Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » Teneo : Problem with Library Editor Tutorial
Teneo : Problem with Library Editor Tutorial [message #51378] |
Thu, 21 September 2006 04:36  |
Originally posted by: nrobin.irisa.fr
Hi Martin,
We wanted to switch our application, that was working fine with Elver
Store, to Teneo. We experienced problems ("NoClassDefFound" errors
loading Dom4J classes) so we decided to return to the Library Editor
Tutorial. And it doesn't seem to work with us. The EMF part of the
tutorial is working fine but when we add the Teneo code, we're having
this error message :
"Problem Opening Wizard"
"The selected wizard could not be started.
Reason:
Plug-in library.editor was unable to load class
org.eclipse.example.library.presentation.LibraryModelWizard"
And here is the stack trace we got from catching the exception :
"org.hibernate.MappingException: Could not determine type for:
org.eclipse.emf.teneo.hibernate.mapping.econtainer.EContaine rUserType,
for columns: [org.hibernate.mapping.Column(econtainer_class),
org.hibernate.mapping.Column(e_container)]
at org.hibernate.mapping.SimpleValue.getType(SimpleValue.java:2 66)
at org.hibernate.mapping.SimpleValue.isValid(SimpleValue.java:2 53)
at org.hibernate.mapping.Property.isValid(Property.java:185)
org.hibernate.mapping.PersistentClass.validate(PersistentCla ss.java:399)
at org.hibernate.mapping.RootClass.validate(RootClass.java:192)
at org.hibernate.cfg.Configuration.validate(Configuration.java: 1026)
org.hibernate.cfg.Configuration.buildSessionFactory(Configur ation.java:1211)
org.eclipse.emf.teneo.hibernate.HbDataStore.buildSessionFact ory(HbDataStore.java:474)
org.eclipse.emf.teneo.hibernate.HbDataStore.initialize(HbDat aStore.java:187)
org.eclipse.example.library.presentation.LibraryEditorPlugin $Implementation.start(LibraryEditorPlugin.java:119)
org.eclipse.osgi.framework.internal.core.BundleContextImpl$2 .run(BundleContextImpl.java:995)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:989)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:970)
org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:317)
org.eclipse.osgi.framework.internal.core.AbstractBundle.star t(AbstractBundle.java:256)
org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter .preFindLocalClass(EclipseLazyStarter.java:86)
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClass(ClasspathManager.java:409)
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.fin dLocalClass(DefaultClassLoader.java:188)
org.eclipse.osgi.framework.internal.core.BundleLoader.findLo calClass(BundleLoader.java:339)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:391)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:352)
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:83)
at java.lang.ClassLoader.loadClass(ClassLoader.java:251)
org.eclipse.osgi.framework.internal.core.BundleLoader.loadCl ass(BundleLoader.java:276)
org.eclipse.osgi.framework.internal.core.BundleHost.loadClas s(BundleHost.java:227)
org.eclipse.osgi.framework.internal.core.AbstractBundle.load Class(AbstractBundle.java:1245)
org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI .createExecutableExtension(RegistryStrategyOSGI.java:147)
org.eclipse.core.internal.registry.ExtensionRegistry.createE xecutableExtension(ExtensionRegistry.java:759)
org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:243)
org.eclipse.core.internal.registry.ConfigurationElementHandl e.createExecutableExtension(ConfigurationElementHandle.java: 51)
org.eclipse.ui.internal.WorkbenchPlugin$1.run(WorkbenchPlugi n.java:242)
org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:67)
org.eclipse.ui.internal.WorkbenchPlugin.createExtension(Work benchPlugin.java:238)
org.eclipse.ui.internal.dialogs.WorkbenchWizardElement.creat eExecutableExtension(WorkbenchWizardElement.java:117)
org.eclipse.ui.internal.dialogs.WorkbenchWizardElement.creat eWizard(WorkbenchWizardElement.java:261)
org.eclipse.ui.internal.dialogs.NewWizardNewPage$6.createWiz ard(NewWizardNewPage.java:766)
org.eclipse.ui.internal.dialogs.WorkbenchWizardNode$2.run(Wo rkbenchWizardNode.java:148)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
at org.eclipse.core.runtime.Platform.run(Platform.java:843)
org.eclipse.ui.internal.dialogs.WorkbenchWizardNode$1.run(Wo rkbenchWizardNode.java:131)
org.eclipse.ui.internal.dialogs.WorkbenchWizardNode.getWizar d(WorkbenchWizardNode.java:128)
org.eclipse.jface.wizard.WizardSelectionPage.getNextPage(Wiz ardSelectionPage.java:104)
org.eclipse.ui.internal.dialogs.WorkbenchWizardSelectionPage .getNextPage(WorkbenchWizardSelectionPage.java:100)
org.eclipse.jface.wizard.WizardDialog.nextPressed(WizardDial og.java:751)
