Re: Galileo updates don't work [message #517485 is a reply to message #513548] |
Sun, 28 February 2010 16:13 |
Originally posted by: mansour.alakeel.gmail.com
Same issue here. A new fresh install.
When trying to install software I get this:
Network connection problems encountered during search.
Unable to access "http://download.eclipse.org/releases/galileo".
Error parsing site stream. [The XML stream is not a valid default
"site.xml" file. The root tag is not site.]
The XML stream is not a valid default "site.xml" file. The root tag
is not site.
is not site.
Both Sites are available under :
Window => Preferences => Install/Updates => Software Update Sites.
Hitting the url with browser gives 404.
http://download.eclipse.org/releases/galileo/site.xml
Hope someone will look into it or provide help.
Eric Rizzo wrote:
> On 2/9/10 1:31 PM, Wm.A.Stafford wrote:
>> Eric,
>> Thanks for the reply. In answer to your question, selecting
>> http://download.eclipse.org/releases/galileo from the 'work with' list
>> produces the message: "No repository found at
>> From the 'available software' panel. Selecting
>> http://download.eclipse.org/releases/galileo and clicking the 'test'
>> button produces a popup with the following error:
>> Unable to read repository at
>> Network is down: connect
>> The last part of this message, "network is down", makes me thing some
>> sort of configuration is required. But I'm not behind a proxy and older
>> versions of Eclipse on the same machine do not display this behavior.
>> Any ideas?
> The only thing I can think of is that maybe your workspace has proxy
> settings that are invalid (because you're not actually behind a proxy).
> Look in the Preferences (type "proxy" without quotes in the search field
> of the Preferences dialog) and see if there is anything suspicious there.
> Other than that I can only suggest getting a network sniffer to try to
> figure out what is happening.
> Hope this helps,
> Eric
Re: Galileo updates don't work [message #655360 is a reply to message #512669] |
Sat, 19 February 2011 21:09 |
No real name Messages: 1 Registered: February 2011 |
Junior Member |
I am having the exact same problem as mansour.alakeel.gmail.com. I use Eclipse 3.5.1-r1 on Gentoo. I cannot tell when the problem started - I have only been trying to access the site in question since around 2011-02-10.
There is nothing suspicious about my proxy settings - I have not changed them since the installation of Eclipse, and no proxy is enabled.
[Updated on: Sun, 20 February 2011 11:27] Report message to a moderator
FUDForum. Page generated in 0.08297 seconds
