Home » Language IDEs » AspectJ » Inpath jar not getting weaved
Inpath jar not getting weaved [message #51609] Tue, 17 May 2005 09:58 Go to next message
Originally posted by: mgoodwin.equitrust.com
I am using ajdt 3.1m6 build. I built the project yesterday and the inpath
jar was set and it correctly weaved the jar. Today, it won't. Did I ding
some setting file. Can you point me in the right direction to fix.
Matt
Re: Inpath jar not getting weaved [message #51629 is a reply to message #51609] Tue, 17 May 2005 11:43 Go to previous messageGo to next message
The aspects are not weaved in eclipse3.0 either. I am able to
successfully weave the jar with eclipse2.1. Not sure what is going on. I
believe I was able to weave in eclipse3.1 yesterday. Maybe there was a
problem with the aj project builder conversion. Has anyone else run into
this?
Re: Inpath jar not getting weaved [message #51724 is a reply to message #51629] Wed, 18 May 2005 06:24 Go to previous messageGo to next message
> this?
Which build of AJDT was this? There was an inpath related fix that went in
recently. Please could you try AJDT 1.2.0RC1 on Eclipse 3.0 and see if the
problem still exists there. There will be a development build for Eclipse
3.1M6 with the same fixes available shortly (check the download page).
Matt.
Matt Chapman
AJDT Development, http://www.eclipse.org/ajdt
Re: Inpath jar not getting weaved [message #51943 is a reply to message #51724] Fri, 20 May 2005 11:47 Go to previous messageGo to next message
Thanks a bunch. I downloaded the rc1 and was able to weave the Inpath
jar. Kudos on the migration wizard as well!!!!!
Re: Inpath jar not getting weaved [message #51993 is a reply to message #51943] Fri, 20 May 2005 12:12 Go to previous message
One last small thing. It does not appear that the inPath jar weaving info
messages get output to the problems view when that is checked. Not a big
deal, but just curious if anyone else was seeing this behavior.
Matt
Re: Inpath jar not getting weaved [message #588109 is a reply to message #51609] Tue, 17 May 2005 11:43 Go to previous message
this?
Re: Inpath jar not getting weaved [message #588146 is a reply to message #51629] Wed, 18 May 2005 06:24 Go to previous message
> this?
Matt.
Matt Chapman
Re: Inpath jar not getting weaved [message #588257 is a reply to message #51724] Fri, 20 May 2005 11:47 Go to previous message
Re: Inpath jar not getting weaved [message #588282 is a reply to message #51943] Fri, 20 May 2005 12:12 Go to previous message
Matt
Previous Topic:Aspects across (Eclipse) projects
Next Topic:bug 86832?
Current Time: Sat Oct 25 03:27:41 EDT 2025
Powered by FUDForum. Page generated in 0.05556 seconds
