Home » Newcomers » Newcomers » Eclipse NOT RESPONDING after usage data sent
Eclipse NOT RESPONDING after usage data sent [message #514143] Fri, 12 February 2010 10:20 Go to next message
now and then eclipse (3.5) asks me if I want to send usage data to help improve the IDE. So I say to myself, sure, why not, and up until today there were no problems with this. But after I agreed to send usage data today, eclipse froze up and I cant do anything about it. I already tried rebooting my pc, no use. Any help would be greatly appreciated.Thanx
Robert
Re: Eclipse NOT RESPONDING after usage data sent [message #514178 is a reply to message #514143] Fri, 12 February 2010 12:18 Go to previous messageGo to next message
So I found some kind of a "solution".
1. start eclipse with no connection to the internet.
2. if you start eclipse while connected to the internet, disable your network connection for a while and eclipse will be responding again.
But still, is there a real solution to this problem? Am I the only one experiencing this type of difficulties?
Re: Eclipse NOT RESPONDING after usage data sent [message #514260 is a reply to message #514178] Sat, 13 February 2010 02:29 Go to previous messageGo to next message
"Robert Varga" <vargar2@gmail.com> wrote in message
news:hl42go$4hc$1@build.eclipse.org...
Haven't run into that myself (and was using Eclipse all day). But in
general, if you run into a deadlock or freeze kind of problem, you can
approach it this way: http://wiki.eclipse.org/How_to_report_a_deadlock
Re: Eclipse NOT RESPONDING after usage data sent [message #524036 is a reply to message #514260] Tue, 30 March 2010 08:38 Go to previous messageGo to next message
I encountered the same problems on MacOSX Snow Leopard and Eclipse Version: 3.5.1 (Yoxos Distribution), so: you are not alone ;)
Thanks for the hint,
Achim Bode
Re: Eclipse NOT RESPONDING after usage data sent [message #652025 is a reply to message #514143] Wed, 02 February 2011 08:35 Go to previous message
Not sure if this will work for everyone. To resolve this issue, I deleted the log files and the lock file in the workspace while eclipse was off. Restarted eclipse and the problem was gone.
Previous Topic:Internalization tool
Next Topic:Code view , GUI view for JAVA
Current Time: Sun Nov 09 19:37:17 EST 2025
Powered by FUDForum. Page generated in 0.08901 seconds
