Automatically expanding node tree when opening workflow/task description [message #51549] |
Tue, 24 June 2008 14:19  |
Originally posted by: jhnewsgroup1.nebo-consulting.de
Hi!
In contrast to other sides the navigator tree in a published web site is not
in sync if I open a workflow page or after selecting a task description.
This means the auto expand and auto selection behavior doesn't work.
Is there a possibilty (by code-customizing) to change this behavior? I've
already tried to adapt the common known .js scripts by setting the global
values or setting the hastree parameter. May be an automatic call of whoamI
function would be a solution?
Thank you for your answers
Best regards
Juergen
FUDForum. Page generated in 0.11728 seconds
