Home » Eclipse Projects » Eclipse Platform » ImageDescriptor.createFromFile
ImageDescriptor.createFromFile [message #51491] Wed, 28 May 2003 06:14 Go to next message
Originally posted by: gg.decisionsoft.com
I'm trying to load a gif from my icons directory.
The problem I have is that I'm trying to use
ImageDescriptor.createFromFile yet the documentation for the method is
confusing, specifically the location parameter:
location - the class whose resource directory contain the file
How does a Class relate to a resource directory?
Geoff.
Re: ImageDescriptor.createFromFile [message #52154 is a reply to message #51491] Wed, 28 May 2003 12:06 Go to previous messageGo to next message
Yeah, I too found that kind of confusing when I was first trying to get
Images to work in Eclipse. The phrase seems to mean something like "the
actual directory of the class-file of the class". Here is what we did
that works:
a) put all icons in a directory called "icons" (or whatever) that itself
is directly under our eclipse/workspace/com.foo.ourprojectname directory
(that com.foo.ourprojectname directory is the one that Eclipse wants to
create for your plugin project)
b) refer to every icon via a path (String) of this form
"icons/myGifThatLooksCool.gif"
c) use this code (where the class YourPlugin_Plugin is created by Eclipse
in your
eclipse/workspace/com.foo.ourprojectname/src/com/foo/ourproj ectname
directory):
public static ImageDescriptor getImageDescriptor (final String
fileName) {
final URL installURL =
YourPlugin_Plugin.getDefault().getDescriptor().getInstallURL ();
try {
final URL url = new URL(installURL, fileName);
return ImageDescriptor.createFromURL(url);
catch (MalformedURLException mue) {
reportError(
"getImageDescriptor(): couldn't find image: "
+ installURL
+ fileName);
return null;
HTH,
Paul K
> Geoff.
Re: ImageDescriptor.createFromFile [message #52234 is a reply to message #52154] Wed, 28 May 2003 13:54 Go to previous message
Originally posted by: richkulp.NOSPAM.us.ibm.com
The phrase refers to the way resources should be loaded in Java. It uses
Class.getResourceAsStream(String filename). Look this up in Java and
you'll see how it works. This is for loading resources which are in your
class path (and jars).
Previous Topic:[ANN] Ant Script for install/update Eclipse
Next Topic:[Team] Eclipse spontaneously unable to connect to host
Current Time: Mon Jul 14 05:30:24 EDT 2025
Powered by FUDForum. Page generated in 0.03114 seconds
