Home » Archived » XML Schema Definition (XSD) » test editor source
test editor source [message #51875] Tue, 31 August 2004 13:57 Go to next message
Originally posted by: gj.puredge.com
Is it possible to download the source for the Test XML Editor? I want to be
able to dynamically add elements and model groups to my schema and I figure
that's a good place to start.
Is it possible to obtain the source through my Eclipse CVS? If so, what is
the CVS Host, repository path, user, pw,connection type, etc? Sorry if I'm
new to this one.
Gary
Re: test editor source [message #51901 is a reply to message #51875] Tue, 31 August 2004 14:09 Go to previous messageGo to next message
--------------070207060507010109020007
Content-Type: text/plain; charset=us-ascii; format=flowed
Gary,
Imagine an open source project where your couldn't download the source.
That would be a contradiction in terms. ;-)
Check out this document for help in setting up CVS for EMF and XSD:
http://dev.eclipse.org/viewcvs/indextools.cgi/%7Echeckout%7E /emf-home/docs/cvsdoc/emfcvsug.html
There are samples in org.eclipse.xsd.util.XSDPrototypicalSchema that
should help too.
>new to this one.
>Thanks
>Gary
Content-Type: text/html; charset=us-ascii
<html>
<head>
<title></title>
</head>
Gary,<br>
<br>
source.&nbsp; That would be a contradiction in terms. ;-)<br>
<br>
Check out this document for help in setting up CVS for EMF and XSD:<br>
<blockquote><a
href=" http://dev.eclipse.org/viewcvs/indextools.cgi/%7Echeckout%7E /emf-home/docs/cvsdoc/emfcvsug.html"> http://dev.eclipse.org/viewcvs/indextools.cgi/%7Echeckout%7E /emf-home/docs/cvsdoc/emfcvsug.html</a><br>
</blockquote>
should help too.<br>
<br>
<br>
Gary J wrote:<br>
<blockquote cite="midch2e0f$a3j$1@eclipse.org" type="cite">
<pre wrap="">Is it possible to download the source for the Test XML Editor? I want to be
new to this one.
Gary
</pre>
</blockquote>
<br>
</body>
</html>
--------------070207060507010109020007--
Re: test editor source [message #51927 is a reply to message #51875] Tue, 31 August 2004 14:12 Go to previous messageGo to next message
Well I almost answered my own question again.
I managed to connect to the dev.eclipse.org:/home/eclipse repository but I
can not see the org.eclipse.xsd project although it is visible through the
html viewcvs interface. Is this project someplace else?
"Gary J" <gj@puredge.com> wrote in message news:ch2e0f$a3j$1@eclipse.org...
new to this one.
Gary
Re: test editor source [message #51952 is a reply to message #51927] Tue, 31 August 2004 14:15 Go to previous messageGo to next message
Sorry to jump the gun. I found it under /technology
"Gary J" <gj@puredge.com> wrote in message news:ch2ern$bmg$1@eclipse.org...
new to this one.
Gary
Re: test editor source [message #51978 is a reply to message #51901] Tue, 31 August 2004 14:43 Go to previous messageGo to next message
Hi Ed,
Thanks for the help. Which repository is
org.eclipse.xsd.util.XSDPrototypicalSchema in? Its not in /home/technology.
"Ed Merks" <merks@ca.ibm.com> wrote in message
news:ch2enc$bcn$1@eclipse.org...
Gary,
There are samples in org.eclipse.xsd.util.XSDPrototypicalSchema that should
help too.
new to this one.
Gary
Re: test editor source [message #52004 is a reply to message #51978] Tue, 31 August 2004 15:27 Go to previous message
--------------010408090902000503080606
Gary
Here's a link to the location of the file containing the class I
referred to:
http://dev.eclipse.org/viewcvs/indextech.cgi/org.eclipse.xsd /plugins/org.eclipse.xsd/src/org/eclipse/xsd/util/XSDPrototy picalSchema.java
But you probably already found it. ;-)
Gary J wrote:
>Hi Ed,
>Thanks
>Gary,
>help too.
>new to this one.
>Thanks
>Gary
<html>
<head>
<title></title>
</head>
Gary<br>
<br>
referred to:<br>
<br>
<blockquote><a
href=" http://dev.eclipse.org/viewcvs/indextech.cgi/org.eclipse.xsd /plugins/org.eclipse.xsd/src/org/eclipse/xsd/util/XSDPrototy picalSchema.java"> http://dev.eclipse.org/viewcvs/indextech.cgi/org.eclipse.xsd /plugins/org.eclipse.xsd/src/org/eclipse/xsd/util/XSDPrototy picalSchema.java</a><br>
</blockquote>
<br>
But you probably already found it. ;-)<br>
<br>
<br>
Gary J wrote:<br>
<blockquote cite="midch2gn4$fg9$1@eclipse.org" type="cite">
<pre wrap="">Hi Ed,
"Ed Merks" <a class="moz-txt-link-rfc2396E" href="mailto:merks@ca.ibm.com">&lt;merks@ca.ibm.com&gt;</a> wrote in message
<a class="moz-txt-link-freetext" href="news:ch2enc$bcn$1@eclipse.org">news:ch2enc$bcn$1@eclipse.org</a>...
Gary,
<a class="moz-txt-link-freetext" href=" http://dev.eclipse.org/viewcvs/indextools.cgi/%7Echeckout%7E /emf-home/docs/cvsdoc/emfcvsug.html"> http://dev.eclipse.org/viewcvs/indextools.cgi/%7Echeckout%7E /emf-home/docs/cvsdoc/emfcvsug.html</a>
help too.
new to this one.
Gary
</pre>
</blockquote>
<br>
</body>
</html>
--------------010408090902000503080606--
Re: test editor source [message #591163 is a reply to message #51875] Tue, 31 August 2004 14:09 Go to previous message
Gary,
should help too.
>new to this one.
>Thanks
>Gary
<html>
<head>
<title></title>
</head>
Gary,<br>
<br>
<br>
<blockquote><a
</blockquote>
<br>
<br>
Gary J wrote:<br>
new to this one.
Gary
</pre>
</blockquote>
<br>
</body>
</html>
Re: test editor source [message #591181 is a reply to message #51875] Tue, 31 August 2004 14:12 Go to previous message
new to this one.
Gary
Re: test editor source [message #591192 is a reply to message #51927] Tue, 31 August 2004 14:15 Go to previous message
new to this one.
Gary
Re: test editor source [message #591204 is a reply to message #51901] Tue, 31 August 2004 14:43 Go to previous message
Hi Ed,
Gary,
help too.
new to this one.
Gary
Re: test editor source [message #591212 is a reply to message #51978] Tue, 31 August 2004 15:27 Go to previous message
Gary
referred to:
Gary J wrote:
>Hi Ed,
>Thanks
>Gary,
>help too.
>new to this one.
>Thanks
>Gary
<html>
<head>
<title></title>
</head>
Gary<br>
<br>
referred to:<br>
<br>
<blockquote><a
</blockquote>
<br>
<br>
<br>
Gary J wrote:<br>
<pre wrap="">Hi Ed,
Gary,
help too.
new to this one.
Gary
</pre>
</blockquote>
<br>
</body>
</html>
Previous Topic:test editor source
Next Topic:Re: EMF/SDO/XSD Update Manager Site
Current Time: Thu Jul 17 12:41:50 EDT 2025
Powered by FUDForum. Page generated in 0.13333 seconds
