Home » Language IDEs » ServerTools (WTP) » Help - Installation problems
Help - Installation problems [message #51471] Tue, 02 November 2004 15:13 Go to next message
Originally posted by: jeffmil.us.ibm.com
Folks, I've downloaded and unzipped both wtp-1.0M1.zip and
wtp-wst-1.0M1.zip and restarted Eclipse. I see nothing relate to Web
tools anywhere in the application. Is there something else I have to do
in the install?
Thanks alot,
<WS-Jeff>
jeffmil@us.ibm.com
Re: Help - Installation problems [message #51498 is a reply to message #51471] Tue, 02 November 2004 17:47 Go to previous messageGo to next message
Originally posted by: jmordax.terra.es
First of all, you just need wtp-1.0M1.zip (which includes
wtp-wst-1.0M1.zip).
Once you have installed that file, start Eclipse R3.0.1, go to: Help ->
Software Updates -> Manage Configuration... and make sure that the
feature is enabled.
Then, go to File -> New -> Other and make sure you have two folders
called: J2EE and Servers.
Please, notice that WTP M1 hasn't the functuonality needed to work on
J2EE projects.... so you won't see a JSP editor o a EJB wizard yet. But
things are moving.....
Chemi.
> do in the install?
> Thanks alot,
> <WS-Jeff>
> jeffmil@us.ibm.com
Re: Help - Installation problems [message #51546 is a reply to message #51498] Wed, 03 November 2004 08:08 Go to previous messageGo to next message
Chemi, that was it. I had looked there before and didn't see anything
related. But then I saw I had to show the disabled features and then I
could see the WTP stuff. And after enabling it I could see the
functionality in Eclipse. I have a few duplicate Preferences entries
around Servers and Web but I will clear that one up later. Thanks for
your help!
</WS-Jeff>
> wtp-wst-1.0M1.zip).
> feature is enabled.
> Chemi.
>> do in the install?
>> Thanks alot,
>> <WS-Jeff>
>> jeffmil@us.ibm.com
Re: Help - Installation problems [message #52244 is a reply to message #51471] Mon, 08 November 2004 09:17 Go to previous messageGo to next message
> in the install?
> Thanks alot,
> <WS-Jeff>
> jeffmil@us.ibm.com
Hi,i encounter this problem too.Anyone else can give me some advises?There
is nothing about install and usage in the webpage of WTP.
Hello,friend from world of eclipse.I am a new-bie in the world of java and
eclipse.I need your help to improve my ability and make the java world
better and stronger.
Re: Help - Installation problems [message #52297 is a reply to message #51546] Mon, 08 November 2004 09:49 Go to previous messageGo to next message
> your help!
> </WS-Jeff>
>> wtp-wst-1.0M1.zip).
>> feature is enabled.
>> Regards,
>> Chemi.
>>> do in the install?
>>> Thanks alot,
>>> <WS-Jeff>
>>> jeffmil@us.ibm.com
Very thanks your help,Chemi.I'm just forgotten that eclipse sometimes should
disable new features installed.
Thanks again.
Re: Help - Installation problems [message #53245 is a reply to message #51498] Sun, 14 November 2004 12:05 Go to previous messageGo to next message
Originally posted by: sam.psfdevrip-it.com
"Chemi" <jmordax@terra.es> wrote in message news:cm92qh$ad$1@eclipse.org...
> wtp-wst-1.0M1.zip).
> Software Updates -> Manage Configuration... and make sure that the feature
> is enabled.
> Please, notice that WTP M1 hasn't the functuonality needed to work on J2EE
> projects.... so you won't see a JSP editor o a EJB wizard yet. But things
> are moving.....
> Chemi.
Sorry for jumping in the middle of this thread.
I have wtp-1.0M1.zip. Do I unzip it into the root directory of my Eclipse
install? The rest of your instructions look pretty straightforward.
I use WebSphere at work and just downloaded and installed Eclipse
yesterday. All I can say so far is FANTASTIC! This will make testing code,
projects, etc. at home much more seamless!
SamMan
Rip it to reply
Re: Help - Installation problems [message #53302 is a reply to message #53245] Mon, 15 November 2004 04:16 Go to previous messageGo to next message
The zip file should contain an eclipse dircetory with other two
directories: \plugins and \features; you should copy \plugins content in
top of your current \plugin dircetory and the same thing with \features one.
Hope this helps,
Chemi.
Webtools and OC4J [message #65939 is a reply to message #53302] Tue, 18 January 2005 07:55 Go to previous messageGo to next message
Hi all,
I'm quite sure I will get beaten for stupidity after this mail but:
I'm using Eclipse 3.1M4 with WTP version M2 ??? maybe M3 I deleted the
zip file and have not been able to discover the version of WTP... the
pluginlist shows 1.0.0...
To my Question... everything seems to work fine with tomcat... but I
don't want to use catalina... I need an working oc4j version... so I
copied the bea-serverfile to oc4j.server in:
${eclipse.home}/plugins/org.eclipse.jst.server.generic.core_ 1.0.0
after that I edited the file to the values I think should fit for oc4j
(start, shutdown and un-/deploly options) I'm quite sure my server-specs
will work but it doesn't even show up in the "Generic Server Runtime"
list and the "search for new server runtime" doesn't even recognize
oc4j.jar as a runtime...
So my question is:
How can I add a new server runtime by hand?!
Thnx in advance...
Re: Webtools and OC4J ... nearly?! solved [message #65994 is a reply to message #65939] Tue, 18 January 2005 12:06 Go to previous message
Hi again,
and sorry for the double posting...
now I got the OC4J to display in the List... I also get Errors on start
ing when an other instance is already running on the same port and
stuff... but I can't get the thing to keep up after it started it
immediatly shuts down... anyone got the webtools running with oc4j?!?!
thnx
Previous Topic:Eclipse WebTools presentation - Portland Java User Group
Next Topic:Debugging JSPs
Current Time: Wed Jul 16 22:14:54 EDT 2025
Powered by FUDForum. Page generated in 0.26589 seconds
