Home » Modeling » M2T (model-to-text transformation) » JET tag to set local variable - Flag
JET tag to set local variable - Flag [message #51950] Tue, 07 October 2008 09:32 Go to next message
I need to set a local variable - like boolean flag in my template file for
a business logic condition that should occur only the first time .(flag
before iteration begins) .
I did not find JET tag to set local variable. c:set tag sets XPath
expression only.
Part of snippet is below:
<c:setVariable select="$oldSpringContext/beans" var="beanRoot"/>
<c:iterate select="$currentArtifact/package" var="currentPackage">
<c:iterate select="$currentPackage/class" var="currentClass">
Pls let me know if JET tag exists or workaround.
Justin.
Re: JET tag to set local variable - Flag [message #51976 is a reply to message #51950] Wed, 08 October 2008 12:41 Go to previous message
Justin:
Boolean, string and numeric expressions are also valid XPath expressions.
So:
<c:setVariable var="firstTime" select="true()"/>
<c:iterate ... >
<c:if test="$firstTime">
<c:setVariable var="firstTime" select="false()"/>
... first time processing...
</c:if>
</c:iterate>
FYI. You can also do:
<c:setVarible var="i" select=" 1 "/> <%-- $i equals the number 1 --%>
or
<c:setVariable var="ECLIPSE" select=" 'org.eclipse' "/> <%-- $ECLIPSE
equals the string 'org.eclipse' (without the quotes) --%>
Paul
Previous Topic:Problems with java:package
Next Topic:Re: Using JET with EMF model
Current Time: Sat Jul 26 09:17:39 EDT 2025
Powered by FUDForum. Page generated in 0.03419 seconds
