Home » Eclipse Projects » Nebula » Date selection widgets and DataBinding
Date selection widgets and DataBinding [message #51566] Mon, 14 April 2008 18:55 Go to next message
Originally posted by: tskaufma.gmail.com
I am wondering whether any of the various date selecting Nebula widgets
support databinding.
CDateTime, DateChooser(Combo), and others provide nice looking date
selection, but is it possible to use Eclipse Databinding with these widgets?
Trevor
Re: Date selection widgets and DataBinding [message #51653 is a reply to message #51566] Tue, 15 April 2008 06:43 Go to previous messageGo to next message
Hi Trevor,
I'm not aware of such a thing. I'd say let's file a bug against those
components. There 2 possibilities to proceed because you'll need
additional dependencies (org.eclipse.core.databinding and
org.eclipse.jface.databinding).
There are 2 possibilities:
a) Create a seperate plugin with the databinding stuff
b) Create a non-mandatory dependency in the MANIFEST.MF
I'd prefer a) but I think nebula-subcomponents have also used b) because
starting the work is much easier because you can simply produce patches
against the current CVS. If you filed a bug please CC and I can help you
with the my databinding knowledge.
Tom
Trevor Kaufman schrieb:
> Hello,
> widgets?
> Trevor
B e s t S o l u t i o n . at
Tom Schindl JFace-Committer
Re: Date selection widgets and DataBinding [message #51715 is a reply to message #51653] Sat, 19 April 2008 14:48 Go to previous messageGo to next message
It appears that CDateTime has databinding support.
This bug [https://bugs.eclipse.org/bugs/show_bug.cgi?id=177013] is the
enhancement request.
So I guess the question becomes is there any examples of this? How does it
work?
Trevor Kaufman
"Tom Schindl" <tom.schindl@bestsolution.at> wrote in message
news:fu20sl$jpr$1@build.eclipse.org...
> Hi Trevor,
> Tom
>> Hello,
>> widgets?
>> Thanks,
>> Trevor
Re: Date selection widgets and DataBinding [message #51864 is a reply to message #51653] Wed, 23 April 2008 13:01 Go to previous messageGo to next message
Last I heard wasn't Nebula against using JFace dependencies? Just checking,
or I wouldn't mind implementing for CalendarCombo, but I recall when I
submitted the widgets I had to remove all JFace code and rework it to use
pure SWT...
Emil Crumhorn
Nebula Committer
http://www.hexapixel.com/
> Hi Trevor,
> Tom
>> Hello,
>> widgets?
>> Thanks,
>> Trevor
Re: Date selection widgets and DataBinding [message #51942 is a reply to message #51864] Wed, 23 April 2008 18:27 Go to previous messageGo to next message
Well the plain widget yes but if nebula provides e.g. Viewers (like Grid
and Gallery do you need to have an at least optional dependency on JFace
and the same would IMHO apply if you want to provide obervables).
Tom
> pure SWT...
Re: Date selection widgets and DataBinding [message #52046 is a reply to message #51715] Sun, 27 April 2008 18:08 Go to previous messageGo to next message
CDateTime does support DataBinding, and I have been using it this way
for about a year. Simply instantiate a CDateTimeObservableValue for the
target side of the binding and use a java.util.Date type model. There
is also a CDateTimeCellEditor for use with Tables, Trees, or Grids.
FYI, I've been terrible about producing binary builds. The CVS version
has a number of stability and API improvements.
Peter
Re: Date selection widgets and DataBinding [message #52071 is a reply to message #52046] Sun, 27 April 2008 21:59 Go to previous message
Thank you for the information.
I planned on getting a CVS copy since the widget isn't packaged as a plugin
(at least the last binary download I found).
Trevor
"Peter Centgraf" <peter@centgraf.net> wrote in message
news:fv2tgu$t3k$1@build.eclipse.org...
> CDateTime does support DataBinding, and I have been using it this way for
> target side of the binding and use a java.util.Date type model. There is
> Peter
Re: Date selection widgets and DataBinding [message #589338 is a reply to message #51566] Tue, 15 April 2008 06:43 Go to previous message
Hi Trevor,
Tom
> Hello,
> widgets?
> Trevor
Re: Date selection widgets and DataBinding [message #589371 is a reply to message #51653] Sat, 19 April 2008 14:48 Go to previous message
work?
Trevor Kaufman
> Hi Trevor,
> Tom
>> Hello,
>> widgets?
>> Thanks,
>> Trevor
Re: Date selection widgets and DataBinding [message #589416 is a reply to message #51653] Wed, 23 April 2008 13:01 Go to previous message
pure SWT...
Emil Crumhorn
Nebula Committer
> Hi Trevor,
> Tom
>> Hello,
>> widgets?
>> Thanks,
>> Trevor
Re: Date selection widgets and DataBinding [message #589438 is a reply to message #51864] Wed, 23 April 2008 18:27 Go to previous message
Tom
> pure SWT...
Re: Date selection widgets and DataBinding [message #589475 is a reply to message #51715] Sun, 27 April 2008 18:08 Go to previous message
Peter
Re: Date selection widgets and DataBinding [message #589483 is a reply to message #52046] Sun, 27 April 2008 21:59 Go to previous message
Trevor
> Peter
Previous Topic:Disposing of items in the Gallery
Next Topic:3.2.2 Compatible Release
Current Time: Tue Jul 22 12:11:29 EDT 2025
Powered by FUDForum. Page generated in 0.06628 seconds