org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDi alog.java:351)
at org.eclipse.jface.dialogs.Dialog$3.widgetSelected(Dialog.jav a:660)
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:90)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:928)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3348)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2968)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:820 )
at org.eclipse.jface.window.Window.open(Window.java:796)
at org.eclipse.ui.actions.NewWizardAction.run(NewWizardAction.j ava:181)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:499 )
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:539)
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:488)
org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:400)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1914)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1878)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:419)
org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:95)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:78)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:92)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:68)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:400)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:177)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:336 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:280)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)"
We're using the Teneo version from the update site (0.7.5) and we
created a separated Hibernate plug-in with version 3.2.0 cr3.
We also have Eclipse 3.2.0, EMF 2.2.0 and a JDK 1.5.0_04.
Thanks for your help,
Nicolas ROBIN & Benoît LAMARCHE
Re: Teneo : Problem with Library Editor Tutorial [message #51588 is a reply to message #51378] |
Thu, 21 September 2006 10:51   |
Hi Nicolas,
My guess is that this is related to dependencies which are not resolved. In the hibernate plugin did
you export all (is the savest) hibernate java packages?
Did you check the reexport property of the dependency of the hibernate plugin in the model plugin?
gr. Martin
Nicolas Robin wrote:
> Hi Martin,
> Reason:
> at
> at
> at
> at
> at
> at
> at java.security.AccessController.doPrivileged(Native Method)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: Teneo : Problem with Library Editor Tutorial [message #51818 is a reply to message #51588] |
Fri, 22 September 2006 04:43   |
Hi Martin,
Thanks for your answer. We've restarted the Library Editor Tutorial from
scratch, in a new workspace and created a new Hibernate plug-in. We're
having the same error but a different stack trace.
In our Hibernate plug-in, we've added the hibernate3.jar and all the
jars that were in the "lib" directory, and we've exported each of them.
The reexport properties of the Hibernate and Teneo plug-ins dependencies
in the model plug-in are set. The "org/hibernate/mapping/Value" class
does exist in the hibernate jar. I don't understand what we did wrong.
Here is the new stack trace :
"java.lang.NoClassDefFoundError: org/hibernate/mapping/Value
org.eclipse.emf.teneo.hibernate.HbHelper$1.createHbDataStore (HbHelper.java:56)
org.eclipse.emf.teneo.hibernate.HbHelper.createRegisterDataS tore(HbHelper.java:150)
org.eclipse.example.library.presentation.LibraryEditorPlugin $Implementation.start(LibraryEditorPlugin.java:117)
at org.eclipse.ui.internal.WorkbenchPlugin$1.run(WorkbenchPlugi n.java:242)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:67)
org.eclipse.ui.internal.dialogs.NewWizardSelectionPage.advan ceToNextPageOrFinish(NewWizardSelectionPage.java:71)
org.eclipse.ui.internal.dialogs.NewWizardNewPage$1.doubleCli ck(NewWizardNewPage.java:364)
org.eclipse.jface.viewers.StructuredViewer$1.run(StructuredV iewer.java:796)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:44)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:14 9)
org.eclipse.jface.viewers.StructuredViewer.fireDoubleClick(S tructuredViewer.java:794)
org.eclipse.jface.viewers.AbstractTreeViewer.handleDoubleSel ect(AbstractTreeViewer.java:1216)
org.eclipse.jface.viewers.StructuredViewer$4.widgetDefaultSe lected(StructuredViewer.java:1158)
org.eclipse.jface.util.OpenStrategy.fireDefaultSelectionEven t(OpenStrategy.java:223)
at org.eclipse.jface.util.OpenStrategy.access$0(OpenStrategy.ja va:220)
at org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrate gy.java:281)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:95)
Thanks for your time
Martin Taal wrote :
> Hi Nicolas,
> In the hibernate plugin did you export all (is the savest) hibernate
> java packages?
