Home » Modeling » BPEL Designer » Installing BPEL plugin
Installing BPEL plugin [message #4555] Fri, 12 May 2006 15:06 Go to next message
Originally posted by: flinn.alum.mit.edu
I tried to use the Update Manager to load the BPEL plugin. I downloaded
Eclipse 3.2 and ran the update manager giving it the required URL listed
on the BPEL designer update site. When it started to install I got the
following error message - Requested operation cannot be performed because
it would invalidate the current configuration. See details for more
information.
Unable to retrieve remote reference
" http://download.eclipse.org/technology/bpel/update-site/feat ures/org.eclipse.jem_1.2.0.v20060227-S.jar".
[Server returned HTTP response code: "404 Not Found" for URL:
http://download.eclipse.org/technology/bpel/update-site/feat ures/org.eclipse.jem_1.2.0.v20060227-S.jar.]
and
Requested operation cannot be performed because it would invalidate the
current configuration. See details for more information.
What am I doing wrong?
thanks for any help
Don
Re: Installing BPEL plugin [message #4626 is a reply to message #4555] Sat, 13 May 2006 22:02 Go to previous messageGo to next message
> because it would invalidate the current configuration. See details for
> more information.
> and
Hmm - probably nothing. Michal, does one or more of the jar links need
to be updated?
james
Re: Installing BPEL plugin [message #4764 is a reply to message #4626] Wed, 24 May 2006 19:05 Go to previous messageGo to next message
Originally posted by: ronaldmridenour.yahoo.com
I used the update manager as well. The plugins downloaded, then during
installation I got the following message.
an exception occurred while downloading feature from
http://download.eclipse.org/.technology/bpel/update-site/fea tures/org.eclipse.wst.common_core.feature_1.0.100.v200602152 251--jXOWXVW2X.jar
Re: Installing BPEL plugin [message #5106 is a reply to message #4764] Fri, 23 June 2006 13:36 Go to previous messageGo to next message
Originally posted by: kroyce.ups.edu
I ran into the same problem and found out you must install eclipse
version 3.2RC7 first... I had to uninstall my existing eclipse version
prior to installing v3.2RC7.
Kevin
University of Puget Sound
www.ups.edu
-----Original Message-----
From: Ron Ridenour [mailto:ronaldmridenour@yahoo.com]
Posted At: Wednesday, May 24, 2006 4:06 PM
Posted To: eclipse.technology.bpel-designer
Conversation: Installing BPEL plugin
Subject: Re: Installing BPEL plugin
lipse.wst.common_core.feature_1.0.100.v200602152251--jXOWXVW 2X.jar
Re: Installing BPEL plugin [message #5244 is a reply to message #5106] Fri, 23 June 2006 14:03 Go to previous message
Hmmm... I just noticed how old this posting was. I hope you found your
answer before now.
Kevin Royce
www.ups.edu
Posted At: Friday, June 23, 2006 10:37 AM
Kevin
www.ups.edu
Previous Topic:General status update?
Next Topic:BPEL Designer Project
Current Time: Tue Jul 15 14:23:37 EDT 2025
Powered by FUDForum. Page generated in 0.07094 seconds
