Home » Archived » BIRT » Viewer works only after restarting Eclipse
Viewer works only after restarting Eclipse [message #51409] Fri, 24 June 2005 16:03 Go to next message
Originally posted by: gauravengg.hotmail.com
when i make a report and run it on preview tab..it gives me this error...
Cannot open the connection for the driver (jdbc)
I am connecting to db2
But when i Restart the eclipse..it works fine all the way...and everything
works
think there is problem with cache in eclipse for plugins lik BIRT
any suggestions to get around this problem would be greatly appreciated..
thanx a lot
Re: Viewer works only after restarting Eclipse [message #51437 is a reply to message #51409] Fri, 24 June 2005 17:33 Go to previous message
Wal,
The Birt Viewer instanciates the Birt Engine object as a singlton, which
will build up a registry of all available plugins with in the viewer's
"WEB-INF/plugins" directory. If you adding more stuff after engine get
initialized, they will be ignored until a new instnace be obstained. In
this case, you have to restart the eclipse since we don't provide UI
control to restart the embedded tomcat.
Jun Zhai
Previous Topic:How to deploy a report with a chart?
Next Topic:setEngineHome in web app
Current Time: Mon Jul 21 21:34:57 EDT 2025
Powered by FUDForum. Page generated in 6.96441 seconds
