Home » Newcomers » Newcomers » error after launching eclipse
error after launching eclipse [message #51870] Wed, 13 April 2005 18:51
Any idea about this error? Seems eclipse can not restore the workspace I
had. -yuchen
"Unable to create editor. This message may be due to a bug in the editor,
not a problem with the file you are trying to edit. First close this error
message and then use "Open With..." to open the file in a different editor.
Reason for the failure: No input factory ID found for editor
id=org.eclipse.ui.DefaultTextEditor name=.project:"
org.eclipse.ui.PartInitException: No input factory ID found for editor
org.eclipse.ui.internal.EditorManager$Editor.getRestoredInpu t(EditorManager.java:1736)
org.eclipse.ui.internal.EditorManager$Editor.getEditorInput( EditorManager.java:1715)
org.eclipse.ui.internal.EditorManager.busyRestoreEditorHelpe r(EditorManager.java:1177)
org.eclipse.ui.internal.EditorManager.busyRestoreEditor(Edit orManager.java:1102)
at org.eclipse.ui.internal.EditorManager$7.run(EditorManager.ja va:1064)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:69)
org.eclipse.ui.internal.EditorManager.restoreEditor(EditorMa nager.java:1062)
org.eclipse.ui.internal.EditorManager.restoreEditorState(Edi torManager.java:1876)
org.eclipse.ui.internal.EditorManager.restoreState(EditorMan ager.java:1016)
org.eclipse.ui.internal.WorkbenchPage.restoreState(Workbench Page.java:2464)
org.eclipse.ui.internal.WorkbenchWindow.restoreState(Workben chWindow.java:1660)
at org.eclipse.ui.internal.Workbench.restoreState(Workbench.jav a:1408)
at org.eclipse.ui.internal.Workbench.access$9(Workbench.java:13 58)
at org.eclipse.ui.internal.Workbench$14.run(Workbench.java:1241 )
org.eclipse.core.internal.runtime.InternalPlatform.run(Inter nalPlatform.java:1021)
at org.eclipse.core.runtime.Platform.run(Platform.java:757)
at org.eclipse.ui.internal.Workbench.restoreState(Workbench.jav a:1185)
org.eclipse.ui.internal.WorkbenchConfigurer.restoreState(Wor kbenchConfigurer.java:173)
org.eclipse.ui.application.WorkbenchAdvisor.openWindows(Work benchAdvisor.java:712)
at org.eclipse.ui.internal.Workbench.init(Workbench.java:962)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1510)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:306)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:103)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:228)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:344)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:156)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:315 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:268)
at org.eclipse.core.launcher.Main.run(Main.java:942)
at org.eclipse.core.launcher.Main.main(Main.java:926)
Previous Topic:note->john athrone
Next Topic:organizing multiple projects in one workspace
Current Time: Tue Jul 15 07:03:44 EDT 2025
Powered by FUDForum. Page generated in 0.08217 seconds
