Home » Archived » Visual Editor (VE) » JDialog Creation
JDialog Creation [message #52005] Mon, 26 July 2004 03:37 Go to next message
Originally posted by: masterelettronik.yahoo.it
How ican make a JDialog with VE ? Can I make it changing the class
derived from JFrame to JDialog?
Thank you for the help!
(Excuse my poor English...)
Re: JDialog Creation [message #52030 is a reply to message #52005] Mon, 26 July 2004 09:08 Go to previous messageGo to next message
In the New Visual Class Wizard, select Other as the visual class you'd
like to extend, then press the Browse... button next to the Superclass
field. Enter JDialog, then press Finish.
This should work ok. We've had a few problems recently with extending
JDialog. If the resulting code has problems, if you fix the code
yourself it should work. Otherwise, please try out the forthcoming M2
build.
- Jeff
Re: When is M2 sceduled? [message #52056 is a reply to message #52030] Mon, 26 July 2004 15:34 Go to previous messageGo to next message
Hi Jeff,
when is the release of M2 Sceduled?
Winni
> build.
> - Jeff
Re: When is M2 sceduled? [message #52082 is a reply to message #52056] Mon, 26 July 2004 16:39 Go to previous message
Winni,
Any day now, just resolving a last few bugs before pushing it out the door.
- Jeff
Winni P. wrote:
> Hi Jeff,
> Thanks
> Winni
Re: JDialog Creation [message #595861 is a reply to message #52005] Mon, 26 July 2004 09:08 Go to previous message
build.
- Jeff
Re: When is M2 sceduled? [message #595867 is a reply to message #52030] Mon, 26 July 2004 15:34 Go to previous message
Hi Jeff,
Winni
> build.
> - Jeff
Re: When is M2 sceduled? [message #595874 is a reply to message #52056] Mon, 26 July 2004 16:39 Go to previous message
Winni,
- Jeff
Winni P. wrote:
> Hi Jeff,
> Thanks
> Winni
Previous Topic:JDialog Creation
Next Topic:Reading about EMF and VE! I need more info on the code generation capabilities
Current Time: Mon Jul 21 22:10:37 EDT 2025
Powered by FUDForum. Page generated in 0.06781 seconds
