Home » Language IDEs » C / C++ IDE (CDT) » Failed launching CDI Debugger
Failed launching CDI Debugger [message #51907] Mon, 25 November 2002 11:18 Go to next message
I get the following error when I try to debug with the release 1.0
11/14/2002 build of the CDT:
Failed Launching CDI Debugger: Error initializing: Timedout
org.eclipse.cdt.debug.core.cdi.CDIException: Error initializing: Timedout
org.eclipse.cdt.debug.mi.core.GDBDebugger.createLaunchSessio n(GDBDebugger.java:49)
org.eclipse.cdt.launch.internal.LocalCLaunchConfigurationDel egate.launch(LocalCLaunchConfigurationDelegate.java:80)
org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:136)
org.eclipse.debug.internal.ui.launchConfigurations.LaunchCon figurationDialog$10.run(LaunchConfigurationDialog.java:2299)
org.eclipse.jface.operation.ModalContext$ModalContextThread. run(ModalContext.java:98)
I can debug outside of Eclipse just fine (even using another tool that
uses the gdb's machine interface).
This is the first time trying to debug using the CDT.
Re: Failed launching CDI Debugger [message #51933 is a reply to message #51907] Mon, 25 November 2002 14:18 Go to previous messageGo to next message
Originally posted by: ihutchinson.providencesoftware.com
I am using Eclipse 2.0.2 with the nightly build and debugging works
fine. My configuration is Linux/2.4.x kernel/glibc 2.2.5. I use the gtk
based versions. All my settings are default including the debugger time
out info under Window->Prefernces->C\C++->Debug->GDB MI, which is set to
10000.
what is your configuration?
> at
> at
> at
> at
> at
Re: Failed launching CDI Debugger [message #51959 is a reply to message #51933] Mon, 25 November 2002 14:41 Go to previous message
Originally posted by: thingsforsale.nc.rr.com
I found the problem, I had the default cygwin gdb instead of the required
5.2 in my path.
Thanks for your willingness to help.
Ed
"Iran Q. Hutchinson" <ihutchinson@providencesoftware.com> wrote in message
news:artt3q$6g5$1@rogue.oti.com...
> 10000.
Timedout
> > at
va:49)
> > at
> > at
on.java:136)
> > at
> > at
..java:98)
Previous Topic:EJB development in eclipse?
Next Topic:Solaris x86 CDT1.0?
Current Time: Thu Jul 17 22:05:29 EDT 2025
Powered by FUDForum. Page generated in 0.10662 seconds