> gr. Martin
>> Hi Martin,
>> Reason:
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>> at
>> at
Re: Teneo : Problem with Library Editor Tutorial [message #51871 is a reply to message #51818] |
Fri, 22 September 2006 07:14   |
Hi Nicolas,
When you add the import statement:
import org.hibernate.mapping.Value;
to the class: org.eclipse.example.library.presentation.LibraryEditorPlugin .
Does the compiler complain?
If the compiler complains, can you then check if the hibernate packages are exported in the runtime
tab of the hibernate plugin Manifest.MF?
Also the hibernate plugin must have this in the manifest.mf:
Eclipse-BuddyPolicy: dependent
Another eclipse-buddypolicy can work also. Although this is not related to this issue.
gr. Martin
> Hi Martin,
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at java.lang.ClassLoader.loadClass(Unknown Source)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Martin Taal wrote :
>> Hi Nicolas,
>> resolved. In the hibernate plugin did you export all (is the savest)
>> gr. Martin
>>> Hi Martin,
>>> Reason:
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
The Netherlands
Re: Teneo : Problem with Library Editor Tutorial [message #51899 is a reply to message #51871] |
Fri, 22 September 2006 07:51   |
When we add the import statement, there's no error. We had forgotten to
put the "Eclipse-BuddyPolicy: dependent" but it didn't change anything.
We still have the same error and stack trace.
Thanks for trying to help
Martin Taal wrote :
> Hi Nicolas,
> are exported in the runtime tab of the hibernate plugin Manifest.MF?
> to this issue.
> gr. Martin
>> Hi Martin,
>> from scratch, in a new workspace and created a new Hibernate plug-in.
>> We're having the same error but a different stack trace.
>> them. The reexport properties of the Hibernate and Teneo plug-ins
>> dependencies in the model plug-in are set. The
>> "org/hibernate/mapping/Value" class does exist in the hibernate jar. I
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> Martin Taal wrote :
>>> Hi Nicolas,
>>> gr. Martin
>>>> Hi Martin,
>>>> Elver Store, to Teneo. We experienced problems ("NoClassDefFound"
>>>> errors loading Dom4J classes) so we decided to return to the Library
>>>> Editor Tutorial. And it doesn't seem to work with us. The EMF part
>>>> of the tutorial is working fine but when we add the Teneo code,
>>>> we're having this error message :
>>>> Reason:
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
Re: Teneo : Problem with Library Editor Tutorial [message #51928 is a reply to message #51899] |
Fri, 22 September 2006 08:07   |
Hi Nicolas,
Okay, can you upload a screendump of the jars in your hibernate plugin as eclipse display it?
Can you comment out the teneo part in the editorplugin and just try some basic hibernate stuff such
as create a configuration and a SessionFactory? To see if that also fails.
gr. Martin
> Martin Taal wrote :
>> Hi Nicolas,
>> to the class:
>> packages are exported in the runtime tab of the hibernate plugin
>> Manifest.MF?
