Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » JET - Feature 'version' not found
JET - Feature 'version' not found [message #51762] Fri, 22 September 2006 03:13 Go to next message
I am trying to generate the xml and java artifacts based on my EMF model
using the JET2 Transformations. When I try to execute the
runTransformationOnResource() on the model (that I have generated using my
Editor) from my Action, am getting the Feature 'version' not found error ,
with the path given to my model file at a loaction (2,-1)
Help in this regard is highly appericiated.
Thanks and Regards,
Kamesh
Re: JET - Feature 'version' not found [message #51956 is a reply to message #51762] Fri, 22 September 2006 08:40 Go to previous messageGo to next message
Kamesh:
JET transformations are setup by default to consume XML documents, not ECore
documents.
To fix your transformation, open the plugin.xml in you transformation
project. Switch to the Extension tag, expand the org.eclipse.jet.transform
extension , and select the 'transform' element. In the Extension Element
Details pane, set the 'modelLoader' property to 'org.eclipse.jet.emf'. Save,
and try running your transformation again.
BTW, documentation on how to do this was recently added to the JET 0.7.1
maintenance build.
Paul Elder
"Kamesh Sampath" <kamesh_sampath@msn.com> wrote in message
news:fbe9de061313c36bbd142ae4f2f7acc1$1@www.eclipse.org...
> Thanks and Regards,
> Kamesh
Re: JET - Feature 'version' not found [message #52242 is a reply to message #51956] Fri, 22 September 2006 22:23 Go to previous messageGo to next message
Paul Elder wrote:
> Kamesh:
> documents.
> maintenance build.
> Paul Elder
>> Thanks and Regards,
>> Kamesh
Paul,
Thanks for the insight in to this problem all my issues are resolved and
my artifacts are getting generated but when i see the log trace am
getting the following exceptions,
1)org.eclipse.jet.taglib.JET2TagException: Variable
"org.eclipse.jet.resource.project.name" is not defined.
2)org.eclipse.jet.taglib.JET2TagException: Variable
"org.eclipse.jet.resource.fileName" is not defined.
I am running the JET transformation from my action class , the code
snippet as follows,
JET2Context context = new JET2Context(StrutsConfigType.class);
JET2Platform.runTransformOnResource(ARTIFACT_XML_TRANSFORMER _ID,
modelFile, new NullProgressMonitor());
IStatus status = JET2Platform.runTransform(
ARTIFACT_XML_TRANSFORMER_ID, context, new NullProgressMonitor());
Please let me know why am getting an expception trace in my eclipse log
inspite of the artifacts getting generated properly as expected ????
Thanks and Regards,
Kamesh
Re: JET - Feature 'version' not found [message #52373 is a reply to message #52242] Mon, 25 September 2006 08:15 Go to previous message
Kamesh:
You seem to be running the transformation twice:
.... this runs it once, should work ...
> IStatus status = JET2Platform.runTransform( ARTIFACT_XML_TRANSFORMER_ID,
.... this attempts to run it again, probably won't work...
In fact, your could can be simplified to the one statement:
Paul
news:ef25rg$djj$1@utils.eclipse.org...
> Paul Elder wrote:
>> Kamesh:
>> ECore documents.
>> org.eclipse.jet.transform extension , and select the 'transform' element.
>> In the Extension Element Details pane, set the 'modelLoader' property to
>> 'org.eclipse.jet.emf'. Save, and try running your transformation again.
>> maintenance build.
>> Paul Elder
>>> Hi,
>>> my Editor) from my Action, am getting the Feature 'version' not found
>>> error , with the path given to my model file at a loaction (2,-1)
>>> Thanks and Regards,
>>> Kamesh
> Paul,
> snippet as follows,
> Thanks and Regards,
> Kamesh
Re: JET - Feature 'version' not found [message #591734 is a reply to message #51762] Fri, 22 September 2006 08:40 Go to previous message
Kamesh:
documents.
maintenance build.
Paul Elder
> Thanks and Regards,
> Kamesh
Re: JET - Feature 'version' not found [message #591812 is a reply to message #51956] Fri, 22 September 2006 22:23 Go to previous message
Paul Elder wrote:
> Kamesh:
> documents.
> maintenance build.
> Paul Elder
>> Thanks and Regards,
>> Kamesh
Paul,
snippet as follows,
Thanks and Regards,
Kamesh
Re: JET - Feature 'version' not found [message #591862 is a reply to message #52242] Mon, 25 September 2006 08:15 Go to previous message
Kamesh:
Paul
> Paul Elder wrote:
>> Kamesh:
>> ECore documents.
>> maintenance build.
>> Paul Elder
>>> Hi,
>>> Thanks and Regards,
>>> Kamesh
> Paul,
> snippet as follows,
> Thanks and Regards,
> Kamesh
Previous Topic:Teneo: Hibernate and Arrays as EDataType
Next Topic:How to use Progress Monitor with JET2 Transformation
Current Time: Sat Jul 26 14:45:12 EDT 2025
Powered by FUDForum. Page generated in 0.04627 seconds
