Home » Language IDEs » Java Development Tools (JDT) » "Initializing Java Tooling" Error(Error Problems in Eclipse)
"Initializing Java Tooling" Error [message #511122] Fri, 29 January 2010 19:42 Go to next message
I have tried to reinstall Eclipse to get rid of this error, but whenever I start up Eclipse I get the following:
An internal error occurred during "Initializing Java Tooling"
Illegal UTF8 string in constant pool in class file org/eclipse/jdt/internal/core/search/BasicSearchEngine
I am on Ubuntu 9.10 using the latest version of Eclipse. Please let me know how I can fix this.
Re: "Initializing Java Tooling" Error [message #511124 is a reply to message #511122] Fri, 29 January 2010 16:32 Go to previous messageGo to next message
What VM are you using ?
Olivier
Re: "Initializing Java Tooling" Error [message #511125 is a reply to message #511124] Fri, 29 January 2010 21:48 Go to previous messageGo to next message
Re: "Initializing Java Tooling" Error [message #511152 is a reply to message #511125] Sat, 30 January 2010 09:32 Go to previous messageGo to next message
Le 2010-01-29 21:48, Susie a écrit :
> 1.6.0.16
Can you check the checksum of the file you downloaded?
It looks like a corrupted file.
Olivier
Re: "Initializing Java Tooling" Error [message #511154 is a reply to message #511152] Sat, 30 January 2010 10:03 Go to previous messageGo to next message
Hm...I don't think so. I shouldn't still have the file, because I installed it quite a long time ago (say six months), and it only started acting up yesterday.
Re: "Initializing Java Tooling" Error [message #511197 is a reply to message #511154] Sat, 30 January 2010 17:42 Go to previous messageGo to next message
"Susie" <seuzy8@gmail.com> wrote in message
news:hk1hp1$i4g$1@build.eclipse.org...
I wonder if there is a problem with your hard disk? It certainly does sound
like a file (the jdt.core plugin jar) has gotten corrupted.
Re: "Initializing Java Tooling" Error [message #511207 is a reply to message #511197] Sat, 30 January 2010 19:42 Go to previous message
That's what the error message seemed to imply, and I thought reinstalling it would help, but it did not...
Any suggestions?
Previous Topic:Eclipse Spring & Hibernate Dev Environment
Next Topic:Triggering further build
Current Time: Mon Jul 07 10:59:18 EDT 2025
Powered by FUDForum. Page generated in 0.51003 seconds
