Home » Newcomers » Newcomers » Minimum files needed for eclipse to run
Minimum files needed for eclipse to run [message #51334] Tue, 12 April 2005 18:57 Go to next message
Originally posted by: jeremiah.labresh.com
Hello there,
Is there a set of minimum files needed for eclipse to run for JUST EDITING
PHP. Basically, does anyone know what I can get rid of and what I NEED to
keep? I am experimenting right now with no luck.
-J-
Re: Minimum files needed for eclipse to run [message #52077 is a reply to message #51334] Thu, 14 April 2005 10:22 Go to previous messageGo to next message
Originally posted by: Chris_Laffra.ca.ibm.com
What seems to be your concern? Too large a footprint? Too much memory
consumption? Too slow to start up In other words, why are you trying to
configure your own IDE subset?
If you do "Help > About > Configuration Details", you can see what plugins
are available, and which ones have been activated to do whatever you have
done up to that point.
Chris Laffra, http://eclipsefaq.org
"-J-" <jeremiah@labresh.com> wrote in message
news:d3hk7f$tdl$1@news.eclipse.org...
> Hello there,
EDITING
> -J-
Re: Minimum files needed for eclipse to run [message #54726 is a reply to message #52077] Thu, 14 April 2005 12:49 Go to previous message
ROFL - YES ALL OF THE ABOVE!!!!
Thanks. for the website and the info.
-J-
"Chris Laffra" <Chris_Laffra@ca.ibm.com> wrote in message
news:d3lunl$kjc$1@news.eclipse.org...
> > Hello there,
> EDITING
to
> > -J-
Previous Topic:Install Eclipse in Linux
Next Topic:Print button deactivated
Current Time: Mon May 12 21:39:32 EDT 2025
Powered by FUDForum. Page generated in 0.08113 seconds