>> gr. Martin
>>> Hi Martin,
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> Martin Taal wrote :
>>>> Hi Nicolas,
>>>> gr. Martin
>>>>> Hi Martin,
>>>>> Library Editor Tutorial. And it doesn't seem to work with us. The
>>>>> EMF part of the tutorial is working fine but when we add the Teneo
>>>>> code, we're having this error message :
>>>>> Reason:
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
The Netherlands
Re: Teneo : Problem with Library Editor Tutorial [message #52115 is a reply to message #51928] |
Fri, 22 September 2006 09:44   |
We've tried to comment out all the teneo part and we only left this line
in the start() function : "Configuration cfg = new Configuration();". It
failed. I guess there's really a problem with our Hibernate plug-in.
Here is the screen dump (I hope this is what you wanted) :
http://www.onetwothreefour.info/screendump.gif
Martin Taal wrote :
> Hi Nicolas,
> basic hibernate stuff such as create a configuration and a
> gr. Martin
>> to put the "Eclipse-BuddyPolicy: dependent" but it didn't change
>> anything.
>> Martin Taal wrote :
>>> Hi Nicolas,
>>> to the class:
>>> Manifest.MF?
>>> gr. Martin
>>>> Hi Martin,
>>>> plug-in. We're having the same error but a different stack trace.
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> Martin Taal wrote :
>>>>> Hi Nicolas,
>>>>> gr. Martin
>>>>>> Hi Martin,
>>>>>> Reason:
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
Re: Teneo : Problem with Library Editor Tutorial [message #52168 is a reply to message #52115] |
Fri, 22 September 2006 10:00   |
Hi Nicolas,
You can also try the following: add the hibernate plugin directly to the edit plugin dependency (and
remove it from the model).
Or copy all the hibernate jars to the edit plugin and add the jars directly to the dependencies.
This is not to nice but maybe helps you to get further and diagnose the issue.
Btw, I will be away in about 30 minutes and will be back on monday evening.
gr. Martin
> Martin Taal wrote :
>> Hi Nicolas,
>> some basic hibernate stuff such as create a configuration and a
>> gr. Martin
>>> anything.
>>> Martin Taal wrote :
>>>> Hi Nicolas,
>>>> to the class:
>>>> Manifest.MF?
>>>> gr. Martin
>>>>> Hi Martin,
>>>>> the jars that were in the "lib" directory, and we've exported each
>>>>> of them. The reexport properties of the Hibernate and Teneo
>>>>> plug-ins dependencies in the model plug-in are set. The
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> Martin Taal wrote :
>>>>>> Hi Nicolas,
>>>>>> gr. Martin
>>>>>>> Hi Martin,
>>>>>>> Teneo code, we're having this error message :
>>>>>>> Reason:
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
The Netherlands
Re: Teneo : Problem with Library Editor Tutorial [message #59262 is a reply to message #59211] |
Wed, 25 October 2006 11:10   |
Hi Vijayan,
The tables are not present in the database, so they are not created by Hibernate. My experience is
that Hibernate will not stop if the database creation fails, the error is shown when you actually
try to use the tables.
Can you check the log why no tables are created (permission issue maybe?)?
Btw, there is a Teneo option to prevent schema update/creation: PersistenceOptions.UPDATE_SCHEMA
But as this is not part of the tutorial I don't think that you set that.
gr. Martin
Vijayan wrote:
> Hi Martin,
> Thanks that problem is solved.
> I am getting the following error now.
