating context-free queries [message #52132 is a reply to message #52081] Tue, 04 March 2008 08:58 Go to previous messageGo to next message
Hi, Stefan,
I see, now. That API is a bit of an anachronism. I suppose that any
EClassifier will do. You might just grab EcorePackage.Literals.ESTRING.
I suppose it depends on what your application is doing, but often it isn't
practical for an application to know a priori whether an expression will
reference 'self.' Hence, my previous reply was more OCL-oriented than
API-oriented.
Christian
> Hi Christian,
> If I want to use that method, what should I set as self-variable? Is it
> correct to set it to a random EClass from my metamodel?
> Stefan
>> Hi, Stefan,
>> HTH,
>> Christian
>>> Hi...
>>> fine.
>>> StackOverflow.
>>> Stefan
Re: Creating context-free queries [message #52491 is a reply to message #52132] Sat, 08 March 2008 21:14 Go to previous messageGo to next message
Hi Christian,
using EcorePackage.Literals.ESTRING works fine on one condition. If the
first self-variable I set to an Environment is an
EcorePackage.Literals.EString, the contextPackage of this Environment is set
to EcorePackage.eINSTANCE.
Because the contextPackage will never be updated, all subsequent evaluations
are failing.
It's not hard to work around this problem, but I thought it'd be good to
know for other people with the same problems. ;)
Bye,
Stefan
news:fqjki2$nqc$1@build.eclipse.org...
> Hi, Stefan,
> API-oriented.
Re: Creating context-free queries [message #52545 is a reply to message #52491] Mon, 10 March 2008 09:32 Go to previous message
Hi, stefan,
Right, that's a good point that I neglected to mention. The context
classifier also determines what is the default package for resolution of
unqualified classifier names.
You should be able to use the fully-qualified name to reference any type in
any package (so long as its name is unique, of course).
This sounds like a good FAQ item for the Wiki ...
Christian
> Hi Christian,
> set to EcorePackage.eINSTANCE.
> evaluations are failing.
> Bye,
> Stefan
>> Hi, Stefan,
>> isn't practical for an application to know a priori whether an expression
>> will
>> API-oriented.
Previous Topic:Support for UML 2 collaborations
Next Topic:CollectionItem -> item direct edition
Current Time: Fri Jul 18 09:47:28 EDT 2025
Powered by FUDForum. Page generated in 0.04319 seconds
