Home » Eclipse Projects » Plugin Development Environment (PDE) » Problem adding an extension point
Problem adding an extension point [message #51659] Tue, 24 March 2009 02:36 Go to next message
Hi to everybody,
I've installed latest version of Ganymede RCP/Plugin from eclipse web site
but I've a probrem trying to creare a plugin with an extension: In
"Extensions" tab of MANIFEST editor window I added the
org.eclipse.cdt.core.BinaryParser extension point but if I try to right
click on added item to add my extension, a popup containing only "Generic"
entry is shown. I've tryed with others extension points with the same
result. Can somebody tell me where is my mistake? Isn't it the right way
to create a plugin that extends eclipse components ?
Thank you in advance.
Simone Navari.
Re: Problem adding an extension point [message #51680 is a reply to message #51659] Tue, 24 March 2009 07:03 Go to previous message
Simone Navari wrote:
> Hi to everybody,
> site but I've a probrem trying to creare a plugin with an extension: In
> "Generic" entry is shown. I've tryed with others extension points with
> the same result. Can somebody tell me where is my mistake? Isn't it the
> right way to create a plugin that extends eclipse components ?
> Simone Navari.
I haven't worked with CDT, but tried this extension point and got the same result as you are getting.
However, on searching for usage of this ext pt., I found this in one plugin.xml
<extension
id="MachO"
name="%MachOParser.name"
point="org.eclipse.cdt.core.BinaryParser">
<cextension>
<run
class="org.eclipse.cdt.utils.macho.parser.MachOParser">
</run>
</cextension>
</extension>
May be you can extend it in similar fashion.
hope that helps,
Ankur..
Re: Problem adding an extension point [message #593851 is a reply to message #51659] Tue, 24 March 2009 07:03 Go to previous message
> Hi to everybody,
> Simone Navari.
<extension
id="MachO"
<cextension>
<run
</run>
</cextension>
</extension>
hope that helps,
Ankur..
Previous Topic:Problem adding an extension point
Next Topic:Custom Project Problem
Current Time: Fri Jul 18 22:51:55 EDT 2025
Powered by FUDForum. Page generated in 0.03064 seconds