> org.eclipse.emf.teneo.hibernate.HbStoreException: Exception when saving
> resource library
> at
> org.eclipse.emf.teneo.hibernate.resource.HibernateResource.l oadResource(HibernateResource.java:245)
> at
> org.eclipse.emf.teneo.resource.StoreResource.load(StoreResou rce.java:236)
> at
> org.eclipse.emf.teneo.resource.StoreResource.getContents(Sto reResource.java:347)
> at
> org.eclipse.example.library.presentation.LibraryModelWizard$ 1.execute(LibraryModelWizard.java:214)
> at
> org.eclipse.ui.actions.WorkspaceModifyOperation$1.run(Worksp aceModifyOperation.java:101)
> at
> org.eclipse.core.internal.resources.Workspace.run(Workspace. java:1737)
> at
> org.eclipse.ui.actions.WorkspaceModifyOperation.run(Workspac eModifyOperation.java:113)
> at
> org.eclipse.jface.operation.ModalContext.runInCurrentThread( ModalContext.java:369)
> at org.eclipse.jface.operation.ModalContext.run(ModalContext.ja va:313)
> at org.eclipse.jface.wizard.WizardDialog.run(WizardDialog.java: 851)
> at
> org.eclipse.example.library.presentation.LibraryModelWizard. performFinish(LibraryModelWizard.java:245)
> at
> org.eclipse.jface.wizard.WizardDialog.finishPressed(WizardDi alog.java:680)
> at
> org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDi alog.java:355)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Caused by: org.hibernate.exception.SQLGrammarException: could not
> execute query
> at
> org.hibernate.exception.SQLStateConverter.convert(SQLStateCo nverter.java:67)
> at
> org.hibernate.exception.JDBCExceptionHelper.convert(JDBCExce ptionHelper.java:43)
> at org.hibernate.loader.Loader.doList(Loader.java:2147)
> at org.hibernate.loader.Loader.listIgnoreQueryCache(Loader.java :2028)
> at org.hibernate.loader.Loader.list(Loader.java:2023)
> at org.hibernate.loader.hql.QueryLoader.list(QueryLoader.java:3 93)
> at
> org.hibernate.hql.ast.QueryTranslatorImpl.list(QueryTranslat orImpl.java:338)
> at
> org.hibernate.engine.query.HQLQueryPlan.performList(HQLQuery Plan.java:172)
> at org.hibernate.impl.SessionImpl.list(SessionImpl.java:1121)
> at org.hibernate.impl.QueryImpl.list(QueryImpl.java:79)
> at
> org.eclipse.emf.teneo.hibernate.resource.HibernateResource.l oadUsingTopClasses(HibernateResource.java:291)
> at
> org.eclipse.emf.teneo.hibernate.resource.HibernateResource.l oadFromStore(HibernateResource.java:277)
> at
> org.eclipse.emf.teneo.hibernate.resource.HibernateResource.l oadResource(HibernateResource.java:239)
> ... 47 more
> Caused by: java.sql.SQLException: ORA-00942: table or view does not exist
> at oracle.jdbc.dbaccess.DBError.throwSqlException(DBError.java: 114)
> at oracle.jdbc.ttc7.TTIoer.processError(TTIoer.java:208)
> at oracle.jdbc.ttc7.Oall7.receive(Oall7.java:542)
> at oracle.jdbc.ttc7.TTC7Protocol.doOall7(TTC7Protocol.java:1311 )
> at
> oracle.jdbc.ttc7.TTC7Protocol.parseExecuteDescribe(TTC7Proto col.java:595)
> at
> oracle.jdbc.driver.OracleStatement.doExecuteQuery(OracleStat ement.java:1600)
> at
> oracle.jdbc.driver.OracleStatement.doExecute(OracleStatement .java:1758)
> at
> oracle.jdbc.driver.OracleStatement.doExecuteWithTimeout(Orac leStatement.java:1805)
> at
> oracle.jdbc.driver.OraclePreparedStatement.executeUpdate(Ora clePreparedStatement.java:322)
> at
> oracle.jdbc.driver.OraclePreparedStatement.executeQuery(Orac lePreparedStatement.java:280)
> at
> org.hibernate.jdbc.AbstractBatcher.getResultSet(AbstractBatc her.java:186)
> at org.hibernate.loader.Loader.getResultSet(Loader.java:1668)
> at org.hibernate.loader.Loader.doQuery(Loader.java:662)
> at
> org.hibernate.loader.Loader.doQueryAndInitializeNonLazyColle ctions(Loader.java:224)
> at org.hibernate.loader.Loader.doList(Loader.java:2144)
> ... 57 more
> It also shows the warning
> WARN main org.hibernate.util.JDBCExceptionReporter - SQL Error: 942,
> SQLState: 42000
> Vijayan
The Netherlands
Re: Teneo : Problem with Library Editor Tutorial [message #59586 is a reply to message #59539] |
Mon, 30 October 2006 06:02   |
Hi Vijayan,
Can you try to set the bookcategory to something else than the default value before saving? It looks
similar to this old issue (url can be truncated by end-of-line):
http://www.elver.org/hibernate/troubleshooting.html#Validati on+exception+on+enumerate+properties+when+saving+the+editor+ content
This should be solved in emf 2.2.
