Home » Language IDEs » Java Development Tools (JDT) » How to use Eclipse debugger to step through/debug VM initialization?
How to use Eclipse debugger to step through/debug VM initialization? [message #51975] Fri, 06 June 2003 14:43 Go to next message
Folks,
We have a situation where we need to step through our app's VM
initialization using the Eclipse debugger. Possible? Can we break before
main, within the VM initialization? How do we put the VM source into the
correct path? Etc.
Re: How to use Eclipse debugger to step through/debug VM initialization? [message #53492 is a reply to message #51975] Mon, 09 June 2003 14:55 Go to previous message
Originally posted by: jed_anderson.us.ibm.com
Paul,
Do you really mean stepping through the VM initialization? Or do you
mean stepping through the static initializers for your classes?
If it is the former, you are going to have to use CDT (and I have no
clue about where you get source for the VM).
In the second case, just put breakpoints in your static initializers.
jkca
Paul Duffy wrote:
> Folks,
> correct path? Etc.
Previous Topic:Breakpoints, Remote Debugging and Projects
Next Topic:Can't debug StackOverflowError
Current Time: Mon Sep 01 03:35:20 EDT 2025
Powered by FUDForum. Page generated in 0.39946 seconds
