Home » Modeling » M2T (model-to-text transformation) » JET tag to Check if file exists
JET tag to Check if file exists [message #51640] Mon, 06 October 2008 07:58 Go to next message
I need to check if a file exists in a project in the eclipse
workspace/file system .
If file does not exist, I need to create file which can be done using
<ws:file> .
If file exist,I will be loading it using <c:load> tag.
I could not find a JET tag that meets this requirement. Pls let me know if
there is Jet tag for the same.
I had used java scriptlet code for this reqt.
However,I am not able to get the eclipse workspace path dynamically.
My code snippet is below:
<\%@ page import="java.io.*" %>
<% int i=0;
java.io.File file = new java.io.File("..");
try{
java.io.File file1 = new
java.io.File(file.getCanonicalPath()+" FA/projects/credentials/credentials-business-service/src/mai n/resources/serviceContext.xml ");
boolean b = file1.exists();
String s=file.getCanonicalPath();
String s1=file.getAbsolutePath();
System.out.println("file1 can pth "+file.getCanonicalPath());%>
<c:log> can path is <%=s%> and abs <%=s1%> </c:log>
<% if(b){
System.out.print("exists");
<c:load
url=" credentials/credentials-business-service/src/main/resources/ serviceContext.xml "
urlContext="workspace" var="oldSpringContext"/>
file.getCanonicalPath() gives the root hard disk drive name(like C:).
I have hardcoded the workspace to FA/projects which is workspace .
Is there a method to get the workspace path dynamically.
Pls let me know asap.
Justin.
Re: JET tag to Check if file exists [message #51657 is a reply to message #51640] Mon, 06 October 2008 09:08 Go to previous messageGo to next message
Hey,
imho, there is no xpath-function or tag for that functionality.
Either do it via Scriplet or implement your own function by using the
extension points. For the localization of the resources in the workspace,
have a look at the following link:
http://lmap.blogspot.com/2008/03/platform-scheme-uri.html
May be this helps.
Adios
Timothy
"justin " <justin_prabhu@yahoo.com> schrieb im Newsbeitrag
news:9b0af99a93c24fbdb0145ac20a20d169$1@www.eclipse.org...
> <ws:file> .
> <\%@ page import="java.io.*" %> <% int i=0;
> try{ java.io.File file1 = new
> <% if(b){
> <c:load
> I have hardcoded the workspace to FA/projects which is workspace . Is
> Justin.
Re: JET tag to Check if file exists [message #51735 is a reply to message #51657] Mon, 06 October 2008 09:41 Go to previous message
Justin, Timothy:
A couple of possibilities:
1) Detect the file with the 'org.eclipse.jet.resource' loader
<%-- this 'loads' the parent. Here $parent is an IResource --%>
<c:load var="parent" url="workspace relative path to parent"
urlContext="worksapce" loader="org.eclipse.jet.resource" />
<c:if test=" $parent/file[@name = ' the file name']" >
<%-- file exists --%>
</c:if>
The more obvious approach of using the actual file as an URL doesn't work,
as the loader will through an exception. You could still use the approach,
and then check for the non-existence of the variable, but then this isn't
much different than the above in temps of amount of code.
2) Use the replace='false' attribute to avoid overwritting some existing
files. The 'replace' attribute on ws:file and java:class checks for file
existance. If set to 'false', then if the file already exists, the template
is not run, and the results are not written. I'm not sure that it will help
in your situation, though.
3) Creating a conditional tag (e.g. <mylib:fileExists path="..."> ... handle
exists ...</mylib:fileExists> would be fairly easy. An XPath funciton might
be a bit more code (because you need to fiddle a bit to get the function
arguments, but is also pretty easy). If you feel that such a function would
be generally useful, feel free to submit a bugzilla. And, even better than a
bugzilla is attaching an implementation - provided your employer approves,
of course.
Paul
"Timothy Marc" <timothymarc@freenet.de> wrote in message
news:gcd2g5$iks$1@build.eclipse.org...
> Hey,
> May be this helps.
> Adios
> Timothy
>> <ws:file> .
>> if there is Jet tag for the same.
>> <% if(b){
>> <c:load
>> Regards,
>> Justin.
Previous Topic:Error when setting "xsi:schemaLocation" attribute
Next Topic:JET var in scriptlets
Current Time: Thu May 08 02:31:50 EDT 2025
Powered by FUDForum. Page generated in 0.05711 seconds