gr. Martin
Vijayan wrote:
> Hi Martin,
> Thanks a lot. I dropped the Database schema and recreated, it works fine
> now. I am able to create a library, add books and writers. But everytime
> i try to change some feature and save i get the following error.
> org.eclipse.emf.teneo.StoreValidationException: Diagnosis of
> org.eclipse.example.library.impl.BookImpl@805550{platform:/resource/librarySample/My.library#/0/@books.2}
> The required feature 'category' of
> 'org.eclipse.example.library.impl.BookImpl@805550{platform:/resource/librarySample/My.library#/0/@books.2}'
> must be set
> at
> org.eclipse.emf.teneo.resource.StoreResource.validateContent s(StoreResource.java:326)
> at
> org.eclipse.emf.teneo.resource.StoreResource.save(StoreResou rce.java:270)
> at
> org.eclipse.example.library.presentation.LibraryEditor$16.ex ecute(LibraryEditor.java:1370)
> at
> at
> at
> at
> org.eclipse.jface.operation.ModalContext$ModalContextThread. run(ModalContext.java:113)
> I could not understand why it is not saving the value that was already
> set for the category feature when i am trying to change the pages/Author
> property of the book.
> Also i can see the tables and the values stored in the database, but
> when i execute a select query on the table i get an error saying table
> or view does not exist.
> Vijayan
The Netherlands
Re: Teneo : Problem with Library Editor Tutorial [message #591612 is a reply to message #51378] |
Hi Nicolas,
gr. Martin
> Hi Martin,
> Reason:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
The Netherlands
Re: Teneo : Problem with Library Editor Tutorial [message #591700 is a reply to message #51588] |
Hi Martin,
Martin Taal wrote :
> Hi Nicolas,
> java packages?
> gr. Martin
>> Hi Martin,
>> Reason:
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
Re: Teneo : Problem with Library Editor Tutorial [message #591716 is a reply to message #51818] |
Hi Nicolas,
gr. Martin
> Hi Martin,
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Martin Taal wrote :
>> Hi Nicolas,
>> gr. Martin
>>> Hi Martin,
>>> Reason:
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
The Netherlands
Re: Teneo : Problem with Library Editor Tutorial [message #591720 is a reply to message #51871] |
Martin Taal wrote :
> Hi Nicolas,
> to this issue.
> gr. Martin
>> Hi Martin,
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> Martin Taal wrote :
>>> Hi Nicolas,
>>> gr. Martin
>>>> Hi Martin,
>>>> Reason:
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
Re: Teneo : Problem with Library Editor Tutorial [message #591727 is a reply to message #51899] |
Hi Nicolas,
gr. Martin
> Martin Taal wrote :
>> Hi Nicolas,
>> to the class:
>> Manifest.MF?
>> gr. Martin
>>> Hi Martin,
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> Martin Taal wrote :
>>>> Hi Nicolas,
>>>> gr. Martin
>>>>> Hi Martin,
>>>>> Reason:
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
The Netherlands
Re: Teneo : Problem with Library Editor Tutorial [message #591774 is a reply to message #51928] |
Martin Taal wrote :
> Hi Nicolas,
> gr. Martin
>> anything.
>> Martin Taal wrote :
>>> Hi Nicolas,
>>> to the class:
>>> Manifest.MF?
>>> gr. Martin
>>>> Hi Martin,
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> Martin Taal wrote :
>>>>> Hi Nicolas,
>>>>> gr. Martin
>>>>>> Hi Martin,
>>>>>> Reason:
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
Re: Teneo : Problem with Library Editor Tutorial [message #591786 is a reply to message #52115] |
Hi Nicolas,
gr. Martin
> Martin Taal wrote :
>> Hi Nicolas,
>> gr. Martin
>>> anything.
