Home » Eclipse Projects » Plugin Development Environment (PDE) » Extending the Samples wizard in Eclipse welcome screen
Extending the Samples wizard in Eclipse welcome screen [message #51955] Tue, 24 March 2009 21:26
Is there a way to extend the
org.eclipse.pde.ui.internal.samples.ShowSampleAction wizard without it
showing the "What can you do with the sample" window on the right hand
side after the import of the sample is done? I am hooking into this wizard
with non-Java samples, and the links in this section is misleading
(Browsing, running, and debugging the Java source code in the project).
Previous Topic:Setting the right editor title for the workbench
Next Topic:Extending the Samples wizard in Eclipse welcome screen
Current Time: Mon Jul 07 18:34:54 EDT 2025
Powered by FUDForum. Page generated in 0.04508 seconds
