Home » Eclipse Projects » GEF » Need help: Problem with Deployment
Need help: Problem with Deployment [message #51557] Mon, 30 December 2002 08:12 Go to next message
Originally posted by: assisi2000.yahoo.com
I tried to deploy my plugin which is working very well in the
runtime-workbench.
I have done the following:
1. I created a feature-folder in eclipse/features in the same way like
the logic example
2. I created a plugin-folder in eclipse/features in the same way like
the logic example
3. I exported all my class-files & resources to a jar to the
pulgin-folder/runtime
4. I restarted eclipse
5. I got the message that there is a new update
6. I installed it (it looked as if it would be a success)
7. When I tried to acces my plugin with files/new I got the right wizard
8. after the creation of the file I get alwas the following message:
java.lang.NoClassDefFoundError: org/eclipse/gef/internal/SharedImages
The features.xml has the following entry:
<requires>
<import plugin="org.eclipse.gef" version="2.0.1"
match="compatible"/>
</requires>
So I dont understand what is wrong.
I use JRE1.4. Is this the problem?
Who can help?
Re: Need help: Problem with Deployment [message #51580 is a reply to message #51557] Mon, 30 December 2002 09:46 Go to previous messageGo to next message
Originally posted by: hudsonr.us.eye-bee-em.com
The internal packages are not visible at runtime (and shouldn't be when
develop your plugin). It is a limitation of Eclipse that when developing a
pluging, the runtime class visibility is not reproduced.
Which Images do you need access to?
"exquisitus" <assisi2000@yahoo.com> wrote in message
news:aupg11$m7k$1@rogue.oti.com...
> runtime-workbench.
> the logic example
> the logic example
> <requires>
> </requires>
> Who can help?
Re: Need help: Problem with Deployment [message #51620 is a reply to message #51580] Mon, 30 December 2002 11:46 Go to previous messageGo to next message
Thank you. Now I understood. The reason was, that I tried to implement also
the resizing of width and heigth.
Theirfore I copied the AlignmentAction and changed it. But still I dont
understand why it works in the
runtime-workspace. But this is not important any more.
Now onother question. Is this very common function paned or implemented in
GEF?
Ramin
"Randy Hudson" <hudsonr@us.eye-bee-em.com> schrieb im Newsbeitrag
news:auplos$p54$1@rogue.oti.com...
a
> > runtime-workbench.
> > the logic example
> > the logic example
> > <requires>
> > </requires>
> > Who can help?
Re: Need help: Problem with Deployment [message #51696 is a reply to message #51580] Mon, 30 December 2002 12:09 Go to previous messageGo to next message
I have still have deployment problems:
1. I tried to calculate the PluginDirectory. But I also made the mistake to
use internal package.
Is there another way?
PluginDescriptor descriptor =
(PluginDescriptor)V4EPlugin.getDefault().getDescriptor();
v4eLocation = descriptor.getLocation();
2. The same with the acces to the TreeViewer for the parts (to scan it)
public PackageExplorerPart getPackageExplorer(){
return PackageExplorerPart.getFromActivePerspective();
what would be the alternative?
Thanks for help and happy new year.
Ramin
a
> > runtime-workbench.
> > the logic example
> > the logic example
> > <requires>
> > </requires>
> > Who can help?
Re: Need help: Problem with Deployment [message #51777 is a reply to message #51620] Wed, 01 January 2003 19:13 Go to previous messageGo to next message
news:aupsii$sfe$1@rogue.oti.com...
also
> GEF?
Are you asking for "Match Width" "Match Height"?
> Ramin
developing
> a
> > > runtime-workbench.
> > > the logic example
> > > the logic example
wizard
> > > <requires>
> > > </requires>
> > > Who can help?
Re: Need help: Problem with Deployment [message #51805 is a reply to message #51696] Wed, 01 January 2003 19:15 Go to previous message
news:auptt0$t4i$1@rogue.oti.com...
to
You should consider anything not available programmatically as internal
also. If you are trying to get to the Icon via its resource, you may be
broken in a future build.
I don't understand which icon could be reused to represent "match width".
> Ramin
developing
> a
> > > runtime-workbench.
> > > the logic example
> > > the logic example
wizard
> > > <requires>
> > > </requires>
> > > Who can help?
Previous Topic:adding connections to the TreeViewer
Next Topic:Question about Figure.translateToAbsolute/translateToRelative
Current Time: Wed Jul 16 16:54:35 EDT 2025
Powered by FUDForum. Page generated in 0.46956 seconds