>>> Martin Taal wrote :
>>>> Hi Nicolas,
>>>> to the class:
>>>> Manifest.MF?
>>>> gr. Martin
>>>>> Hi Martin,
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> Martin Taal wrote :
>>>>>> Hi Nicolas,
>>>>>> gr. Martin
>>>>>>> Hi Martin,
>>>>>>> Reason:
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
The Netherlands
Re: Teneo : Problem with Library Editor Tutorial [message #594200 is a reply to message #52168] |
Tue, 17 October 2006 07:06  |
I am also facing problems while trying to run the sample Library
application. Please find below the error message that i get.
org.eclipse.emf.teneo.hibernate.mapping.econtainer.EContaine rUserType, for
org.hibernate.mapping.PersistentClass.validate(PersistentCla ss.java:395)
org.eclipse.example.library.presentation.LibraryEditorPlugin $Implementation.start(LibraryEditorPlugin.java:130)
I have checked all the teneo dependencies for the reexport option also.
Please let me know on what is the problem.
Vijayan
Re: Teneo : Problem with Library Editor Tutorial [message #594210 is a reply to message #57902] |
Tue, 17 October 2006 07:13  |
Hi Vijayan,
Can you check if there is another underlying (or earlier) exception in the trace. My experience is
that this exception is just a signal of another exception.
gr. Martin
Vijayan wrote:
> at
> at
> at
> at
> at
> Vijayan
The Netherlands
Re: Teneo : Problem with Library Editor Tutorial [message #594644 is a reply to message #57927] |
Tue, 24 October 2006 01:42  |
Hi Martin,
I could not see any other exception. Please find below the complete stack
trace.
Vijayan
Re: Teneo : Problem with Library Editor Tutorial [message #594663 is a reply to message #58805] |
Tue, 24 October 2006 01:52  |
Hi Vijayan,
Can you post/send me the ecore file? Then I can test myself were it fails.
gr. Martin
Vijayan wrote:
> Hi Martin,
> stack trace.
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Vijayan
The Netherlands
Re: Teneo : Problem with Library Editor Tutorial [message #594796 is a reply to message #58982] |
Wed, 25 October 2006 04:51  |
Hi Martin,
resource library
at org.eclipse.core.internal.resources.Workspace.run(Workspace. java:1737)
Caused by: org.hibernate.exception.SQLGrammarException: could not execute
query
... 47 more
at oracle.jdbc.driver.OracleStatement.doExecute(OracleStatement .java:1758)
... 57 more
SQLState: 42000
Vijayan
Re: Teneo : Problem with Library Editor Tutorial [message #594810 is a reply to message #59211] |
Hi Vijayan,
gr. Martin
Vijayan wrote:
> Hi Martin,
> resource library
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> execute query
> at
> at
> at
> at
> at
> at
> at
> ... 47 more
> at
> at
> at
> at
> at
> at
> at
> at
> ... 57 more
> SQLState: 42000
> Vijayan
The Netherlands
Re: Teneo : Problem with Library Editor Tutorial [message #594928 is a reply to message #59262] |
Mon, 30 October 2006 05:40  |
Hi Martin,
now. I am able to create a library, add books and writers. But everytime i
must be set
I could not understand why it is not saving the value that was already set
Also i can see the tables and the values stored in the database, but when
i execute a select query on the table i get an error saying table or view
does not exist.
Vijayan
Re: Teneo : Problem with Library Editor Tutorial [message #594942 is a reply to message #59539] |
Hi Vijayan,
gr. Martin
Vijayan wrote:
> Hi Martin,
> must be set
> at
> at
> at
> at
> at
> at
> at
> Vijayan
The Netherlands
Current Time: Thu Jul 17 20:50:54 EDT 2025
Powered by FUDForum. Page generated in 0.24708 seconds
